01-31-2016, 10:37 AM | #1 |
ZZ502 died while driving. Need help troubleshooting
I was driving down the highway. I had just come off of an onramp where I was in the throttle all the way to merge into traffic. About 2 minutes later the Blazer had one backfire and then the motor shut off. I got it to the side of the road and tried to crank it. The motor turned over just fine but it wouldn't fire up. After a few seconds of turning the motor over it lets out 1 backfire. I had it towed home and I still haven't been able to find out what the problem is.
I have the Aeromotive Stealth intake system and the pump work when the ignition is turned on. The fuel pressure gauge is reading correctly too. I originally thought it might be the coil so I changed it out but it still won't fire up. I think it might be something in the ignition system but, I'm not sure where to start. I pulled the cap off and tried to turn the rotor and it seemed to be ok, meaning I don't think the distributor shaft is broken. Although I'm not sure of anything at this point. Do you guys have any ideas of what it could be or where would be the best place to start? |
01-31-2016, 11:53 AM | #2 |
Re: ZZ502 died while driving. Need help troubleshooting
Check for spark. It sounds like the module died.
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
01-31-2016, 02:04 PM | #3 |
I'm pretty disappointed in myself for not thinking of that. I bet that's it. I just went and bought one. I have to run out but, I'll put the new one on when I get back.
Thanks. |
01-31-2016, 03:01 PM | #4 |
I'd start by checking for spark and checking timing.
1973 C20, 350/350 |
01-31-2016, 03:27 PM | #5 |
Loss of spark sounds most likely to me. What kind of ignition system do you have?
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
02-01-2016, 08:59 PM | #6 |
I have the ZZ502 HEI setup. I replaced the ignition module and it still won't start. I turn the key and it turns the motor over fine and after a few second of turning it backfires really loudly. I am very frustrated with this thing. I would love to have a mulligan.
02-01-2016, 09:26 PM | #7 |
Throwing money at it will get expensive in a hurry. Have you verified that it does or doesn't have spark? I assume this engine is carbureted? What kind of Carb have you verified fuel is actually coming out of the carb?
02-01-2016, 09:27 PM | #8 |
I would pull off the valve covers and check things out while turning the engine over buy hand. Almost sounds like a timing issue, dropped valve etc...
If you don't like this pound sand ..... |
02-02-2016, 09:07 AM | #9 | |
I sure hope that's not the case. |
02-02-2016, 10:14 AM | #10 |
Active Member
Years ago I had a similar symptom on an olds. It turned out to be the cam gear -stripped some teeth.
As mentioned above, first check for spark (if you have a timing light you can clamp it on the spark plug cables to check for a flash). Then check the timing.
68 GMC 250/3 speed Saginaw p/b p/s 69 Chevy 350/350 currently in pieces still lookin for a cab 06 Trailblazer I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive... |
02-02-2016, 10:43 AM | #11 |
Check to make sure it didn't shear the pin in the drive gear also
02-03-2016, 12:25 AM | #12 |
60-66 Nut
Are you seeing fuel without moving the throttle?
02-03-2016, 12:35 AM | #13 |
Are you thinking too much fuel pressure over powering the needle and seat? like stated earlier pull the valve covers, my 502 ate a valve while driving also.
At my worst I'm at my best |
02-03-2016, 01:01 AM | #14 |
60-66 Nut
That or a piece of dirt got between the needle and seat?
I'm not saying it couldn't be something serious, but I typically check the easy/simple stuff first....... like fuel and spark
02-03-2016, 08:24 AM | #15 |
No. I worded that poorly.
My fuel pressure is 5.5 and 6. |
02-03-2016, 09:58 AM | #16 | |
Senior Car Nut
always do the easy checks first. no sense pulling valve covers (or other parts) 'til you need to. I'd bring the engine to TDC #1 (compression stroke, finger on the hole method) and see if the rotor is pointing at the right place on the cap if that looks okay, pull all the plugs and dry them and spin the motor over to clear the cylinders of any raw gas. when you're ready to restart, give it a couple of pumps but don't keep pumping if it doesn't fire right up
Larry |
02-03-2016, 09:58 AM | #17 |
7.5# is optimum fuel pressure. Good luck man
02-03-2016, 11:58 AM | #18 |
I think electrical also. Check the rotor from the bottom to see if it has carbon tracking or a burn-thru, check the coil button in the top of the cap also.
