11-14-2014, 06:22 AM | #26 |
Re: Urgent, need opinions on my new crate engine
k so a couple fat chicks
11-14-2014, 07:30 AM | #27 | |
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
11-14-2014, 10:55 AM | #28 |
I am not sure where people get these massive weight numbers for some of their trucks that I frequently hear, they must have some crazy heavy stuff mounted on them. These trucks are not that big. I have a 2003 Silverado and a 2014 Silverado and they weigh mountains more than my 71'. I had a 1971 Chevelle SS sitting side by side in the garage with my 71' shortbed for several years and the truck was several inches shorter than the car. (They are longer than a Camaro and shorter than a Chevelle). I weighed my truck at a local scale when I was having a stall converter made and it came in at 3312 lbs with a 350/350 turbo without me in the truck. I have no idea what the full size trucks weigh, but I checked mine so I am positive about it. 290 HP should be more than enough for you as a daily driver/cruiser and should have plenty of power for towing and hauling normal loads(if your truck is not retired). Now if you are looking to smoke the tires at 20 mph you probably better keep on shopping. (Oh and just to clarify my truck had a fiberglass rear roll pan and aluminum rims when weighed so I imagine those items alone shaved off at least 100 lbs)
11-14-2014, 12:29 PM | #29 |
11-14-2014, 01:01 PM | #30 | |
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
11-14-2014, 01:03 PM | #31 |
Just for reference, My 72 C10, short fleet, 350/350, PS, PB, AC, spare, half tank of gas came in at 3,710 on a fresh fame off restoration. My 65 Corvette roadster came in at 3,146. Couple of fat chicks difference.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
11-14-2014, 02:26 PM | #32 | |
11-14-2014, 02:31 PM | #33 | |
11-14-2014, 02:45 PM | #34 |
My shortbed fleetside weighed 3940 on the truck scale at work. Scale has a 20 lb resolution and gets calibrated every 6 months.
Thats PS, PB, aftermarket AC, iron head Vortec 350, Tremec TKO 600, steel bumpers, 3/4 tank of gas, 80's factory rallyes, spare in the bed, and a tool kit in the cab...LOL.
Shawn 1970 Chevy C-10 SWB, 350, TKO 600 5 speed My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881 |
11-14-2014, 02:47 PM | #35 |
Oh, and for comparison my 2012 Tundra Crewmax 4x4 weighed 6400 on the same scale.
Big difference there, but the Tundra is a lot bigger truck and 4x4.
11-14-2014, 02:51 PM | #36 |
is a fungineer
I had the 290hp crate in my '68 longbed with 3 speed manual trans, 3.73 rear gears and a 29" tall tire. Truck ran fine, kept up with highway traffic and had enough power to do what I needed it to.
The only reason I took it out is I was hard up for money and sold it. I would say, if you're willing to put it in as-is, then keep it. If you would plan on putting new heads, cam, etc, I would do one of two things. Send it back and order the right complete engine for you the first time, without having to do more work to it, or order a short block and pick the rest of the components you want.
2003 S10, 2.2 auto- the daily driver, currently with a 2"/2" drop and some minor engine bolt-ons 1978 Impala 2-door, race 350/T350 - the new race car, in progress 1968 Chevy C10 longbed- 3/5 drop, currently undergoing a heart transplant |
11-14-2014, 03:20 PM | #37 | |
I've had 2 long bed 1/2 tons that I paid a lot of attention to from a weight/GVW standpoint and I did the same 'weight check' thing over at the commercial scales quite a few times. One was a leaf spring/Heavy half and the other was a trailing arm regular 1/2 ton (my current blue one in the avatar pic). The 'H.Duty' leaf spring truck was slightly lighter than the trailing arm truck...which makes sense...less steel there for sure with those trailing arms. That said both of these 1/2 ton/long bed trucks were very at or slightly above the 4000lb mark....without me in them. Both of these trucks had the following options: V-8/SBC, ps, pb, auto, a-c, tilt, dual exhaust, deluxe trim and rear bumpers. Once you add in even the basic options it starts to pile up the weight...eg: V-8, ps, pb, auto, bumper, radio, deluxe trim/gauges, auxiliary gas tank, dual exhaust.....they all chunk it on and it easily turns into several hundred pounds. That said, its always good to know exactly what your own truck weighs, that way if you decide to carry or pull a load you know what you are up against. I remember being kind of 'bummed out' that legally my truck couldn't actually take too much load before its GVW rating was exceeded (5000lbs and 5400lbs) until I realized this was due more to the poor tire quality of the era being the weak link in that era's rating system rather than the truck itself. ....anywhooo, a little off topic from the original threads Crate Engine theme but thought I'd throw the info out there anyways. all Good Coley
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL 1966 Chevy 1/2 ton (Florida- Red/white) 1972 Chevy 1/2 ton (California- Blue/white) 2005 Chevy Silverado HD2500/Duramax 2000 Dodge Ram 1500 Last edited by Coley; 11-14-2014 at 03:27 PM. |
11-14-2014, 11:36 PM | #38 |
I put both of my trucks on a scale. The 71 C10 long bed was 4400 lbs and the C20 Suburban was 6800 lbs.
