07-22-2017, 01:51 PM | #1 |
WTB 14 Bolt Semi Float Differential
Looking for a 14bsf out of an '81-'87 4x4 3/4 ton, preferably with 3.42 gears and 11 inch brakes. Bonus if its out of a 4 speed truck so I can also get the driveshaft.
Please let me know what you have. Thanks, Danny
1957 Chevy 3200 1971 Jeep CJ-5 Renegade II 1983 Chevy K/10 Silverado 1985 Jeep CJ-8 Scrambler Last edited by AtomicYJ; 07-22-2017 at 01:53 PM. Reason: Spelling |
08-14-2017, 02:05 AM | #2 |
Re: WTB 14 Bolt Semi Float Differential
I have what you are looking for the only difference is mine is a full floater and a posi. The gears and brakes you want no drive shaft, came out of 91 suburban.
"I pawned my Hanso" "Hold my beer, Watch this" |
08-14-2017, 01:20 PM | #3 |
With the 10.5" ring gear? I'm looking for the 9.5" ring gear differential as I'm trying to upgrade my 1/2 ton and keep 6 lug wheels.
1957 Chevy 3200 1971 Jeep CJ-5 Renegade II 1983 Chevy K/10 Silverado 1985 Jeep CJ-8 Scrambler |
09-11-2017, 02:13 AM | #4 |
Are you still looking for this rear differential? I might have one. Have to pull the cover and check the ratio and check the brakes. It came out of an 86 GMC 2x4. Thanks, Ken
09-28-2017, 11:51 PM | #5 | |
Sorry for taking so long to get back to you, I'm in the middle of moving to GA.. I've already found one. Thank you though, Danny
09-29-2017, 12:56 AM | #6 |
OK, glad to hear it. Shipping would have been a monster on that anyway. BTW, did I understand your post to say you can put six lug axles in this rear end? Thanks, Ken
09-29-2017, 02:52 PM | #7 |
It's my understanding that there are two ways to get a 6 lug semi floater. Re drill the shafts and drums on an 8 lug to 6 for a squarebody housing which is what I intend to do. Or find a 6 lug version out of a GMT400 truck and move the spring perches and shock mounts. Since I can't weld I figured it would be easier to get a squarebody housing and take the drums and shafts out and have a machine shop re drill them for me.
Thanks, Danny
09-29-2017, 03:12 PM | #8 |
OK Dan, Thanks for the clarification.Ken
09-29-2017, 04:45 PM | #9 |
I have a semi float 14 bolt 4.10 13" brakes in Spokane Washington
10-05-2017, 09:52 AM | #10 |
Why would you expect this 3/4 axle to have the 14BSF (9.5" ring gear) 6-lug (you may be right, I'm not sure)? There are some other places to be looking for a 6-lug 14BSF. If you want a 6-lug, look at the 88-98 GM-1500s with a GVWR of 6,600. It's important to know whether it's a 2wd (65" WMS-WMS) or 4wd (70" WMS-WMS), because the widths are different. Also, starting in 2004, you could get the 6-lug, 14BSF in the Vortec Max 1500. I'm not sure what the width is on those. You might need a conversion u-joint for the driveshaft. Curious enough, there was actually a 5-lug 14BSF in the 454 SS trucks built between 1990-93. Anecdotally, there may be some 6-lug 14BSF in the mid-90s 2500 vans.
11-25-2017, 02:42 PM | #11 |
Here's some axles:
https://lansing.craigslist.org/for/d...399412056.html |
Tags |
14bsf, 4x4, differential |