Tim K. 84 K30 srw Silverado 454 auto 85 C20 350 C6P auto flatbed 94 K1500 lifted shortbed 350 4 bbl NV4500 |
02-03-2016, 06:52 PM | #19 |
There was carbon on the bottom side of the rotor. What does that indicate?
02-03-2016, 09:21 PM | #20 |
Carbon tracking. Basically the rotor is worn out. The cap is likely in the same shape. With the distributor cap off of the distributor crank the engine and make sure the distributor is actually spinning. You need to start at basics and go from there. We can sit here and guess all day but without physically checking things one by one its hard to nail it down. Basically we have to do process of elimination to get you back on the road.
02-04-2016, 03:08 PM | #21 |
*** That's interesting ***
Folks already gave good advice. But after you pulled the cap, did you verify that the rotor is spinning and is not loose? I had the exact same thing happen once. Screws broke off on the rotor (very strange), so the rotor was just laying on the metal plate with the plate spinning underneath it when cranking the engine. At first glance, it seemed fine until I could lift the rotor right off! There was also quite a bit of plastic shavings underneath like the screws backed out slowly and then just sheered. After replacing the rotor, I was back on the road. The symptoms were the same. I'd crank it and eventually get a backfire because the rotor was in the right position for one cylinder with each revolution, and that would ignite the built up fuel in one cylinder and then in the exhaust. Good luck. Keep us posted. Try some starting fluid to eliminate fuel delivery.
Tom Chevy by day... 1969 Chevy C30 Rollback Tow Truck -- 383 stroker, 4L80E 2011 Chevy Caprice PPV 9C3 6.0L 1995 Chevy Caprice 9C1 1994 Chevy Caprice 9C1 #3 1995 Chevy Caprice Wagon #2 1995 Chevy Impala SS Mopar by night... 1969 Dodge Charger 1972 Chrysler Newport 2dr Hardtop (27K miles) Plus others... |
02-06-2016, 01:26 AM | #22 |
All engines need 2 things to run, fuel and spark. Then proper amount of fuel, and correct timing.
Get a good book on engine mechanics on diagnosis. We all look for easy fixes at first. Proper diagnosis, then replace parts with money. Buddy just spent 500 bucks on a carb for an old 4 wheeler. Did not run correctly after that. Bought the fuel petcock did not run better. I actually forced him to ride with me to NAPA to buy a fuel filter. 2 bucks later at that point I was beating him around the track on a 20 year 350 Wolverine, He was on a 2014 700 Grizzly. I learned something from him. At his expense. The only work I did was the fuel filter. Shortcuts almost never work. Spray some ether in the carb and see if it runs. I do not think that 2 buck can of ether will hurt while you are picking up a manual on that motor. |
02-06-2016, 01:51 AM | #23 |
I built it
how recently had you fueled up? i got a tank of gas that had quite a bit of water in it. truck ran for maybe 5 miles and then had to get towed. opened up the carb and there were between nickel and quarter sized water "pockets" in both fuel bowls (edelbrock carb at time) after i got everything cleaned out it fired up fine. maybe something to check.
'72 k10 lwb 454, th400, 205, d44ft, 12b rear, 4in skyjacker, 35x12.5-15 superswampers, 4.56, blazer tank. painless wiring harness '98 dodge 3500 12v 5sp 4x4. the truck that actually runs |
02-06-2016, 11:54 PM | #24 |
Fabricate till you "puke"
Loads of good info here....just 1 more thought? I have not seen this so much in the chevs, but did see a 460 Ford, shear the roll pin on the dist gear. Maybe pull the dist, & take a look? Longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
02-23-2016, 09:00 PM | #25 |
So far, I know part of the problem was the distributor gear. I will find out tomorrow if it trashed the cam gear too. /sigh
