09-19-2018, 06:10 PM | #376 |
A guy with a truck
Re: Buried to Bagged 1972 2wd
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
09-19-2018, 07:20 PM | #377 |
Dash is very cool. Going ultra retro. Maybe you said but what's that out if?
72 3/4 ton blazer. 5 inch lift on 35 inch tires. 355 corvette engine with crane roller rockers, rv cam, edelbrock carb and intake with one inch spacer. Thrush Headers with flowmaster 40 duels. 4speed sm465 manual. 4 wheel disk brakes with Inboarded rear shock prerunner style mounts and shocks. |
09-26-2018, 01:49 PM | #378 |
Sofa King Crazy!!
Thank you, it is out of a 1955 Bel Air. Had to be stretched 9.5 inches, but it fits.
You found the Tater. My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650 My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650 67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS. 1972 2wd Blazer "Porterbuilt and Sloshed" |
09-27-2018, 07:08 PM | #379 |
Ok thx. I thought it looked like a 50s dash. Very cool
09-28-2018, 10:12 AM | #380 |
Looking killer!
I know you are running 22x8.5 & 22x12's.. What are your tire specs? |
10-04-2018, 07:35 AM | #381 |
Still Learning
Looks great!
10-31-2018, 07:59 PM | #382 | |
Sofa King Crazy!!
Thanks man!
305/40-22 outback 265/40-20 upfront. Thank you sir, it's been a crazy build so far!
10-31-2018, 09:20 PM | #383 |
Sofa King Crazy!!
After getting the front clip on and half way aligned it looks like a project!!
Fitting those Slosh Tubz under the hood. I had a fitment issue but a quick call to Mike and POW, done!!! Still have a ton to do just on the front clip but it is coming along.
11-01-2018, 07:46 AM | #384 |
Ok then. Tic toc.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
11-01-2018, 11:47 AM | #385 |
JMHO but, if you're doing a 2WD it should look like this thread
11-01-2018, 12:02 PM | #386 |
Nice, nice, nice
Seth Instagram: sethrosa11 My Build Thread: "Betty" http://67-72chevytrucks.com/vboard/s...d.php?t=613225 1966 C10 Patina: http://67-72chevytrucks.com/vboard/s...d.php?t=716802 1978 Big 10 http://67-72chevytrucks.com/vboard/s...d.php?t=771383 |
11-08-2018, 08:28 AM | #387 |
Still Learning
Very nice!
11-28-2018, 04:48 PM | #388 |
Did you figure out what to do with the cowl along the bottom of the windshield? I've been curious for a while what you decided. This thing is incredible!
Jeremy 1969 Blazer 4x4 original cst 1971 Blazer partial 2wd convert 1972 Blazer 4x4 original cst 1970 Blazer 4x4 w/ 2 1/2in lift and 33in tires w/4 wheel camper 1970 4x4 suburban w/ 6in lift and 35in tires 1968 Corvette convertible 1970 Malibu convertible 1959 Brookwood wagon 1972 International Scout ii Last edited by 72gmguy; 11-28-2018 at 04:49 PM. Reason: Punctuation |
12-11-2018, 06:26 PM | #389 | |
Sofa King Crazy!!
I know, right!?!?
Thank you Sir! Thanks Brotha! Yes sir I did. I'll get some pics up for ya a little later tonight or tomorrow. It was pretty simple once I figured it out. Happy to share!!
12-11-2018, 07:03 PM | #390 |
Sofa King Crazy!!
Roadster cowl customization in 5 easy steps!!! I really hope this helps someone out!
Mark where your cowl should be cut to match the A-pillar. First the back portion of the cowl was cut off and relief cuts where made from the back toward the front. I took out about 1.25" at the rear and none across the center of the cowl. I cut out excess metal until both pieces butted together nicely. This gives you a flatter surface than stock. I cut out the fresh air vents on the cowl and replaced it with 18 gauge metal. I made the metal concave to match the cowl then used a shrinker/stretcher to get it to bend properly to match the compound curve from side to side. I worked a little short hair fiberglass into the cuts then went over that with some trusty bondo to get it to look halfway decent. After a small amount of sanding I got it very close but still feel a small dip where the inside relief cut was made. A little more pookie on it, and it should be good! For the record, I'm not a bodyman!!
12-11-2018, 09:50 PM | #391 |
That's pretty nice work for a non-body man. Looks awesome!
12-12-2018, 12:32 AM | #392 |
Oh now that's funny- For the record.
01-17-2019, 05:07 PM | #393 |
Sofa King Crazy!!
I gave it a shot!!!
Definitely not a body man!! But I'll try anything once!!
01-23-2019, 05:29 PM | #394 |
Sofa King Crazy!!
Excuse all the junk in the background. Just wanted to post a picture showing the shaved cowl. It makes the whole truck look different.
I have been working to get the dash, door, fender, body and custom sail panel on the door aligned. This is turning into a hassle but it will be worth it in the end.
01-23-2019, 09:02 PM | #395 |
Looks awesome. All the lines are coming together nicely.
09-17-2019, 10:18 AM | #396 |
Sofa King Crazy!!
Thank you sir!!
09-17-2019, 11:08 AM | #397 |
Sofa King Crazy!!
I have not done much to the Blazer lately, but that is about to change!! This is the concept I have in mind and if it flows together it may be what happens. I am going for the old Corvette look. Thoughts?
09-17-2019, 11:33 AM | #398 | |
09-17-2019, 11:42 AM | #399 |
Sofa King Crazy!!
This is the reason my Blazer has not been getting much attention. I bought this little 78 GMC and put some time in on it. She is cool, just not old enough.
09-17-2019, 11:43 AM | #400 |
Sofa King Crazy!!
Thanks man! Just trying to think outside the box and bring cool stuff to the custom world!!
