09-25-2015, 12:42 PM | #1 |
Inner door handle locks but doesn't open.
Title says it all, the passenger door handle locks but doesn't open. It bends the rod trying but feels like it's hitting on something. Took the door panel off to look at the latch but can't see anything that would be interfering with it. Any suggestions all knowing forum members?
Jack Personal Fleet: Family Fleet: 1955.5 Panel 1959 Apache 1968 ShortWide 1969 ShortStep Last edited by 68shortwide; 09-25-2015 at 01:09 PM. |
09-25-2015, 12:58 PM | #2 |
Old member
Re: Inner door handle but doesn't open.
A couple of things to try.
While you push in on the door from the outside try to push in on the outside handle button. Take a long screw driver and pull up on the handle inside the door where your rod connects to the plunger on back of door.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