Mike 1971 C10 350 1969 C20 396 1979 Corvette L-82 |
11-15-2014, 12:26 AM | #39 |
UPDATE :
ok guys thanks so much for all your help and input! So it turns out that when I ordered this engine (the 290HP with chrome package # 19244450) I made sure multiple times with the summit racing people on the online chat as to whether the engine came with the intake manifold installed and the valve covers and timing chain cover installed. They said YES!!! Well I went over today to my mechanics shop to look at the engine and NOPE, nothing was installed....its just the cheaper $2000 290 HP crate with the plain black valve covers and timing cover with no intake installed....then they just stuffed all the chrome parts on top of the engine in the wood crate! LOL So because of this, they have agreed to come pick up the engine and take it back free of charge! They will refund me and then I can order whatever engine I want! This is probably good since I was hesitant about this engine anyways and it's not really suited for my application. I am thinking about getting this engine instead.... http://www.summitracing.com/parts/nal-19210007 what do you guys think of this one? I have a few days to make up my mind, so I need feedback!!! Thanks in advance!!!
1972 Chevrolet C20 Cheyenne Custom Camper LWB - 350 / 330 HP GM Crate - TH350 / Mild Shift Kit - Dark Blue / Medium Blue - Paint Code 559 |
11-15-2014, 12:34 AM | #40 | |
11-15-2014, 12:41 AM | #41 | |
So this one should be a good noticeable improvement power wise over my stock engine and will be ok for the my larger GVWR of 6700-7500 ? What balancer would it take and what flywheel? I think I know but you guys are always better at this stuff than me at this point in my knowledge level
11-15-2014, 12:45 AM | #42 |
Also a couple other things while its on my mind.
what does this mean : "Fuel line from pump to carburetor is required. Fuel pump pressure is not required, pump pressure is pre-set." And whats the difference between : balance : internal / external vs (the other engine 290 HP) balance : internal
11-15-2014, 01:24 AM | #43 | |
Now onto internal vs external balanced. Externaly balanced means the crankshaft is well externaly balanced meaning it uses a counter weight on the flywheel/flexplate to balance it. Internaly balanced means that the crankshaft is internaly balanced and DOES NOT need a flywheel/flexplate with a counter weight. |
11-15-2014, 01:33 AM | #44 | |
so does this engine need balance or not?
11-15-2014, 09:57 AM | #45 | |
So you need a non-weighed balancer and weighted flywheel. Flywheel needs to be for the late 350 with 1 piece rear main.
11-15-2014, 10:18 AM | #46 | |
And this: http://www.summitracing.com/parts/tci-399773/overview/ Doesn't have to be those exact ones, but match the specs.
11-15-2014, 10:31 AM | #47 | |
Thanks Shawn! What does the external coolant bypass thing mean? Someone on the summit reviews said it was a pain to incorporate that and still route to his heater core. I'm not familiar with what this is.
11-15-2014, 10:36 AM | #48 |
"Vortec heads also require an external coolant bypass line which was extremely annoying to plumb and keep heater core functional at same timeortec heads also require an external coolant bypass line which was extremely annoying to plumb and keep heater core functional at same time"
11-15-2014, 10:39 AM | #49 | |
11-15-2014, 10:42 AM | #50 |
Ok cool.
What's the temperature valve for? Should I have one of these?
