Old 12-28-2009, 04:29 PM   #1
Thealien
Thealien's Avatar
Mating a 4L60 to an NP205 (part of my 5.3 swap)
I will include this in my build thread but thought some of you may be interested in what is needed to mate a 4L60 to the NP205 transfer case usually found in our trucks.
Here is my original adapter next to Advance adapters part number
50-5302
Which is part of
4L60205
You save about $90 buying the whole kit. Due to poor understanding by the Techs at advance adapters I bought the kit piecemeal
Here you will see their 4 bolt to 6 bolt adapter part number
50-0405
will not fit on the stock adapter.
This was in their instructionsbut nowhere on their site and none of their techs informed me of this even after numerous conversations?
Here are a couple of pictures showing some of the differences. I do believe you could alter the stock adapter with a cut off wheel on a grinder as it seals against the first flat spot/shoulder and not anywhere on the part you would have to cut off.
I figured aluminum would be easier to work with so I opted not to cut mine and sell it to offset the cost.
Their adapter
Stock adapter
Now you will see even their adapter doesn't fit 100%. If you cut the flange off the stock adapter you would not have to deal with this. If you use theirs you will run into this. The VSS will not screw into the adapter due to this flange!
So I made a modification
Old 12-28-2009, 04:30 PM   #2
Thealien
Thealien's Avatar
Re: Mating a 4L60 to an NP205 (part of my 5.3 swap)
the 2 adapters together showing my modification
Here is the VSS installed
The reluctor ring that triggers the VSS
How it looks from the end before the TC adapter is installed
And here is a thread where I discuss the different output shaft needed and the installation of the reluctor ring I start discussing it near the end of page 1 and onto page 2.
Critters thread
Old 12-29-2009, 01:47 PM   #3
Critter
Future TOTM Winner
Critter's Avatar
THANKS! You have cleared up a lot of questions that I have been asking AA and NOT getting any answer to. It's strange that they have these two adapter together in a kit yet you have to modify the two to fit the VSS.
One question, both the adapters are aluminum, correct?
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces)
72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts
2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver
Check it out www.lsdyno.com
Critter is offline   Reply With Quote
Old 12-29-2009, 02:03 PM   #4
Thealien
Thealien's Avatar
Yes both are aluminum. I think the reason you have to modify is there are many different aplications for the different parts. If you wanted to use their transfer case adapter with a stock bearing supported coupler (no VSS) the modification I made would make that unuseable! In the instructions it says if you have the bearing supported adapter you will need theirs (its about what the savings are if you buy the whole kit instead of idividual pieces like I did) But I can't see why you just couldn't cut the 1/2 inch off the transmission end of the coupler and use it without the bearing? Other than the bearing area the outside diameter of the two couplers are the same. My coupler had slight grooves where the seals rode so I needed one anyway.
I really want to try and sell my original adapter or I would modify it to see if I can make it work. I like to Know, have the answers but I do believe it wouldn't be too bad.
Old 05-21-2010, 11:33 AM   #5
Critter
Future TOTM Winner
Critter's Avatar
I'm sure it's in one of these posts somewhere, but what did the overall length of the transmission and adapter come out to be? Basically the distance from the front of the bell housing to the rear of the adapter?
Old 05-23-2010, 12:29 PM   #6
Thealien
Thealien's Avatar
Advance adapters says it ends up being the same as an older 700R4.
IT SAYS HERE A 700R4 is 23 3/8ths and a 4L60 is 21 3/4
With the adapter it is probably slightly longer than the 23 3/8ths? I never measured but I will next time I am at the garage.
BTW it has run and moved under its own power. Still have lots to do but it is getting there!!
Old 05-23-2010, 10:45 PM   #7
Critter
Future TOTM Winner
Critter's Avatar
Thanks, I'm concerned with the overall length including all the adapters. I think for you it's going to be 27 3/8" but I'm not sure. I'm having second thoughts about going ahead and using the 4L80e instead, for comparison it's length in this situation would be 30" exactly.
Old 08-13-2010, 04:28 PM   #8
SWB4x4
SWB4x4's Avatar
will this adaptor kit work with the 4l80e as well?
J.T.
1972 SWB 4X4 on 35"s with 6" lift all around 3/4 ton running gear with high steer and 4.88s 350/th350. SOON TO BE DONE:2" higher in front 37"s,LSX Swap,Hugger Orange & White Paint Scheme,Air Conditioning,Power Windows & Locks,Complete Gauge Kit,Tank Relocation,Double Din Nav with full Audio System.
My Build Thread http://67-72chevytrucks.com/vboard/s...=1#post4169140
SWB4x4 is offline   Reply With Quote
Old 08-15-2010, 06:19 AM   #9
Puropedo
Alien, THANKS for all the advise and info you have been providing all this time, keep up the great work..
Puropedo is offline   Reply With Quote
Old 08-15-2010, 07:13 AM   #10
Thealien
Thealien's Avatar
I don't think so. I would check out advance adapters. I believe there is a solution to mate the 4L80 to the NP 205. You will have to move the NP205 back a couple of inches changing driveshaft lengths and shifter location. You will either need to cut the hole for the shifter further back or try to rebend the shifter?
Old 08-15-2010, 07:14 AM   #11
Thealien
Thealien's Avatar
Thanks for reading, commenting, and apreciating what little help I have provided.
