06-17-2014, 05:20 PM | #1 |
Re: S10 Swap how to
Moderators- When Sarge completes this can we get a sticky? Maybe in the builds section...
Thanks. Last edited by iowaboynca; 06-17-2014 at 05:22 PM. Reason: added to post |
06-18-2014, 12:40 PM | #2 | |
and a few others
Re: S10 Swap how to
mr48chev, anyone who's been on this forum for any length of time is well aware of your opinions of lowered or frame-swapped trucks. You don't need to seek out these types of threads to keep reminding everyone. Just a suggestion; when you see a thread titled "bagged" or "lowered" or "slammed" or "S10 swap" DON'T CLICK ON IT.
Bill US Army Vet -193rd Infantry BlueRidgeMuscleCars.com “The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi |
10-19-2017, 04:06 PM | #3 |
Re: S10 Swap how to
im curious to know what is wrong with the threads that have , bagged, lowered, or slammed in them ... i just posted my first thread and it has bagged in it .. i understand you dont like the style , but we need help just like anyone else .
mr48chev, anyone who's been on this forum for any length of time is well aware of your opinions of lowered or frame-swapped trucks. You don't need to seek out these types of threads to keep reminding everyone. Just a suggestion; when you see a thread titled "bagged" or "lowered" or "slammed" or "S10 swap" DON'T CLICK ON IT. __________________ Bill US Army Vet -193rd Infantry |
10-19-2017, 04:21 PM | #4 | |
Re: S10 Swap how to
Funny... very funny.
www.olesargecustoms.com email: chris@olesargecustoms.com '48 build: http://67-72chevytrucks.com/vboard/s...d.php?t=541904 '33 build: http://67-72chevytrucks.com/vboard/s...=1#post6232888 '49 build: http://67-72chevytrucks.com/vboard/s...=1#post6364475 |
10-19-2017, 04:52 PM | #5 |
Re: S10 Swap how to
for anyone wondering how to move the stock 4.3 or want to install a sbc, and dont think you want to build the super simple engine mounts skymangs shows, I have recommended and just recently installed for the first time the universal weld in engine mount crossmember from speedway motors. It comes with two new motor mounts and is $75.
to keep the motor at the same height as stock, I ended up with the tube almost exactly 1/2 way over the frame then boxed in the open end. you can measure from the center of the original mount to the center of the new mount to get the right amount of move, mine is moved 10 inches because its a 41 going on the frame, measure your own to be sure. also, dont forget to offset about an inch to the passenger side for steering shaft clearance, and install the mount at a 4 degree down angle. you dont have to level the frame, just put an angle finder on the middle part of the frame and note the angle, then install the motor mount with 4 more degrees down to the rear IMG_7385 by Joe Doh, on Flickr IMG_7415 by Joe Doh, on Flickr IMG_7418 by Joe Doh, on Flickr IMG_7437 by Joe Doh, on Flickr what about the trans? what if you dont want to section your original or dont have it? speedway makes one of those too. get the one with the 4" drop, I got the 2" drop and it wasnt enough for exhaust. Messages Image(4025115421) by Joe Doh, on Flickr you might need to cut the center of it out to fit a later trans mount. IMG_7408 by Joe Doh, on Flickr it comes with two triangle mounts, but so does the engine crossmember, if you use them all on the trans mount you have a removable trans mount, easy peasy. IMG_7453 by Joe Doh, on Flickr if you order them at the same time you get free shipping, and its under $130 for both WITH new engine mounts. you can build them like skymangs shows and its not very hard and is defintely cheaper, but I spent more time at homer derpo getting the parts to make my own on the last truck than I did installing BOTH of these
10-19-2017, 08:56 PM | #6 | |
Re: S10 Swap how to
http://67-72chevytrucks.com/vboard/s...d.php?t=517098 The nice part about an Internet community is you can ignore anyone you want no matter how loudly they type I'm currently working on putting an accuair e-level and firestone bags on my S10 swap. Be happy to share my mistakes and research with ya.
