Old 02-04-2013, 03:03 PM   #126
67_ShortFleet
67_ShortFleet's Avatar
Re: 67 short fleet
240-Volt MIG Flux-Cored Wire Feed Welder
•Forgiving arc makes dialing in your application easy
•Smooth arc starts with minimal spatter
•30-180 amp welding output range is enough for many tasks
•Weld up to 1/2"steel using self-shielded Lincoln Innershield® wires
•Precision full-adjustment drive system reduces chance of wire tangling and crushing
•Brass-to-brass gun connections for enhanced connectivity
•Large industrial closed-design drive motor for improved torque and trouble-free performance
•No hassle tool-less design -- for wire spool mounting, wire drive service and polarity changes
•Innovative contact tip, drive roll and nozzle storage -- keeps all your consumables close at hand
Matt
Garage build http://www.garagejournal.com/forum/s...ead.php?t=6784
My slow but sure truck build http://67-72chevytrucks.com/vboard/s...d.php?t=394924
My philosophy on tires is the same as cigarettes. "smoke them if you got them"
HAPPILY DIVORCED!
67_ShortFleet is offline   Reply With Quote
Old 02-25-2013, 12:08 AM   #127
67_ShortFleet
Re: 67 short fleet
Some progress. Removed an upper control arm and blasted it and have the new bushing kit mocked up. Removed the engine today. Hope to get the frame to the body shop soon for the repair.
Matt
HAPPILY DIVORCED!
Old 08-21-2013, 12:37 AM   #128
35 prog
Re: 67 short fleet
Matt Can that welder be gas converted? Nice to see progress.
35 prog is offline   Reply With Quote
Old 08-21-2013, 08:21 AM   #129
67_ShortFleet
Re: 67 short fleet
Oh yes and was right away.
Matt
HAPPILY DIVORCED!
Old 03-03-2014, 12:56 AM   #130
67_ShortFleet
Re: 67 short fleet
A little progress over the weekend. Next stop for the frame is a frame machine to fix some previous damage.
Matt
HAPPILY DIVORCED!
Old 07-12-2014, 08:41 PM   #131
67_ShortFleet
Re: 67 short fleet
Stripped my truck frame of the rear end and all the front suspension today to flip it to do some welding on the trailing arm mount cross member. I added 4 inch rings so I can run my exhaust through them. Hope to blast it soon.
Matt
HAPPILY DIVORCED!
Old 08-13-2014, 10:11 AM   #132
67_ShortFleet
Re: 67 short fleet
I blasted the frame yesterday. I'll fill a few holes tonight and start coating it this weekend.
Matt
HAPPILY DIVORCED!
Old 08-14-2014, 04:17 PM   #133
67_ShortFleet
Re: 67 short fleet
I forgot to add a picture of the CPP notched I installed.
Matt
HAPPILY DIVORCED!
Old 08-15-2014, 08:56 PM   #134
67chevy1series
67chevy1series's Avatar
Re: 67 short fleet
Looks very nice! I hope to get my notches soon and install them. Hopefully you had no troubles with the notches?
67chevy1series is offline   Reply With Quote
Old 08-16-2014, 09:33 PM   #135
67_ShortFleet
Re: 67 short fleet
No trouble with the notches.
Matt
HAPPILY DIVORCED!
Old 08-16-2014, 09:36 PM   #136
67_ShortFleet
Re: 67 short fleet
2 coats of Rust Seal on one frame rail. I decided to coat the frame in sections.
Matt
HAPPILY DIVORCED!
Old 08-16-2014, 09:56 PM   #137
Xeen
Xeen's Avatar
Re: 67 short fleet
Nice, you have been making some good progress lately.
Please call me Brian.
Check out My 1972 SWB Fleetside 5.3L Vortec Restomod Build
Xeen is offline   Reply With Quote
Old 02-24-2015, 11:00 PM   #138
67_ShortFleet
Re: 67 short fleet
Slow but sure progress. I had the frame completely coated with rust seal and did not like the satin finish, so I scuffed the frame down, recoated with another coat of rust seal then topped it off with 2 coats of black top flat. What a pain in the ass! I don't like haw loose the front springs are when it is off the ground, seems like there should be a limit or something.
Matt
HAPPILY DIVORCED!
Old 02-25-2015, 12:54 AM   #139
PHAT TONY
PHAT TONY's Avatar
Re: 67 short fleet
Every time I jack my Blazer up I think the front coils are gonna fall right out lol.
1972 factory 2 Wheel Drive Blazer-Sold
1972 K10 4X4-Sold
1971 Chevrolet Cheyenne/10-Sold
1970 Chevrolet C/10-Sold
1968 GMC 4X4-Project
1968 Chevrolet C/10 Pro Street
1970 GMC 3/4 Ton-Parts
1997 2WD 2DR Yukon-Sweet
http://67-72chevytrucks.com/vboard/s...d.php?t=335664
PHAT TONY is offline   Reply With Quote
Old 02-25-2015, 11:16 AM   #140
JD'S 69
JD'S 69's Avatar
Re: 67 short fleet
Do you have the rubber stopper in the upper a-arm?
When I stand before god at the at the end of my life, I would hope that I would not have a single bit of talent left, and I could say," I used everything you gave me"
My 69 stepper http://67-72chevytrucks.com/vboard/s...d.php?t=601095
JD'S 69 is offline   Reply With Quote
Old 02-25-2015, 01:07 PM   #141
67_ShortFleet
Re: 67 short fleet
No, I don't think it would do much good with the 3" lowering springs.
Matt
HAPPILY DIVORCED!
Old 07-28-2016, 03:57 PM   #142
67_ShortFleet
Re: 67 short fleet
I picked up a 2005 5.3 LM7 and a 4L60e within the last few months. Slow but sure progress. Picked up a LS6 intake. I've been working on the harness. I need to set one of my cabs on the frame to figure out where the engine will sit.
Matt
HAPPILY DIVORCED!
Old 07-28-2016, 03:58 PM   #143
67_ShortFleet
Re: 67 short fleet
In the frame.
Matt
HAPPILY DIVORCED!
Old 07-21-2021, 08:53 AM   #144
68Gold/white
Re: 67 short fleet
Look'n Good, in the CP neighborhood!!! LOL
68Gold/white is online now   Reply With Quote
