Old 10-05-2012, 11:00 PM   #1
ScottG
Parting out 69 C20 PRICES LOWERED!!!
Got what's left of a '69 C20 to part out. Cab and bed sheet metal was junk, so that's gone to scrap metal. Here's what I have off so far:
Headlight trim, straight light surface rust sold
Fender emblems, some over spray, easily cleanable SOLD
Front turn signals with lenses sold
Gauge cluster, nice printed circuit, everything works SOLD
4 row radiator clamps, rubber good. sold
Headlight buckets with springs and adjusters sold
Tailgate trunions 10.00 shipped
Ball bearing ashtray, crappy paint job, but works great! 10.00 shipped
Lighter, headlight switch, and wiper switch with knobs, headlight switch looks
fairly new. tiny bit of over spray on lighter trim that will clean right off. All
in working condition SOLD
Hood latch with support. Nice and straight, works fine 25.00 shipped
Brake booster w/ proportioning valve and master cylinder. For drum brakes,
works fine. SOLD
High hump trans tunnel. Very nice!!! With bolts SOLD
Saddle seat belts, needs cleaning, pitting on chrome on 1. 1 buckle has
a little cracking SOLD
Saddle visors, very nice SOLD
Aqua blue/ green visors, very nice SOLD
Chrome 1 wire alternator, working condition, don't know the
amperage. dsSOLD
4 row radiator. Aftermarket, appears to be recently replaced. Fins are
perfect. Very nice. SOLD
Left fender, very clean, no dents, cup is good. PO screwed front molding in with 2 small screws, otherwise really nice shape SOLD
Right fender, same screw holes, but 4 instead of 2. Cup has rust, but the rest
is very nice. SOLD
I'll be adding more as I get it apart. If you don't see it, ask, I might have it!!
'67 C20 LBW
ScottG is offline   Reply With Quote
Old 10-05-2012, 11:57 PM   #2
too much stuff
Roadtrip!
too much stuff's Avatar
Re: Parting out 69 C20
I will take the emblems if the studs are intact.
Engine stands?
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is online now   Reply With Quote
Old 10-06-2012, 12:02 AM   #3
ScottG
Engine stands?
They are intact, with the nuts on them as well. I have 2 sets of small block engine stands. No big block, as this truck was converted at some point.
pm sent on the emblems.
thanks, Scott
'67 C20 LBW
Old 10-06-2012, 05:54 AM   #4
gmc 2500 4x4
i'll take brake booster
gmc 2500 4x4 is offline   Reply With Quote
Old 10-06-2012, 08:08 AM   #5
WETOWM
I need the part of the floor where the high hump cover bolt to if you still have the cab ?
WETOWM is offline   Reply With Quote
Old 10-06-2012, 10:27 AM   #6
cericd
cericd's Avatar
Interested in the lighter and switch set. Do you have the wiring harness for the lighter? Is the headlight switch a gm part?
cericd is offline   Reply With Quote
Old 10-06-2012, 10:59 AM   #7
ScottG
Pm sent.
'67 C20 LBW
Old 10-06-2012, 11:02 AM   #8
ScottG
I do have the harness, I'll throw that in. Switch looks aftermarket, but that's not a bad thing. Put 2 Delco switches in my truck, 1 took a dump after 2 months, and the replacement was DOA right out of the box!
'67 C20 LBW
Old 10-06-2012, 11:03 AM   #9
ScottG
No sorry. I cut it up because it was badly rusted. I'll keep an eye out though.
'67 C20 LBW
Old 10-06-2012, 12:03 PM   #10
bollybib
bollybib's Avatar
I'll take the seat belts. PM me your payment info.
- Jim -
My Daily Driver is a 1969 Chevrolet Custom/20 Fleetside 350/TH400/Eaton H052 4.10
and its Project thread is here http://67-72chevytrucks.com/vboard/s...d.php?t=456911
bollybib is offline   Reply With Quote
Old 10-06-2012, 12:18 PM   #11
ScottG
Originally Posted by bollybib View Post
i'll take the seat belts. Pm me your payment info.
pm sent
'67 C20 LBW
Old 10-06-2012, 01:00 PM   #12
cericd
cericd's Avatar
Hey scottg I was mostly concerned with the knobs looking the same including the brushed metal inserts. Do they? Would all the parts clean up real nice? Does the lighter assembly have a light? Just curious. Thanks
Old 10-06-2012, 01:32 PM   #13
ScottG
All knobs are identical, they will clean up nicely. Lighter does not have a light.
'67 C20 LBW
Old 10-06-2012, 05:21 PM   #14
gmc 2500 4x4
payment sent<<<
Old 10-06-2012, 05:29 PM   #15
ScottG
payment sent<<<
Thanks Paul.
Scott
'67 C20 LBW
Old 10-06-2012, 06:01 PM   #16
Rgthoma
I'm looking for a bellhousing #3925505
Rgthoma is offline   Reply With Quote
Old 10-06-2012, 06:10 PM   #17
BlackhillsHD
BlackhillsHD's Avatar
I will take the cluster. PM me with payment info
1970 : Chevy: K20 "Frank the Tank" 6.0 LS, 4L80E, 14 bolt, and Dana 44
1970 K5 Blazer CST 350, TH350, Np205, Dana 60 and 14 bolt
General Motors Master Certified wrench swinger
ASE certified Master auto tech
Instructor of Automotive Technology
BlackhillsHD is offline   Reply With Quote
Old 10-06-2012, 06:24 PM   #18
burb71
Active Member
Do you still have the big block power steering hose
burb71 is offline   Reply With Quote
Old 10-06-2012, 06:43 PM   #19
ScottG
I have one, but not sure of the #. I'll check when I get home.
'67 C20 LBW
Old 10-06-2012, 06:44 PM   #20
ScottG
PM sent. Thanks, Scott.
'67 C20 LBW
Old 10-06-2012, 06:46 PM   #21
ScottG
You know, I might. The p/s bracket doesn't look right to me for a small block, so the PO might have used the original on it. I'll get back to you on this.
'67 C20 LBW
Old 10-06-2012, 06:51 PM   #22
BlackhillsHD
Paypal sent. Thanks
Old 10-06-2012, 07:07 PM   #23
cericd
cericd's Avatar
Hey Scott, I'll take the lighter w/harness and switches. PM me with payment info. Thanks
Old 10-06-2012, 07:22 PM   #24
Rgthoma
Thanks Scott, I need the 5 inch opening, not the 4.xx inch opening.
Old 10-06-2012, 07:28 PM   #25
ScottG
PM sent, thanks!
'67 C20 LBW
cluster, fenders, radiator, seat belts, visors
