Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork
Old 12-25-2015, 12:32 AM   #1
chrismoore701
chrismoore701's Avatar
Air hose size for painting
Title says it all. What size are hose are you guys using for painting? I have 20' of 1/2" black pipe with 2 blow offs and then 50' of 3/8" dia hose with inside diameter of 17/64". Thoughts
Chris
Chris
_______________________________
1979 Chevy Stepside SPORT
2018 Chevy Silverado, 39 years apart
My build 2008-2016. http://m.imgur.com/a/bURrE
chrismoore701 is offline   Reply With Quote
Old 12-25-2015, 12:58 PM   #2
dfwright
dfwright's Avatar
Re: Air hose size for painting
I am using 3/8 hose as well, with the "high flow" quick connects from home depot, which some on this forum had recommended.
1972 C10 LWB, 350/350
Deconstruction began 5/2009, mostly completed restoration, 5/2017
dfwright is offline   Reply With Quote
Old 12-25-2015, 03:56 PM   #3
Foot Stomper
Foot Stomper's Avatar
The 3/8' hose is fine. The length can be a problem. For a dramatic example, imagine a 500' foot 3/8 hose and trying to push or pull air out of it compared to a 2 foot 3/8 hose. The change is dramatic. And as dfwright mentions above, use high flow fittings for all your tools.
To this end, try to use as short a hose a possible for three reasons; 1) more air volume to use at your discretion 2) more air pressure to use at your discretion 3) less hose is far easier to manage while spraying. Coils in excess hose like to uncoil into freshly painted doors, kink up against the back side of a tire and cut off supply plus restrict your air supply.
Background:
While in the warehouse distribution business of body shop supplies in Canada, I learned dealing with USA suppliers/manufacturers that nobody offered a 35' "booth hose" that are almost exclusivity used in Canada. Nobody in Canada uses a 50' air hose in the booth if given the choice to use a 35'. We even went so far as request (from new super flexible hose manufactures) 35' custom hoses from USA suppliers and were asked "Why 35?!?'".... Now you know why too! 25's are too short and 50's are too long. We only sold 35' air hoses for the booth unless it was a truck shop or other large booth requirement. This particular manufacturer found it to be such a good seller, they now list it in their regular catalogue and offer it in the USA. I don't want to advertise for them, but PM me if you really need to know who I am talking about.
So when is this "Old enough to know better" supposed to kick in?
My 1959 GMC build thread http://67-72chevytrucks.com/vboard/s...d.php?t=686989
Foot Stomper is offline   Reply With Quote
Old 12-25-2015, 05:15 PM   #4
chrismoore701
I have 50' hose. Will put on the high flow fittings. Are these both the male connectors and quick disconnect?
Chris
Chris
Old 12-25-2015, 10:47 PM   #5
dfwright
dfwright's Avatar
The ones I got from Home Depot are a set.
High Flow Aluminum Female Quick Coupler and Plug Set
Old 12-25-2015, 10:52 PM   #6
chrismoore701
Thanks. I think this run will have to be strictly for painting. I do not want to change all my air tools over.
Chris
Old 12-26-2015, 03:04 PM   #7
chrismoore701
Just picked them up. Will see what happens. Thanks.
chris
Chris
