Workaholic
99 Suburban - add aux input?
I have a 99 Suburban that has the factory AMFM/TAPE head unit and the factory slave CD player. I just want to add a simple aux input to this setup to connect my iPhone to stream iheart radio, pandora, etc. Looking for a low cost solution and I don't need to be able to control or charge the phone, just need to get the tunes from the ipod to the factory unit. Any suggestions would be appreciated.
1979 K-10 Silverado (work in progress) 1991 V1500 Subruban 1999 Suburban LT 4x4 2006 Suburban LTZ (daily driver) |
Re: 99 Suburban - add aux input?
there is a peice on crutchfeild, but it may require factory xm head unit.
otherwise just get one of those tape input things that goes to the headphone jack
Ed will be known as the Tiger Woods of the integration business |
#4 | |
Workaholic
Interference? If so, I will have to keep searching as I am right outside Houston. Thanks for the tip
basically you tune it to an off air station... problem in big cities are the high school, college and other low frequency stations... its almost a given in a big city you will get overlap literally from block to block
