Old 10-17-2017, 04:30 PM   #1
6768chevylover
6768chevylover's Avatar
engine smoking
If my 383 engine is smoking on acceleration and deceleration, does that mean the piston rings are shot or is it still a possibility that the valve seals are shot pretty bad? I've always heard if it smokes on acceleration its the rings and on deceleration its the valve seals. Then again is that a true fact? Compression test was done a that was fine but was thinking the oil rings are shot..
6768chevylover is offline   Reply With Quote
Old 10-17-2017, 04:59 PM   #2
68gmsee
Active Member
68gmsee's Avatar
Re: engine smoking
Could be both. Most of the time when I've had valve stem seals go bad, the engine will smoke on startup after sitting for a period of time like overnight. It's not always the case though but they are the easiest to check and/or replace. The last engine I was working on the seals were so bad they crumbled when I removed them for replacing. They were hard and brittle.
You could also try some of the oil additives to see if it can loosen the oil rings if you suspect they are causing some of smoke.
68 GMC 250/3 speed Saginaw p/b p/s
69 Chevy 350/350 currently in pieces still lookin for a cab
06 Trailblazer
I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive...
68gmsee is offline   Reply With Quote
Old 10-18-2017, 07:47 AM   #3
GRX
GRX's Avatar
Re: engine smoking
My instinct says rings. Oil being sucked past eight 0.3438" valve stems is insignificant compared to eight 4.000" rings.
Smoking when letting off the accelerator while going down hill with truck in gear is classic sign of rings since you are essentially creating a high vacuum situation in the cylinders.
Using a bore scope to observe carbon wash patterns on the pistons would be very helpful here.
1969 c-10 Step Side Long Bed. I-6 250cid = = 1969 Pontiac GTO hard top. 400, 4-speed.
GRX is offline   Reply With Quote
Old 10-18-2017, 02:49 PM   #4
Coley
Coley's Avatar
Re: engine smoking
noting that everything wears out....how many miles are on the motor?
Was it a pro-build?...crate or?
Coley
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL
1966 Chevy 1/2 ton (Florida- Red/white)
1972 Chevy 1/2 ton (California- Blue/white)
2005 Chevy Silverado HD2500/Duramax
2000 Dodge Ram 1500
Coley is offline   Reply With Quote
Old 10-18-2017, 02:59 PM   #5
Alex V.
Alex V.'s Avatar
Re: engine smoking
Smoke most of the time, heavier under load pretty much means rings.
Alex V.
1967 C10 Suburban, 350/NP435, Green/Green, PS, PB, HD cooling, charging, shocks, and springs.
1985 GMC C3500 SRW, Sierra Classic, 454/TH400, white/blue.
Alex V. is offline   Reply With Quote
Old 10-19-2017, 12:21 PM   #6
6768chevylover
Re: engine smoking
its got about 35000 mile on it. it was pro-built engine when I first got it years ago. smokes more when let of the pedal. but smokes a little bit on acceleration. When I say a little bit, it smokes but not a fog left behind me.
Old 10-19-2017, 05:17 PM   #7
mattfranklin
mattfranklin's Avatar
Re: engine smoking
That's not a lot of miles for a smoking problem. Most motors are just getting properly broken in at that point.
So it was good and didn't smoke at all when you first got it, but now is starting to smoke? I'm assuming it's gray/blue oil smoke, and not steam or carbon.
Was there one event that made it suddenly start smoking a lot more, or was it gradual over the years?
(Very) Slow-Going Build Thread: Stock 1970 Short Step with Stock 1970 LT-1
http://67-72chevytrucks.com/vboard/s...d.php?t=567340
mattfranklin is offline   Reply With Quote
Old 10-19-2017, 06:47 PM   #8
WorkinLonghorn
WorkinLonghorn's Avatar
Re: engine smoking
Sounds like both but I would pop a valve cover off and look. Poke a few to see if they are hard. It's really easy to replace these. Check the guides too while you're in there. -BA
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, 2nd owner, Work-Truck supreme. Best $300 I ever spent.
