12-22-2017, 08:26 PM | #1 |
64-66 chevy exhaust infront of tires
I am thinking about running my exhaust out infront of the rear tires. Anyone done this and I need pictures.
http://67-72chevytrucks.com/vboard/s...d.php?t=548705 |
12-22-2017, 08:38 PM | #2 |
One foot in front of the other
Re: 64-66 chevy exhaust infront of tires
I used Camaro tips. Brockman Mellowtone mufflers
12-22-2017, 09:12 PM | #3 |
It's Better With Nitro
I had to run my exhaust to the outside of the frame, so I routed the downpipe under the rise in the front of the frame and did a turn out off of the muffler in front of the rear tire. Here are a couple of photos while I was fabricating the passenger side.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes |
12-22-2017, 09:39 PM | #4 |
Mine are also infront of the tires. no mufflers just straight pipes baby? Will try to send pics tomorrow.
12-22-2017, 10:12 PM | #5 |
My exhaust is routed exactly like vin63's. It works very well this way and there is tons of room.
12-22-2017, 10:38 PM | #6 |
I too did mine like Vin63 and it did sound good, but ultimately it proved to be too loud for long distance driving. I recently added tailpipes over the axle and straight down which was just enough to quiet it down to where I wanted.
But you know wnat they say, "if it's too loud your too old." I guess I am guilty as charged. |
12-25-2017, 10:33 PM | #7 |
Very happy with this setup.
12-26-2017, 10:00 PM | #8 |
Thanks for the pictures. The last truck is the same color as mine. As for being loud that will be fine with me. I am wanting a hot rod look and sound with this truck. Check out my build thread
12-27-2017, 01:53 PM | #9 |
racecougar the stance on your truck is BadAss! With those tires & pipes hanging out the side of a SWB truck it looks like one of those Ed Roth Cartoons from the '60s!
Well Done! |
12-27-2017, 04:26 PM | #10 |
Thanks!
12-27-2017, 05:18 PM | #11 |
mine but its a 62
12-27-2017, 08:33 PM | #12 |
Right on about the wide tires and stance. I really like the red one as well as the 62. There are not many of these trucks I dont like. Here is the one I am building now
12-27-2017, 08:34 PM | #13 |
12-27-2017, 08:37 PM | #14 |
Oh well I cant get the stupid picture to work. It is under 60-66 build title says rolled 65 project
12-28-2017, 12:25 AM | #15 |
Does this og pic count?
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
05-31-2021, 01:02 AM | #16 |
But Found Her 25yrs Later!
Anyone have sound issues having their exhaust routed this way?
I'm wanting to move my tank to the rear but I don't like how close the pipes would be to the tank.
05-31-2021, 02:00 AM | #17 |
I had the mufflers under the cab on my 66 and the resonation was horrible at 2000 rpm. Had no sound deadener but I don't think it would have helped much. Assuming you may not have enough room to put them behind the cab and still have the pipes route in front of the tires.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
05-31-2021, 09:36 AM | #18 |
Yeah, It's louder for sure and if your a windows down kind of guy, you hear the sound of half your engine being deflected off of buildings and curbs. I still have a long bed with front of tire outlets on 2 inch pipe, but I personally dont care to hear much from my exhaust at all so I added resonators to my stock style mufflers which helps. On my shortbed I just got sick of it and lopped the pipes off under the cab and re-did the whole thing all the way out the back with 2.25" putting the mufflers under the bed and resonators fore and aft. The tailpipes and rearward resonators run right next to my rear mounted tank and I have run the truck very hard on very hot days and never found the tank too hot to touch.
05-31-2021, 09:59 AM | #19 |
This isn’t in front of the tires, but when you go over the differential, you will be going to outside of your frame and most rear tanks are between the frame rails. I will finish with my outlets in back of the tires after getting over my soon to be built new differential...plenty of room between tank and exhaust
05-31-2021, 02:52 PM | #20 |
Here's a pic of how close mine are. You'll notice I had to rotate the resonators slightly off center to get a bit more breathing room. (Remember, the flanges on the tank sides stick out a good bit from the tank wall so at least the fuel itself is further in). Those rearward resonators were an afterthought so I was just happy they fit there at all.
05-31-2021, 05:09 PM | #21 |
Thanks guys.
05-31-2021, 08:19 PM | #22 | |
05-31-2021, 09:11 PM | #23 |
This is how I have mine set but I haven't ran the pipe yet.
1964 GMC Fleetside SWB 1966 Mustang Coupe 2013 Tahoe LT |
