Old 01-28-2017, 10:42 PM   #1
michael bustamante
michael bustamante's Avatar
wrangler tank mount question
when mounting the tank in the 67 short stepper, is it better to drop in since i have the bed off or mount from underneath?. im worried about clearance issues for the filler and the sender unit.
Edit! More questions and pics below!!!
Thanks in advance!
1967custom
michael bustamante is offline   Reply With Quote
Old 01-28-2017, 11:27 PM   #2
mongocanfly
mongocanfly's Avatar
Re: wrangler tank mount question
It would be much much easier to install from the top with the bed off..unless you have measured prior to pulling the bed it would mak it a little harder...I would set the bed on and mock up the tank where it needs to sit and take a bunch of measurements..pull bed and then fab mounts and install..
Old 01-29-2017, 04:11 PM   #3
michael bustamante
Measure measure measure....lol. Ok thank you
1967custom
Old 01-30-2017, 02:58 PM   #4
Green67Stepper
Green67Stepper's Avatar
hurry up and figure this out so i don't have too. hahah... my goal for next week is to get my tank mounted. are you doing to use the factory wrangler straps?
Green67Stepper is offline   Reply With Quote
Old 02-01-2017, 01:50 PM   #5
michael bustamante
no i dont have them, ill make some out of sheet metal
1967custom
Old 03-07-2017, 09:45 PM   #6
michael bustamante
update.
ok now shes in, strapped up and lookiooing good. i decided to go from underneath instead of doppping in from the top and it worked well. gettng ready to put the bed on now.
question. do i only need to trim the crossrail to clear the fuel sender or trim the rail to clear the whole top of the tank?
1967custom
Old 03-08-2017, 08:41 PM   #7
michael bustamante
Ok did i do something wrong here? It looks like ill have to completley cut the drossmember instead of just trimming to lay the bed back on the frame. Suggestions?
1967custom
Old 03-09-2017, 03:47 AM   #8
compsystems
on my install I had to cut a section out of the bed support to clear the top of the tank.
compsystems is offline   Reply With Quote
Old 03-09-2017, 01:39 PM   #9
michael bustamante
anybody have pics of their crossmember cutouts? should i lower my tank a little?
will cutting the crossmember the width of the tank compromise its strength and if so how did yall reinforce it?
1967custom
