Old 09-29-2013, 12:51 PM   #276
piratexpress1369a
piratexpress1369a's Avatar
Re: 1960 GMC K1000 4x4
brakes are for pussies lol
My 63 GMC Panel Slow Build
http://67-72chevytrucks.com/vboard/s...=1#post5457281
63
piratexpress1369a is offline   Reply With Quote
Old 10-04-2013, 05:23 PM   #277
rusty76
rusty76's Avatar
Put this bad boy in the low buck build thread as well. Killer truck man. I like it. I'm not a big 4x4 guy, bad luck with a few, but I like your truck non the less. Killer.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873
The low buck build threads. Check'em out!
http://67-72chevytrucks.com/vboard/s...d.php?t=666022
My build thread
Crossmembers CC
rusty76 is offline   Reply With Quote
Old 10-12-2013, 07:21 AM   #278
KroAutomotiveInc
KroAutomotiveInc's Avatar
Been trying to keep at the 4x4 been starting her up everyday to keep me motivated. I also have a small side grade to my property that i have been romping up when pulling it around just to get that thrill going!
Today I was able to work on it a little bit still just preparing for the brakes i was able to get rebuild kits for the front wheel cylinders witch i got all wrapped up. then i tore into the old re-done brake lines witch are in rough shape so i'm redoing everything new i got the front half all pulled down.
After the brakes i need to get a tune up, air cleaner, dimmer switch, pvc valve and O ring, 2 small exhaust hangers, ground the tail lights and bolt the bed down (lol..) and im sure a handful of things before shes road worthy.
KroAutomotiveInc is offline   Reply With Quote
Old 10-12-2013, 10:49 AM   #279
TJ's Chevy
TJ's Chevy's Avatar
Well, At least your making progress! Better then no progress! Keep up the good work.
Old 10-12-2013, 08:21 PM   #280
KroAutomotiveInc
Thanks buddy! Me and you gotta meet up i would love to take a road trip up your way with the 4x4 one day.
I actually got a little bit of a surprise today i looked up the serial number on my block. The P.O told me it was a new 350 crate motor that he payed to get put in 15-20 years ago witch he had only put 10-15k on since. Turns out its a 62-67 327! Witch makes me super happy i love having something different and more period correct to the truck seeing how i wouldn't want that 305 in there anyhow!
Old 10-13-2013, 10:52 AM   #281
KroAutomotiveInc
further research has come to disappoint me i had looked up the motor serial number from a sticky note in one of the repair manuals the PO gave me it read dells new motor #3959512 witch brings up the 327 on a Google search from there i became interested in the heads and when i learned they were nothing special i figured i better check the number on the actual motor turns out its a 79 350 out of a impala or camaro here's the numbers 3970010 K0330DRH 19L600051 and the heads are supposedly the worst ever made lol 462624.
Old 10-13-2013, 10:33 PM   #282
TJ's Chevy
TJ's Chevy's Avatar
Well its better then a 305 for starts! And I would get a set of Edelbrock heads and give that block some fuel! P.S. (Better than a 265!!! HAHAHAH!!)
Old 10-14-2013, 12:02 AM   #283
KroAutomotiveInc
LOL yeah its nothing to complain about for sure. Yeah i think i need to look into some heads for sure i read that the heads i have are prone to cracking. The low miles gives me piece of mind that i still have some time but i need a toy that goes real fast
Old 10-14-2013, 12:21 AM   #284
mud.man.rj
mud.man.rj's Avatar
Ya those heads are junk, prone to cracking and large 76cc combustion chamber, install a set of Vortec heads and matching intake will perk it right up. Good block # though, they were used in 327 and 350 configuration.
1987 Green n Green machine.
5.0 4spd std.
