02-13-2015, 04:44 PM | #26 |
Re: 69 Chevy C20 HO52 full floating rear end drum brake removal/installation.
Thanks for putting this up. I've been hoping to find a step by step process for this when I do my 67 C20. The manual was not helpful to me.
Rich J. 1967 Chevy C20 Longbed Stepside w/283 and 4spdSOLD 2002 Chevy Tahoe 4X4 5.3L SOLD 2015 Chevy Silverado Crew 4X4 5.3L |
02-13-2015, 05:25 PM | #27 |
No problem I felt the same with the books. The torque specs were nice once I found them!
1969 Chevy c20(Miss Hackjob) |
02-13-2015, 06:46 PM | #28 |
threads like this are great - thanks for taking the time to take good pics and to do the write-up. Have seen these on the Dana, but not HO52, great information.
02-13-2015, 10:04 PM | #29 |
Great write-up!
For those interested, here's a picture of the "socket" I used to be sure I torqued the nut properly. I bought it at the local Carquest store. |
02-14-2015, 01:39 AM | #30 |
^^^Thank you! Idk why I couldn't post it.
02-14-2015, 01:29 PM | #31 |
Great job. Thank you.
02-14-2015, 04:35 PM | #32 |
Thanks! I was going to say, the e-brake actuation hardware was super hard for me to find (as it was missing when I went to redo my rear brakes). I had to buy a whole rear end just to get the components.
02-14-2015, 06:53 PM | #33 |
Hey no problem I'm just glad people can use the information. I usually don't mind brake work but something always comes up
02-14-2015, 08:55 PM | #34 |
20' Daredevil (Ret)
Thanks for a great how-to writeup! Wish I had it to refer to the 2 or 3 rimes I've had mine apart. I just laid things out in the order I removed them, then reassembled in reverse order. Used the armstrong method of torquing, and no thread sealer, but it has held together just fine. Bookmarked for future reference!
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
02-14-2015, 09:44 PM | #35 |
Vintage 4x4s
Good writeup. Were you confident the bearings stayed clean through the process? Or did you clean them and I missed it. THanks for posting this!
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades) 67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore ) 86 CHV K30 502 th400, apple red NEW 71 CHV K20 350 SM465, ochre (saved work truck) 71 CHV K20 292 SM465, white, tach, PTO, (future project) 72 CHV K20 350 350th, medium blue (project stocker) 01 CHV K2500hd crew, indigo blue ^3 dont run and the others don't see winter either '86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649 '71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642 '72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6 |
02-17-2015, 08:49 PM | #36 |
Yep I never posted that sorry! I did clean bearings. Whatever I do I always clean what I'm working on. Makes it last longer and look nicer. That's why projects take me longer then most.
02-17-2015, 09:55 PM | #37 | |
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11. 1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9 |
02-17-2015, 10:58 PM | #38 |
Roto Reuter thats the name...
Good job and excellent write up. You should be commended for the time and detail you took to write this up. Nice work.
~ Dan My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232 My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394 1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt 1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project "Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977 |
02-18-2015, 11:00 AM | #39 |
Good job. I like the closeup detail you got on the pics. This will be useful even for those who have done this job several times.
- Jim - My Daily Driver is a 1969 Chevrolet Custom/20 Fleetside 350/TH400/Eaton H052 4.10 and its Project thread is here http://67-72chevytrucks.com/vboard/s...d.php?t=456911 |
02-18-2015, 01:29 PM | #40 |
Thanks for the write-up. You're making me want to do the back brakes.
02-19-2015, 09:01 PM | #41 | ||
Not hard just take your time, when it's done it's nice
02-19-2015, 11:05 PM | #42 |
Thanks for taking the time to post this. I did the front and back brakes on my C20 about 6 months ago. This would have been very helpful. I wish I would have added up how much I spent in total. I think I could have swapped in a whole front end with discs from a 73-87 truck and possibly found a different and newer rear axle/disc brakes for a comparable price. HO52 parts are getting expensive!
02-21-2015, 08:00 PM | #43 |
When I look at your final assembly picture on post 15, I see you're missing a spring. I also see that when you first removed the drum, the spring was missing then.
Tony Nicholas @ Midwest Metal Masters 1953 Chevy 3100 392 Hemi w/727 & 9” Ford 1985 Chevy C/10 6.0L 4L80 373 locker |
02-21-2015, 08:03 PM | #44 |
This spring on the right is missing on your setup.
01-23-2020, 02:34 PM | #45 |
Reviving an old thread I was directed to. Great write-up on this, ...going to bookmark
'68 C20 Utility 396 4sp (BuildThread: http://67-72chevytrucks.com/vboard/s...d.php?t=806904 ) '68 C10 50th |
02-01-2020, 11:51 AM | #46 |
Thank you, the truck has honestly been in hibernation the past few years for the most part aside from the occasional upgrade here and there. Hoping that changes once I move this spring 👍.
02-01-2020, 09:51 PM | #47 |
Old member
I'm going to be doing this myself in a few weeks are so. Nice write up sir, thanks.
I'm going to be doing a full front end swap to disc brakes also.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
03-05-2020, 03:16 PM | #48 |
Great info!
I made the mistake of throwing away my two parking break levers with the old set of shoes. Won't pass safety inspection without them. I've got a 12" dana 60 drum. Would you folks know if any break levers from smaller drums would work? I can find a bunch for 9.5" but no luck with the 12" |
01-17-2021, 09:44 PM | #49 |
Man awesome write up. Just finished doing my HO72 today. Your info really helped for a first time 1 ton owner.
Also opted for new bearings, and decided to go ahead and do the wheel stud upgrade...Dorman part number# 610-193 for the studs. Drilled my hubs to .609 or 39/64 and pressed them in with punch and hammer. |
05-10-2021, 04:15 PM | #50 |
Since I'm going to be tackling this myself in the next couple weeks (and while I'm looking up some parts) I'll add them for reference for others.
Fel-Pro 55350 Axle Flange Gasket: https://www.amazon.com/gp/product/B0...=ATVPDKIKX0DER I am also looking for the axle seal if anyone knows the part# (that press into the backside of the drum/hub). Not sure I need them, but if I have it apart, I'd like to replace. Thanks, Kevin
