#176 |
Re: 1970 One Owner Short Step
More
Just trying to figure this out... 1970 SWB Step-Side http://67-72chevytrucks.com/vboard/s...d.php?t=552980 1970 LWB http://67-72chevytrucks.com/vboard/s...d.php?t=584499 1970 SWB One Owner Step Side 6.0 LY6/6L90 http://67-72chevytrucks.com/vboard/s...d.php?t=617630 Junkyard's 1971 short wide http://67-72chevytrucks.com/vboard/s...86#post7531186 |
#177 |
Last ones for today.
#178 |
i think it will look great when its finished, wonder what kinda wood it is? if ya have a dremel maybe you can polish the rivets too to make them stand out... whatever stain you try go light on the application, second application if necessary.
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
#179 |
Still Learning
Very nice work getting the grill installed and the that's cool steering wheel. I know how time consuming all the little things get on these trucks, but you really are getting close. I hope you can make the March/April cruising season
#180 |
You ever get your seats mounted?
1969 ![]() 2015 GMC 2500 Duramax (Daily Driver) 1999 Jeep TJ 2010 Harley Street Glide Check Out My Build!: http://67-72chevytrucks.com/vboard/s...d.php?t=617981 |
#181 | ||
Not yet. My upholstery guy was super backed up and still doesn't have them done. Maybe sometime in June.
#182 |
I finally got the bed painted abd have spent the last couple of days fitting it. I have been moving at a snail's pace because I haven't built a wood bed before, so I am taking it super slow.
![]() The results have been very good and I only have one scary part left: drilling the carriage bolt holes. I did figure out I am going to have to drop my fuel cell to get to the cross member behind the rear axel. Nothing like doing something 2, 3, or 5 times before its actually done. I set the completed box in the frame so I could test fit everything. I also put the left fender on to double check the fitment of the filler neck. Now to pull it all back off and finalize everything. One day it will be done. ![]()
#183 |
More pictures
#184 |
Couple more
#185 |
Still Learning
Your bed wood turned out great! Awesome looking truck
![]() Keep the pictures coming. |
#186 |
Proprietor of Dale's Corner
![]() Join Date: Nov 2012
Looking great
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
#187 |
Good lookin' stuff!!
Boppa's Old Yeller Truck Build, Old Yeller's New Heart! Project Buzz Bomb Flyin' Low! |
#188 |
![]() Join Date: Jul 2009
Bout time you had something to report on the bed.
Rick 78 GMC K15 SWB, 350/NV4500/NP205/4.10s Project Hazel 71 GMC C25 350/TH400 - Project Angie 59 Chevy SWB Stepside (next in line? Not sure now ![]() 2001 GMC Sierra K2500 |
#189 | |
![]() Thank you. I appreciate you stopping in! I know right? I have been really busy (I am sure you know all about that). I didn't paint the left fender because I needed to weld in the fuel filler behind the side marker. Hopefully everything will be painted this week and final assembly will be completed. I might have to come visit real soon.
#190 |
We'd love to have you and your lovely bride over. Might get you to help block sanding - yay, right?
#191 | |
#192 |
Here is an updated video that shows a good overall view of the truck. Enjoy!
https://youtu.be/UA2zSYYP6nQ
#193 | |
Still Learning
![]() I like your fuel filler BTW..... ![]() |
#194 |
Love the color combo!
#195 | |
Thank you. Everyone questioned me in the beginning but it looks great in the sun. Here is a little more info about the side marker fuel filler. I used a '03 Chevy 2500 fuel neck and a 06 Ford "cup" (no idea what the real term is) to attach the neck to the fender. Since I planned on doing this long before I painted the truck I started mocking it up on the fender before body work started. We then got the box for the bed completed abd on the frame so I could mock up the fender and get final placement. We then welded in the "cup" and I attached the filler neck as you see it. Then we took everything apart and painted it. It was a little extra work this way but it is very sturdy and works extremely well.
#196 |
to adjust for the curve on the fuel door arm, on the left side (front) of the side marker I used a long bolt with a phillips head on it so it appears to be a stock screw and the I used three nuts, one just behind the side marker to hold it out the second to get the correct space between the side marker and the fuel door so it would close flush with the fender and the third to hold the side marker to the fuel door.
On the right side I used a shorter bolt, washer and nut to bolt it to the fuel door. I put a slight bend in the fuel door arm which seemed to help the side marker sit flush.
#197 |
Here you can see where the neck bolts into the "cup".
#198 |
Here you can see where I drilled out the right side so that the bolt on the right side of the side marker can recess into the fender. The left side is done the same way.
#199 |
Couple of shots from the back side. I didn't realize until it was too late that my fuel cell abd filler neck were different sizes. The smaller hose has a wall thickness of 1/4" so it is very sturdy which allows me to clamp it together. I looked at all of my local parts stores for what I needed abd couldn't find anything.
#200 |
Couple of picture to show how much my wife loves me