7" lift w 35's.
mud.man.rj is offline   Reply With Quote
Old 11-17-2013, 09:00 PM   #285
KroAutomotiveInc
All this ruckus put a smile on my face thought some of you might enjoy it!
http://youtu.be/wXMnUXdZO7U
Old 11-18-2013, 12:07 PM   #286
TJ's Chevy
TJ's Chevy's Avatar
Cool! No smokey burnouts???? No 4,000+ revs on the ol 6??? MORE MORE!!!!!!
Old 12-31-2013, 04:10 PM   #287
KroAutomotiveInc
Old 12-31-2013, 09:08 PM   #288
TJ's Chevy
TJ's Chevy's Avatar
Brakes are coming along nicely so far! Keep up the good work!
Old 01-01-2014, 12:03 AM   #289
mud.man.rj
mud.man.rj's Avatar
Engine looks good, but the brake lines are...
5.0 4spd std.
7" lift w 35's.
Old 01-01-2014, 04:15 AM   #290
McMurphy
McMurphy's Avatar
Happy New Years Kro !!
Glad to see you posting on this again, though sorry to hear your motor took a dumper on you...
Michael McMurphy
My 66 Stepside
My 64 Tow Truck
My 66 Tempest
Table Of Contents Added to Page1
McMurphy is offline   Reply With Quote
Old 01-01-2014, 09:53 PM   #291
KroAutomotiveInc
Thanks guys there coming along nicely, happy new year to you as well mcmurphy hope its a good one for ya i just watched your video on your lights that has to be the coolest thing ive seen yet!
Old 01-04-2014, 04:34 AM   #292
KroAutomotiveInc
sorry i didn't add anything with the photos i can only edit 30 min after posting but i should of talked about the clutch line. Originally they have a rubber flex section witch I've heard are not made anymore i replaced mine with the solid line works great just added the one loop in it!
Old 01-04-2014, 09:46 PM   #293
TJ's Chevy
TJ's Chevy's Avatar
Aww man Kro! Its illegal to not post pictures!
Old 01-06-2014, 10:52 PM   #294
KroAutomotiveInc
i can already smell the first burn out boys!
Old 01-08-2014, 01:54 AM   #295
KroAutomotiveInc
well boys she made it i cant believe how fast it is that 3rd gear lasts for days. on the free way ear plugs are a must but she cruises at 85-90 with ease. I'm so happy with how it turned out its everything i wanted!
Old 01-08-2014, 10:13 AM   #296
piratexpress1369a
how cool that is good for you ,any video?
63
Old 01-08-2014, 10:16 PM   #297
mud.man.rj
mud.man.rj's Avatar
Good for you, nice to finally drive it I bet.
5.0 4spd std.
7" lift w 35's.
Old 01-09-2014, 01:11 AM   #298
KroAutomotiveInc
thanks guys and yes it feels so good to drive it i will post a video of me running through the gears soon. i had the camera set up today on my way to work but i wasn't going to shoot the video till my way home. i wish i would have turned it on. getting on the free way i had my foot in her and lost the drive line everything but the u joints where missing haha and in my typical lucky fashion i had a highway patrol roll up on me who lucky wasn't a dick he shoved me to the next exit and into a parking lot then i had two guys roll up who towed me home.
(Note to self get the dam front drive line on haha!)
Old 01-09-2014, 11:35 AM   #299
chevy_man5
GMC's n H.D.'s too!
chevy_man5's Avatar
Lucky!!!
and you STILL don't have that driveline in??? That was like a year and a half ago. LOL When I met you, and got to take a brief ride in it, you didn't have it in.
Jason
1960 GMC 4x4 Babe (the Blue Ox) - Build Thread
chevy_man5 is offline   Reply With Quote
Old 01-09-2014, 12:14 PM   #300
TJ's Chevy
TJ's Chevy's Avatar
^^^^^OMG^^^^HAHAHAHA!!! Sorry! But ChevyMan made me laugh. Sorry to hear 'bout yer drive shaft falling off. I had a broken u-joint on mine and I still did burnouts! lol! BUT I did replace it!!!!!!!
1960 gmc, 4x4, 60-66, gmc, k1000
