Old 01-20-2020, 01:07 PM   #201
nlped
nlped's Avatar
Re: Walter DeWayne...Walt for short
I’ve got Martha running, driving and far enough along to enjoy. This means I’m about to dive back into Walter
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 01-20-2020, 02:24 PM   #202
flashed
Im ready when you are , come on Walter .
flashed is offline   Reply With Quote
Old 01-20-2020, 04:48 PM   #203
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
I'm ready too.....
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
Old 01-20-2020, 08:09 PM   #204
nlped
nlped's Avatar
^^^Thanks guys! I’m ready too. My malady now is...do I use the PorterBuilt chassis and accuair or do I sell it and just go static drop.
Carter
Old 01-21-2020, 11:07 AM   #205
SCOTI
SCOTI's Avatar
Why not PB chassis & C/O's? That's what I'm doing for my 64's front PB air-bag set-up. I'm making front upper brackets for some C/O's. My PB Dropmember is one of the early designs that he doesn't offer a C/O alternative for so I'm making my own.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 01-21-2020, 11:14 AM   #206
68bowtie
68bowtie's Avatar
Sell it and buy ECE static parts 20% off...
I live in California, but identify as a Texan
"If a job's worth doing, it's worth doing well"
Survivor "Lil’ Mint" (67 c10 40k mile light green original paint)
Old 01-21-2020, 11:23 AM   #207
SCOTI
SCOTI's Avatar
Because they're going out of business
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-21-2020, 09:23 PM   #208
nlped
nlped's Avatar
That’s a great idea!!! But it means raising the bed floor and a few other issues.
I actually already have another set of the CPP modular spindles for The Wilwood brakes.
That sucks!!! If I go static, I’d need front & rear springs and a c-notch.
Carter
Old 01-22-2020, 11:10 AM   #209
SCOTI
SCOTI's Avatar
If you had F/R PB set-ups, you already have a rear step notch. Are you saying you only want a mild drop now vs. a more aggressive drop?
Wood or steel floor?
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-22-2020, 02:04 PM   #210
nlped
nlped's Avatar
My PorterBuilt F/R setup is the previously available touring versions. So I didn’t have to notch the frame for the r&p, but in the rear is a much larger notch than the little bolt in one that the mild gets. It’ll get to about 1/2” off the floor in the front and about 1-1/2” in the rear. I currently have a steel floor, but I’m not apposed to swapping to a wood floor, since it’ll have to be raised/changed anyway.
Carter
Old 01-22-2020, 03:45 PM   #211
SCOTI
SCOTI's Avatar
Keep what you have & work w/that. PB should have easily swappable brackets to get you to the C/O option or build your own.
A bolt-in c-notch won't get you the clearance you need (want) for worry (impact) free driving. With a steel floor, locating the sheet metal & raising the floor for necessary clearance is even easier (after cutting & chopping things up ).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-22-2020, 06:35 PM   #212
nlped
nlped's Avatar
Hell, I think I’ll just stay the line and air ride PB chassis.
Carter
Old 01-22-2020, 06:41 PM   #213
SCOTI
SCOTI's Avatar
Nothing wrong w/that either. I can't afford the high end air management control set-ups w/the height + pressure sensors controlling auto height adjustments & seen more than a couple NET stories of failed control units so I stick to basic old school air management which becomes old when driven a lot. Thus, my decision to go coil-over.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-22-2020, 09:02 PM   #214
nlped
nlped's Avatar
I don’t have to super fancy accuair setup. Just the manifold, compressors, and controls.
Carter
Old 01-23-2020, 12:51 AM   #215
SCOTI
SCOTI's Avatar
I skip any electronic 'control'. Pneumatic paddle valves for all 4 corners, 2 small Thomas comps, & 2 3gal alum tanks is what has worked.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-25-2020, 11:23 PM   #216
nlped
nlped's Avatar
I am using an electronic controller; the Switchspeed setup from accuair. But Yep, 2 compressors and 2x 3-gallon tanks.
Carter
Old 01-25-2020, 11:28 PM   #217
nlped
nlped's Avatar
I also ordered a set of wheels for Walter today. Pretty basic stuff... 20” American Racing grey Torque Thrust’s and Toyo Proxes ST-3’s: 20x8” with 255/45r20 & 20x10” with 295/40r20’s. I need them before I can even move Walter back to the lift.
I really wanted to go with Salt Flat’s, but my vanity got the best of me in that I want the brakes to show I figure the tires are kinda tall...29’ish inches tall, but with the Slosh Tubz up front and the raised bed floor out back, I’ll have plenty of room for them.
Carter
Old 01-28-2020, 08:12 PM   #218
nlped
nlped's Avatar
Tires arrived today and the wheels show the expected delivery date as tomorrow. If they show up, I’ll mount them tomorrow night and get them on Walter so I can move him to the 2-post. Then this weekend, my next attempt for getting him done will begin!
Carter
Old 01-28-2020, 08:20 PM   #219
boonedogs72
boonedogs72's Avatar
Glad to see your still at it on this one! And recognize a few of those parts I sold you a few years back!
boonedogs72 is offline   Reply With Quote
Old 01-28-2020, 09:11 PM   #220
nlped
nlped's Avatar
Bahahahaha, yeah, it’s been a few minutes. But I just can’t bring myself to giving up on Walter. Thanks for stayin’ Faithful .
SEMA this year? Or are y’all still turnin’ our kiddos
Carter
Old 01-28-2020, 10:11 PM   #221
boonedogs72
Haven’t been in to long! My youngest will be 5 this year so maybe this is the year I get Togo back!!! Haha
Old 01-28-2020, 10:15 PM   #222
nlped
nlped's Avatar
Has it been that long??? Wow!!! Well, if you decide to do SEMA, let me know. I’ll buy you a beer...or 7.
Carter
Old 01-29-2020, 08:29 PM   #223
nlped
nlped's Avatar
Now that I’ve gotten the Falcoon to a satisfactory stopping point and have started back on Walter. I got the new wheels & tires mounted tonight and on so I can get him moved to the 2-post lift. I think they look great with the big Wilwood brakes behind them... I’m off Friday-Monday, so I’m hoping to get a lot accomplished this weekend.
Carter
Old 01-30-2020, 10:13 PM   #224
boonedogs72
Looking good! Can’t wait to see it aired out!!
Old 01-31-2020, 05:31 PM   #225
nlped
nlped's Avatar
I got Walter moved over to the 2-post and broke him apart. But here are a coupe of pictures to show front at approximate ride height and how close the rear bumper gets to the pavement with the biga$$ 29-1/2” tall tire.
Carter