Mark
Old 08-17-2010, 06:41 PM   #12
SWB4x4
SWB4x4's Avatar
found it pn# 50-0410 I will post up measurments once I get it in there THANKS!
J.T.
Old 01-07-2011, 04:11 PM   #13
C20-67_N_MO
Champagne Taste on Beer Budget
C20-67_N_MO's Avatar
Does this small adapter work with the TH400 going to the 4L60?
Not sure if the output spline is the same as theTH350 tranny.
Coming Soon: Project 1970 Country Truck
C20-67_N_MO is offline   Reply With Quote
Old 03-02-2011, 08:58 PM   #14
themb2g
I am planning on doing an LQ4 to a 4L60 and 27spline np205 and was going to purchase the AA Parts needed. I heard recently that because of clearance issues when doing this swap, you need to have at least a 3"-4" lift for the engine and drivetrain to clear? I figure since you have already done this project, you would be the one in the know. I have already bought a 2" spring lift and now i am wondering if i got a little ahead of myself on the build. Thanks for the help thealien.
themb2g is offline   Reply With Quote
Old 07-06-2011, 12:16 PM   #15
d.garza9
d.garza9's Avatar
Just got out of the transmission shop and not to my surprise they had no clue what the heck to do. They were hesitant on cutting the stock transfer case adapter to make the VSS fit. My question is do the original bearings need to be used or can they be removed? Also does the the coupling inside the TC need to be replaced? I ask because the new shaft I purchased from AA fits into the stock one!! Please help!
If You Ain't First, You're Last - Ricky Bobby
It doesn't matter if you win by an inch or a mile; winning's winning - Dominic Toretto
The LORD himself goes before you and will be with you; he will never leave you nor forsake you. Do not be afraid; do not be discouraged- Deut. 31:8
d.garza9 is offline   Reply With Quote
Old 09-21-2011, 12:44 AM   #16
Teck
Teck's Avatar
I'm look at doing this conversion in my blazer.
I'm going from a 383/700r4/205 to a 5.3L/4L60E/205.
I have the advance adapter output shaft in my 700r4 for it to bolt up to the 350/205adapter.
Do I need to use it and 50-0405 or do I just need 50-0405E without the shaft?
And from what I read i might need to machine mine to fit together.
1986 K5 Blazer
Teck is offline   Reply With Quote
Old 12-04-2011, 12:27 PM   #17
Teck
Teck's Avatar
Thealien, what did you do on your front driveshaft?
Got everything installed yesterday, went to put the front shaft in and it hits the back corner of the pan.
1986 K5 Blazer
Old 08-28-2012, 12:21 PM   #18
Gunny Davis
Did you ever come up with a solution for the Front Driveshaft clearance?
I was thinking of taking my blazer to a driveshaft shop and see if they have any suggestions. I initially tried hammering the corner of the Trans pan in but still don’t have the clearance necessary.
My 72 Blazer Vortec Swap
http://67-72chevytrucks.com/vboard/s...d.php?t=479956
Gunny Davis is offline   Reply With Quote
Old 08-28-2012, 12:33 PM   #19
Teck
Teck's Avatar
Not yet. But did talk with a good friend that has a 4wd shop and he said they make a smaller and shorter CV that he thinks should work. Just need to get
all the parts and a different yoke for the 205. I can post what I use when I get it done.
1986 K5 Blazer
Old 08-31-2012, 02:46 AM   #20
ch0psv1lle
Good info...... can this be used on a 6L60e as well?........ it would be pretty badass to have a 6 speed auto behind a custom ls408 stroker lq9.
ch0psv1lle is offline   Reply With Quote
Old 10-04-2012, 05:38 PM   #21
hilljob26
hilljob26's Avatar
i just got off the phone with matthew at advance adapters and he says that kit 50-5310 is a complete kit with all the machining done,its a bolt on and go kind of deal. you will still need to change out the output shaft, but other then that,its an easy swap
its currently priced at 681.00.. a lil steep,,but with all the guess work taken out,,probably well worth it
21 2500hd duramax
58 apache
HILLJOB GRAPHIX--for all your graphic needs
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=542497
LS ENGINE SWAP INFORMATION THREAD
http://67-72chevytrucks.com/vboard/s...d.php?t=377348
4l60 to an NP205
http://67-72chevytrucks.com/vboard/s...43#post3697343
hilljob26 is offline   Reply With Quote
Old 11-11-2012, 08:19 PM   #22
JPFOURIE
http://www.advanceadapters.com/products/pn-50-0405e/ a lil off topic but, would this be all i need to mate my 4x4 4l60e to np208?
JPFOURIE is offline   Reply With Quote
Old 11-11-2012, 08:34 PM   #23
Teck
Teck's Avatar
That is for a NP205 not a NP208. I would just call them and ask if it works for that or if you need something else.
1986 K5 Blazer
Old 02-09-2013, 12:25 AM   #24
1972K20
1972K20's Avatar
Can you mate a NP205 to a 2WD 4L60? I've been looking for a 4WD 4L60s, but I'm wondering if a 2WD will work just as well.
1972K20 is offline   Reply With Quote
Old 02-09-2013, 12:31 AM   #25
Crash_OK
Crash_OK's Avatar
Yes it will... After you change the tailshaft and add the adapter..
Mark
Crash's 69 4x4 SWB
Crash's Roof over Lake Home
Crash's 1988 Land Cruiser Build
Crash_OK is offline   Reply With Quote
