![]() Join Date: Mar 2018
Replacing the flexplate on a 350 1972 what else should I do while I'm there
Title says it all I figure if I have it open maybe it would be good idea to replace the rear main seal. Engine is leaking oil I'm not sure from where I thought about just wiping the whole thing down so I can identify where it's leaking from. it's an inexpensive part and with the transmission out should be able to see get it done easily, even if it's not leaking just to have it be one less thing to worry about. I'll probably regret saying that last part LOL
Re: Replacing the flexplate on a 350 1972 what else should I do while I'm there
Well you would have to take the oil pan, oil pump, and rear main cap off to change the seal. Are you up for that too?
I'm up for whatever has to get done. I've been reading up on how to diagnose that the rear main seal is the problem and if it's not leaking there I'll leave it alone but there is no pointing putting a flexplate back on until I dealt with that.
I replaced the flexplate on my truck back in May. Not sure what your plan is, but I was able to replace the trans bolts with 6"-8" bolts, and move the trans back just far enough to get a socket between the torque converter and flex plate. It makes it a little bit easier as you don't need to remove the trans from the truck.
1970 C20 Custom Camper - 350, TH350 1997 GMC Suburban 1994 Acura Integra GSR 1987 Dodge Daytona Shelby Z |
#5 | |
#6 | |
![]() Join Date: Jan 2001
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
