Halo headlights in the truck
I put APC halo headlights in the wagon. The halos are xenon and look good at dusk and at night (but you need full headlights at night, so...). The halogens are sealed capsules and look stock and yet provide great light.
I wanted to do halos in the truck but I want to use the halos as DTRLs and the APC xenons just aren't visible in bright daylight. So, I found a Delta light that has a ring of bright COB LEDs as the halo. They are supposed to be really bright halos. The headlights are replaceable H4 halogen bulbs. They are quite a bit more expensive than the APCs but I wanted bright halos so I thought I'd try the Deltas. While the APC lamps are all glass, the Deltas have a glass lens and a plastic reflector back. Not a big deal. The Deltas have a domed lens so look basically stock when off. The fit was pretty easy but I did have to slightly modify the buckets to clear the large rubber seal they use to seal the H4s to the housing. The Deltas come much more ready to install with a premade harness containing the transformers, a ground wire and a hot lead. They can be wired in any number of ways but I chose to wire them into an ignition-on feed so they power on any time the ignition switch is on. I wired in a small hidden rocker switch so I can turn them off altogether if I so desire. The rim where the lens is joined to the reflector is thinner than on stock sealed capsules, so I had to add a ring of hanger wire to the inside of the headlight rings so the rings will hold the capsules snug to the buckets. Again, not a big deal. I did find that the halos are much brighter, they provide a very pleasing white-blue glow even in bright daylight. The headlights are very clear and precise with a very clear upper cutoff on the low beam light so hopefully I won't get flashed by oncoming traffic anymore. The high beams are very powerful. The pictures are in order; halos only, halos and headlights (low beams) and headlights only (low beams).
1965 Malibu SS L79 Restoration Page 1965 Two-Door Wagon Project Progress Page 2006 Pontiac GTO Preservation Project Rich Cummings |
![]() Join Date: Nov 2006
Re: Halo headlights in the truck
Looks kiddie bud imo
I BELIEVE IN JOHN 3:16 |
Uh, yeah, thanks for all the great input.
![]() I'm just glad to have DTRLs that really show up. Anything that can be done to help those texting drivers notice my vehicle and not pull out in front of me is a bonus in my book.
no offence intended. guess I,am just a pureist.
Looks way cool Rich.
No offense taken.
To each their own. I have bone stock restored cars and hot rods, they are all fun and enjoyable. On the halos, it really wasn't about looks (though I like the looks) I just really wanted some kind of DTRL and these fit the bill with a little extra flair for flavor.
I think They look pretty cool on your truck man ! I like how u were able to get them to function as drls ... good write up thanks ����
M.A.G.A. ![]() Last edited by Mollzyie; 06-19-2018 at 11:50 PM. |
![]() Join Date: Feb 2004
Well crap! I guess mine are kiddy too!🤨
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride! ........................ ___ .........________//__{\_____ ,,,,,,,/__(⊙)___//___/__(O)_/ @disciple2.rc 💪instagram💪 LED TAILS |
OP, first time I've seen this on our trucks! Good on you for putting it out there and owning it, yes sir.
I'm thinking that I kinda like it... the halo that is when it is just by itself. The lights look great! Very cool. -klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
The Halo's look Great! Very nice
Old member
I didn't get the halo's. I got the park & turn signals in the bottom.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
#12 | |
I like the fog lights!
#13 | |
Old member
![]() Quote:
Same here.
#15 |
Nice job guys, I like the idea and the look of the Halo lights.
Dave
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
#16 |
I've been wondering how those looked on our trucks. Been wanting to put DTRL on mine when I get to that point.
I got a set of LED H4 bulbs off of ebay while back for a different vehicle and really like how bright they are at night. Ebay item number is 263350848213, if anyone is interested in LED's.
1967 Chevy C20 to K20 Conversion "Simply Toxic" http://67-72chevytrucks.com/vboard/s...d.php?t=749409 1971 Chevy C20 Custom Camper LS Swap http://67-72chevytrucks.com/vboard/s...d.php?t=763775 |