Current Build Thread 1930 Ford Model A Modern Twist: Ford Model A Rat Rod With a Modern Twist Build Thread Phase 1 "The Swap": 1949 3100 with S10 swap. Beginner build with ambition! Build Thread Phase 2 "The Drop": Beginner Build with Ambition gets Air Ride |
10-19-2017, 10:20 PM | #7 | |
Re: S10 Swap how to
There's nothing wrong with coming on here and asking for help but before you act like you own the place and start telling everyone how it is you need to put in your dues. Learn, share, show us how you got it done, what your experience taught you, and what you've ****ed up so we don't **** it up too. Then maybe, we, or at least I, will give a **** about your opinion. Sorry to hyjack the thread, rant done. Please, back to "S10 Swap how to". |
10-19-2017, 10:29 PM | #8 | |
Re: S10 Swap how to
guys guys, settle down. as a new guy he didnt get his quote right, he was quoting a MOD on the first or second page, who had deleted a couple of mr48s posts in this thread about what a stupid idea s10 swaps are.
it was a long time ago, everyones moved on since.
10-19-2017, 10:50 PM | #9 | |
Re: S10 Swap how to
I will agree that there are a lot of different styles and builds on here and you don't have to like them all but should be respectful of other peoples work, unless they're doing something really stupid like a Toyota Prius swap, actually, I might tune into that. |
10-31-2017, 01:09 PM | #10 |
Re: S10 Swap how to
Couple quick questions:. ( Remember, my first build. Appreciate all input.)
With the engine hanging in the truck, the pan is about 2.25" above the front crossmember. It really can't be lower, my v8 s10 conversion headers will hit the a arm on the pass side. The carb mounting surface is about 1* high in front, again, to clear the header. I can't raise the tranny anymore without raising the cab, it's pretty close to the floor at the tranny rear(1.5") and I have cut out all of the firewall that I want. I don't want to tunnel the whole cab. I could tunnel the middle where it dishes down under the seat, but that looks like the driveshaft won't have a lot of clearance at the back of the cab under weight. I would consider installing another 1/2" spacer on top of the cab mounts, if necessary. So, does this sound like I am in the ballpark of where I should be. Second question:. I am about 4.25" off of the frame to the bottom of the floor, not mounting surface, the floor. Will I have problems lining up the fenders and hood with my radiator support with the 19"x22" radiator in it if I leave it here. I am working on the radiator support now. I know rasing the cab would fix all of this, but my dad is in a wheelchair and I need it to be low. Will not use airbags.
Jim Building my first hot rod 54 Chevy truck, S10 frame 383/700r4/373 |
11-01-2017, 09:37 AM | #11 | |
Re: S10 Swap how to
If you're trying to get a low ride height, that is easier done with drop spindles than trying to lower all that sheet metal around the engine and trans. The S10 swap motor mounts are pretty much going to set the engine in place without much leeway on height or placement. Some of the builders on the forum do custom motor mounts to have more options. On the bolts for the radiator, I just chopped mine off after seeing the same problem with a 19x22" radiator. There are so many other bolts holding the radiator and sheet metal on, I figure those ones are optional. I may go back and just install a couple short carriage bolt style ones from the radiator side with the flat head and tack weld them so they don't spin.
11-12-2017, 12:03 AM | #12 |
Re: S10 Swap how to
Help needed with a few general questions in swapping '51 chassis with a 2001 S10. Can I use the S10 radiator, or will it be way to wide to fit? How about using the air conditioning? Can the S10 condenser and evaporator by fit into a '51? Thanks,
10-19-2017, 11:34 PM | #13 |
Re: S10 Swap how to
it looked like he was putting down the bagged , slammed ect, i really didnt mean anything by it , and i also did not realize how many people were a part of this group and how many questions are asked every day , and how it takes very Special people , to answer people questions for free and give a crap .. i do apologize i have been searching thru these threads and having a little bit of a hard time . and didnt realize i was calling anyone out or especially someone that has contributed so much to this AWESOME group ..
