Old 01-11-2018, 11:24 PM   #26
EJC78
No Life Like Low Life
EJC78's Avatar
Re: Soap on a Rope
Wow you sure have your work cut out for a while. FOLLOWING
Eric
1978 Chevy Scottsdale
1960 Impala ZZ4
1965 Buick Riviera GS
2011 GMC Sierra Denali
EJC78 is offline   Reply With Quote
Old 01-12-2018, 05:16 PM   #27
lunatic1968
Re: Soap on a Rope
Yeah, lots of boxes, took three trips to the recycle center.
Something I didn't do was check the frame for square.... Guess what, dropped the soap again. Been hit drivers side. And out of square. Spent the day going through Craigslist looking for a replacement. Have two good prospects. Might buy both. But I have to wait till tomorrow. IM not in a patient mood.
lunatic1968 is offline   Reply With Quote
Old 01-12-2018, 05:25 PM   #28
lunatic1968
Re: Soap on a Rope
EJC78- thanks man.
Today I did have fun though. Despite the bent frame rail. I ordered wheels, fuel tank, gauges, brake kit, new axle, and radiator. All at once with the help from Travis And Nick at Pro Performance. Couldn't of been any easier. Definitely some cool guys who know what they sell.
Old 01-16-2018, 04:17 PM   #29
lunatic1968
Re: Soap on a Rope
So I seem to be doing the c10 two step. But I found a new frame for a hundred bucks but it has some small issues. Nothing I can’t fix but I’m ready to move forward. I’ve got a couple more rivets left and I’ll be ready for powder coating.
As you can see when I drilled the drivers side frame it sprung big time. One rivet was already sheared. So that one is going to scrap.
Found a new 3/4 ton frame but I had to winch it out of a field. Luckily the parts I need are in good shape.
Old 01-16-2018, 04:18 PM   #30
lunatic1968
Re: Soap on a Rope
New frame from the field
Old 01-16-2018, 04:20 PM   #31
lunatic1968
Re: Soap on a Rope
Cut up...
Old 01-17-2018, 11:32 AM   #32
lunatic1968
Re: Soap on a Rope
A little more work done last night
Old 01-17-2018, 11:34 AM   #33
lunatic1968
Re: Soap on a Rope
More...
Old 01-17-2018, 11:37 AM   #34
lunatic1968
Re: Soap on a Rope
Little more
Old 01-17-2018, 11:47 AM   #35
lunatic1968
Re: Soap on a Rope
Found a crack where the steering gear bolts up. I’ll grind it out and weld it up. I’ll mock it up today then it’s ready for some powder coating.
Old 01-31-2018, 02:38 AM   #36
LT7A
Re: Soap on a Rope
Cool build. If that crack is at where the steering box mounts, you may want to look into a kit such as offered by ORD. That frame'll probably be plenty strong, but since you are powder coating, you may want to take steps to keep it from recurring.
http://www.offroaddesign.com/catalog/steeringkit.htm
Old 02-01-2018, 06:04 PM   #37
lunatic1968
Re: Soap on a Rope
Yeah, that’s the place. Pretty common place too. It was ground out and welded up. And I’m using rack and pinion so there will not have any more stress there.
Old 02-21-2018, 09:45 PM   #38
lunatic1968
Re: Soap on a Rope
Update, more boxes and some progress.
Old 02-21-2018, 09:52 PM   #39
lunatic1968
Re: Soap on a Rope
More photos
Old 02-21-2018, 10:04 PM   #40
lunatic1968
Re: Soap on a Rope
Again with the sideways photos! How do I fix that ?
Old 02-22-2018, 10:13 AM   #41
lunatic1968
Re: Soap on a Rope
More parts!
Old 02-22-2018, 10:16 AM   #42
lunatic1968
Re: Soap on a Rope
Little progress...
Old 02-22-2018, 10:19 AM   #43
lunatic1968
Re: Soap on a Rope
Front end coming along.
Old 02-22-2018, 12:11 PM   #44
lunatic1968
Re: Soap on a Rope
Progress
Old 02-22-2018, 12:16 PM   #45
lunatic1968
Re: Soap on a Rope
Big ol booty
Old 02-22-2018, 12:21 PM   #46
lunatic1968
Re: Soap on a Rope
Rolling right along. Very easy kit for sure.
Old 02-22-2018, 12:25 PM   #47
lunatic1968
Re: Soap on a Rope
Front tires. To match the rear.
Old 02-22-2018, 12:27 PM   #48
lunatic1968
Re: Soap on a Rope
Four link mocked up
Old 02-22-2018, 12:46 PM   #49
lunatic1968
Re: Soap on a Rope
Mock up, and making template for frame “close out panel” to hide some of the lines,hoses, and cables. It will be removable.
Old 02-22-2018, 12:51 PM   #50
lunatic1968
Re: Soap on a Rope
Top view
