02-04-2013, 03:03 PM | #126 |
Re: 67 short fleet
240-Volt MIG Flux-Cored Wire Feed Welder
•Forgiving arc makes dialing in your application easy •Smooth arc starts with minimal spatter •30-180 amp welding output range is enough for many tasks •Weld up to 1/2"steel using self-shielded Lincoln Innershield® wires •Precision full-adjustment drive system reduces chance of wire tangling and crushing •Brass-to-brass gun connections for enhanced connectivity •Large industrial closed-design drive motor for improved torque and trouble-free performance •No hassle tool-less design -- for wire spool mounting, wire drive service and polarity changes •Innovative contact tip, drive roll and nozzle storage -- keeps all your consumables close at hand
Matt Garage build http://www.garagejournal.com/forum/s...ead.php?t=6784 My slow but sure truck build http://67-72chevytrucks.com/vboard/s...d.php?t=394924 My philosophy on tires is the same as cigarettes. "smoke them if you got them" HAPPILY DIVORCED! |
02-25-2013, 12:08 AM | #127 |
Re: 67 short fleet
Some progress. Removed an upper control arm and blasted it and have the new bushing kit mocked up. Removed the engine today. Hope to get the frame to the body shop soon for the repair.
08-21-2013, 12:37 AM | #128 |
Re: 67 short fleet
Matt Can that welder be gas converted? Nice to see progress.
08-21-2013, 08:21 AM | #129 |
Re: 67 short fleet
Oh yes and was right away.
03-03-2014, 12:56 AM | #130 |
Re: 67 short fleet
A little progress over the weekend. Next stop for the frame is a frame machine to fix some previous damage.
07-12-2014, 08:41 PM | #131 |
Re: 67 short fleet
Stripped my truck frame of the rear end and all the front suspension today to flip it to do some welding on the trailing arm mount cross member. I added 4 inch rings so I can run my exhaust through them. Hope to blast it soon.
08-13-2014, 10:11 AM | #132 |
Re: 67 short fleet
I blasted the frame yesterday. I'll fill a few holes tonight and start coating it this weekend.
08-14-2014, 04:17 PM | #133 |
Re: 67 short fleet
I forgot to add a picture of the CPP notched I installed.
08-15-2014, 08:56 PM | #134 |
Re: 67 short fleet
Looks very nice! I hope to get my notches soon and install them. Hopefully you had no troubles with the notches?
08-16-2014, 09:33 PM | #135 |
Re: 67 short fleet
No trouble with the notches.
08-16-2014, 09:36 PM | #136 |
Re: 67 short fleet
2 coats of Rust Seal on one frame rail. I decided to coat the frame in sections.
08-16-2014, 09:56 PM | #137 |
Re: 67 short fleet
Nice, you have been making some good progress lately.
02-24-2015, 11:00 PM | #138 |
Re: 67 short fleet
Slow but sure progress. I had the frame completely coated with rust seal and did not like the satin finish, so I scuffed the frame down, recoated with another coat of rust seal then topped it off with 2 coats of black top flat. What a pain in the ass! I don't like haw loose the front springs are when it is off the ground, seems like there should be a limit or something.
02-25-2015, 12:54 AM | #139 |
Re: 67 short fleet
Every time I jack my Blazer up I think the front coils are gonna fall right out lol.
1972 factory 2 Wheel Drive Blazer-Sold 1972 K10 4X4-Sold 1971 Chevrolet Cheyenne/10-Sold 1970 Chevrolet C/10-Sold 1968 GMC 4X4-Project 1968 Chevrolet C/10 Pro Street 1970 GMC 3/4 Ton-Parts 1997 2WD 2DR Yukon-Sweet http://67-72chevytrucks.com/vboard/s...d.php?t=335664 |
02-25-2015, 11:16 AM | #140 |
Re: 67 short fleet
Do you have the rubber stopper in the upper a-arm?
When I stand before god at the at the end of my life, I would hope that I would not have a single bit of talent left, and I could say," I used everything you gave me" My 69 stepper http://67-72chevytrucks.com/vboard/s...d.php?t=601095 |
02-25-2015, 01:07 PM | #141 |
Re: 67 short fleet
No, I don't think it would do much good with the 3" lowering springs.
07-28-2016, 03:57 PM | #142 |
Re: 67 short fleet
I picked up a 2005 5.3 LM7 and a 4L60e within the last few months. Slow but sure progress. Picked up a LS6 intake. I've been working on the harness. I need to set one of my cabs on the frame to figure out where the engine will sit.
07-28-2016, 03:58 PM | #143 |
Re: 67 short fleet
In the frame.
07-21-2021, 08:53 AM | #144 |
Re: 67 short fleet
Look'n Good, in the CP neighborhood!!! LOL
