Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > Vendors Marketplace
Closed Thread
Old 11-24-2014, 04:09 PM   #76
jpoole
jpoole's Avatar
Re: RnD Fabrication 1967-1972 Chevrolet & GMC early C10 / C20 / Blazer Radiators!
Hi, I have a 402 bored .030 over and what looks to be a 2 core radiator with room in front and an inch in back on the tank when compared to the radiator core.
I am probably around 500 hp and am looking for a radiator and fan setup with wiring and relays.
What do you suggest.
thanks, jeff
jpoole is offline
Old 11-24-2014, 04:13 PM   #77
SparkyRnD
SparkyRnD's Avatar
Based on location in Texas, and the HP, I'd go with our upgraded dual-speed 17" fan & shroud kit along with the radiator to keep it cool.
1. radiator with discount is $425
2. upgraded fan & shroud kit with discount is $320
3. controller with relay kit is $75
www.RnDFabrication.com
Custom Radiators, Valve Covers and Overflow Tanks
SparkyRnD is offline
Old 11-24-2014, 04:36 PM   #78
jpoole
jpoole's Avatar
Sounds good how do I order and what is turn around time? My rad is leaking from a crack next to filler neck.
Also, what radiator cap to use on a closed system?
thanks, Jeff
jpoole is offline
Old 11-24-2014, 04:45 PM   #79
SparkyRnD
SparkyRnD's Avatar
I just need an email address and I can send a payment request / invoice. Turn around time is about 2 weeks. For the cap, any standard 12-14lb cap works fine (I prefer the safety cap style)
Old 11-24-2014, 05:01 PM   #80
jpoole
jpoole's Avatar
Hi Sparky, one more question. I have an electric fan pushing through the condenser on front, can I remove that with the high output dual fan setup? Also, I want quiet fans, how noisy are the high output ones?
jpoole is offline
Old 11-24-2014, 05:04 PM   #81
jpoole
jpoole's Avatar
Also, I have a serpintine belt system from chevrolet high performace and it must fit.
jpoole is offline
Old 11-24-2014, 05:10 PM   #82
SparkyRnD
SparkyRnD's Avatar
the radiator is about 3.5" wide, and the dual-speed 17 fan (note that it is a single 17" fan that has a high and low speed) is about the same width, so you'll need around 7" from front to back. For the existing pusher fan, you may be able to remove that but I'd wait until this set up is in place. You will need 3/4" air space min. between the radiator and the condenser.
Old 11-24-2014, 05:29 PM   #83
jpoole
jpoole's Avatar
Hi Sparky, is the standard setup dual fans with shroud? Also, here are some pics. There is like 6.5 inches from very front of core support to accessories. attached a couple of pics.
thanks, Jeff
jpoole is offline
Old 11-24-2014, 05:32 PM   #84
SparkyRnD
SparkyRnD's Avatar
here is the standard dual 12" configuration:
Old 11-24-2014, 05:44 PM   #85
jpoole
jpoole's Avatar
PM Sent
jpoole is offline
Old 11-24-2014, 06:34 PM   #86
SparkyRnD
SparkyRnD's Avatar
Jeff, thanks for your time on the phone today
Old 11-24-2014, 06:50 PM   #87
jpoole
jpoole's Avatar
Sparky knows his cooling!
jpoole is offline
Old 11-28-2014, 12:09 PM   #88
SparkyRnD
SparkyRnD's Avatar
Jeff, we may have another option for your tight quarters. Give me a shout on Monday or we can discuss via PM.
Old 11-28-2014, 06:51 PM   #89
69 c10 FS project
Sparky,
Post #46 finally time to order. Are you price still the same? And how can I complete the order with you, would like to talk prior to ordering
69 c10 FS project is offline
Old 12-01-2014, 09:51 AM   #90
SparkyRnD
SparkyRnD's Avatar
Yes, prices are still the same. To complete an order, I just need you to PM me with your email address and a phone number.
Old 12-12-2014, 04:12 PM   #91
67ctener
67ctener's Avatar
Pm sent. Forgot to add 98271 is my zip
Scott
67 c10 sold
89 c1500
90 k2500
91 s10
#chevyonly
67ctener is offline
Old 12-15-2014, 11:49 AM   #92
SparkyRnD
SparkyRnD's Avatar
replied!
Old 12-19-2014, 10:29 AM   #93
SparkyRnD
SparkyRnD's Avatar
Pre-Christmas bump!
Old 01-07-2015, 10:10 AM   #94
SparkyRnD
SparkyRnD's Avatar
Bringing up for the new year!
Old 01-14-2015, 12:45 PM   #95
SparkyRnD
SparkyRnD's Avatar
Thanks for the support guys!
Old 01-14-2015, 12:50 PM   #96
Lee H
Lee H's Avatar
Installed my new radiator this week. Great product.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline
Old 01-14-2015, 01:01 PM   #97
SparkyRnD
SparkyRnD's Avatar
Thanks, would love to see installed pics!
Old 01-14-2015, 02:44 PM   #98
Lee H
Lee H's Avatar
Already have the covers on but here goes.
Lee H is offline
Old 01-19-2015, 09:11 PM   #99
SparkyRnD
SparkyRnD's Avatar
is that the factory shroud?
Old 01-19-2015, 10:15 PM   #100
Lee H
Lee H's Avatar
Yes, factory AC shroud trimmed 3/4 inch. Will probably trim an addition 1/4 inch next time it's off.
Lee H is offline
Closed Thread
