01-25-2020, 11:17 AM | #1 |
Which tilt column to get from junkyard
Which junkyard tilt column do I need to put in the 72?
01-25-2020, 10:14 PM | #2 |
Old member
Re: Which tilt column to get from junkyard
72!
Depends on how much work you want to do. I'm sure with some work a 60-70's car tilt would fit in the location.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
01-25-2020, 11:09 PM | #3 |
Look for old(70-78) RVs in the yard. I’ve happened upon quite a few over the years, and all were in very good shape and were tight.
You’ll have to modify the end shaft and move the wiring connector, but there are plenty of threads on the subject here. |
01-26-2020, 04:29 AM | #4 |
The boxy RVs from the 70s-80s. Move the NSS and put the flat to round turn signal adapter on and you’re done.
Grab the HD front sway bar while you are there and take a peek underneath for Gear Vendors overdrive.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
01-26-2020, 10:50 AM | #5 |
