Old 04-26-2017, 04:18 PM   #1
YOLO
Custom Truck Lover!
YOLO's Avatar
How to install bed kit by yourself!
I tried to come up with a way to install the bed strips by myself. Here is what I did.
Name:  2017-04-26 09.17.00.jpg
Name:  2017-04-26 09.07.11.jpg
I used a 30 lb weight to hold the bolt down from the bed side. On the bottom I used sticky rubber to hold the lock washer on the nut while sitting in the socket. Do what you got to do. It worked and made the job much easier.
Squarebody guy
YOLO is offline   Reply With Quote
Old 04-26-2017, 04:49 PM   #2
MR Cos
Re: How to install bed kit by yourself!
nice work!
MR Cos is offline   Reply With Quote
Old 04-26-2017, 05:46 PM   #3
jayoldschool
Moderator
Yep, I did the same tricks. Had to weight down the bolts with bricks. Having cardboard on the driveway considerably sped up the top to bottom transfer. Using a cordless impact was essential.
jayoldschool is online now   Reply With Quote
Old 04-26-2017, 07:48 PM   #4
YOLO
Custom Truck Lover!
YOLO's Avatar
Looks great!
Squarebody guy
Old 04-26-2017, 08:13 PM   #5
jayoldschool
Moderator
I forgot to say that I used two or three nuts in the socket so the first one would grab (instead of your sticky trick).
Old 04-26-2017, 09:41 PM   #6
YOLO
Custom Truck Lover!
YOLO's Avatar
I did that a couple times out of necessity. My dumb self got two nuts on the bolt and made more work. I used the sticky stuff to hold the lock washer on the nut so I could reach up with one arm. The truck is lowered and I did not put it on jack stands. That probably would have made the install easier too.
Squarebody guy
Old 04-26-2017, 11:00 PM   #7
rvrfoot
Yep i need to do that next.Name:  DSCN0755.jpg
rvrfoot is offline   Reply With Quote
Old 04-27-2017, 08:28 AM   #8
jbgroby
jbgroby's Avatar
You can also use your grand kids to hold the bolts down, cheap labor cost - you pay them in Ice cream.
jbgroby is offline   Reply With Quote
Old 04-27-2017, 10:23 AM   #9
YOLO
Custom Truck Lover!
YOLO's Avatar
Even better idea! That bed looks great. Very classy
Squarebody guy
Old 04-27-2017, 10:26 AM   #10
YOLO
Custom Truck Lover!
YOLO's Avatar
Originally Posted by rvrfoot View Post
Yep i need to do that next.Attachment 1646348
Nice hinges and great color
Squarebody guy
Old 04-27-2017, 10:31 AM   #11
midnight rambler
midnight rambler's Avatar
nice tips I just ordered new stainless for mine.
midnight rambler is offline   Reply With Quote
Old 04-27-2017, 12:24 PM   #12
jbgroby
jbgroby's Avatar
Thank You, been a LONG 10 years
Old 04-27-2017, 10:43 PM   #13
YOLO
Custom Truck Lover!
YOLO's Avatar
If you are using stainless or chrome strips remember to put something soft between the weight and bed strips. I did not have worry about scratching my bed!
Squarebody guy
Old 04-28-2017, 04:01 PM   #14
forestb
forestb's Avatar
I was using a weight but then I started using tape instead. You can hold down all the bolts at once that way. Also if you start from the sides and lay the boards in one at a time you can just reach around, except for the last 3 boards. I also found that on the cross sills that are more shallow (I have short fat fingers) I could hold the bolt in place with one finger and put the nut on with the other hand. I put a little dab of grease on the washer to hold it onto the bolt and placed a ball of duct tape inside the socket to keep the nut from falling to far into the socket.
forestb is offline   Reply With Quote
Old 04-28-2017, 04:31 PM   #15
rvrfoot
Nice job.
Old 04-28-2017, 11:19 PM   #16
YOLO
Custom Truck Lover!
YOLO's Avatar
Name:  2017-04-28 14.25.45.jpg
Mounted the tool box today. I need to get the truck on jack stands to get the last few bolts through the bed strips.
Squarebody guy
Old 04-29-2017, 01:10 PM   #17
canadian_diesel1964
Must be a fireman thing...IAFF 142 here...brother! Just a micro buck parts getter
canadian_diesel1964 is offline   Reply With Quote
Old 04-29-2017, 02:44 PM   #18
YOLO
Custom Truck Lover!
YOLO's Avatar
Looks like a good start to me. Be safe!
Squarebody guy