WorkinLonghorn is offline   Reply With Quote
Old 10-20-2017, 09:11 AM   #9
6768chevylover
Re: engine smoking
Its definitely blue/gray smoke. I had a bad over heat one day forgetting to click my fans on sitting in a parking lot b.sing . That was alittle over a yr ago. Its been gradually getting worse since then I guess. I'm starting to think you guys are right and that the rings are shot. I was hoping it wasn't that..
Old 10-20-2017, 09:12 AM   #10
6768chevylover
Re: engine smoking
anyone know a ball park on a rering job?
Old 10-21-2017, 12:03 PM   #11
mattfranklin
Re: engine smoking
I just saw your location. Hopefully you’re all ok there in Napa. We could smell the fires way down in Richmond.
I thought this video on overheating and piston failure was interesting. My guess is that yours are probably not as bad as the ones shown because the failure was at idle rather than at WOT.
https://m.youtube.com/watch?v=aCr9iltAx2w
Could it be valve seals only? Small probability. Less than 5% based on the event that triggered the smoking. There are methods to change the valve stem seals with the heads staying on. I have not done that myself, but it looks easier than changing pistons. If you do it yourself it might be a good decision. But if you have to pay to have it done then the cost and risk trade off leans toward pistons. Depends on if you want to do it yourself or how tight your time is.
If I had lots of time and mechanical ability, I’d try the valve stem seals first, knowing it’s more likely the pistons, but hoping for an easy fix. If that didn’t do it then I’d dig deeper and pull a few pistons.
Old 10-22-2017, 10:22 AM   #12
68gmsee
Active Member
68gmsee's Avatar
Re: engine smoking
Originally Posted by mattfranklin View Post
.....If I had lots of time and mechanical ability, I’d try the valve stem seals first, knowing it’s more likely the pistons, but hoping for an easy fix. If that didn’t do it then I’d dig deeper and pull a few pistons.
^ Agree. It's cheapest and fairly easy to do if a person has the necessary tools: small air compressor and spark plug adapter (auto parts part), valve spring compressor, small mechanics magnet. Took me a few hours in my front yard to do.
However, I will say this is a temporary fix to minimize oil burning. For an engine that's high mileage, tired and worn down it's best to rebuild the whole engine and be done with it.
06 Trailblazer
Old 10-22-2017, 02:15 PM   #13
AcampoDave
AcampoDave's Avatar
Re: engine smoking
My engine developed a smoking habit when the intake gasket went bad. I thought it was something more serious and was just beginning to tear things down when I discovered the gaskets just soaked with oil. May not be the case with you but hopefully so, because it was easy and cheap to fix.
AcampoDave is offline   Reply With Quote
Old 10-22-2017, 09:13 PM   #14
70K10Hunter
70K10Hunter's Avatar
Re: engine smoking
you can get a rering kit from summit for like $120 for a SBC. It will come with the cheap o-ring valve seals but just buy the umbrella style extra.
70K10Hunter is offline   Reply With Quote
Old 10-23-2017, 09:31 AM   #15
6768chevylover
Re: engine smoking
I might put that into consideration for the valve seals and try it. also for the intake gasket. To add to my issue, I noticed that I am losing about 3/4 of a pint of oil every 60 miles. 30 each way for work for me..
Old 10-23-2017, 10:02 AM   #16
GRX
GRX's Avatar
Re: engine smoking
3/4 of a pint = 12 ounces. Not good but have seen much worse.
When buying valve seals consider type. Factory style o-rings will do nothing if the stock sheet metal oil shields around the springs have been removed. Being a 383 good chance the heads have been reconditioned, or after markets installed. Hopefully they can accommodate positive valve seals that fit tightly on the guides and do not move up and down. Viton are best material here.
Umbrellas, which ride with the valve stem, and not as desirable as positive seals, are another distinct possibility. When going that route be sure their size allows them fit inside the springs without interference.
Hope that helps.
Old 10-23-2017, 10:40 PM   #17
70K10Hunter
Re: engine smoking
The umbrella style valve seals that I'm talking about are the ones that are held to the valve guide with a steel split ring and DO NOT ride on the valve stem, they are a tight seal around the valve stem and do not move. sorry I'm old school with some of my terminology.
