#451 |
![]() Join Date: Sep 2017
Re: Jesses' 48 PU
That worked great!
8man-aka Robert 1948 on a S10 Frame, small block with a carb 1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL] [/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204 |
#452 |
Re: Jesses' 48 PU
Okay, Im tired... wet sanded all day yesterday... I dont have finger prints left!!
Today I installed the fenders for good.. and quickly threw on the passenger side door. I have to adjust it. Its hard being a one man show....but ill get it done...
![]() Check out my project: http://67-72chevytrucks.com/vboard/s...d.php?t=559086 |
#453 |
![]() Join Date: Sep 2016
Re: Jesses' 48 PU
Current Build Thread 1930 Ford Model A Modern Twist: Ford Model A Rat Rod With a Modern Twist Build Thread Phase 1 "The Swap": 1949 3100 with S10 swap. Beginner build with ambition! Build Thread Phase 2 "The Drop": Beginner Build with Ambition gets Air Ride |
#454 |
Re: Jesses' 48 PU
Looking awesome
‘53 GMC COE stock ‘53 Chevy 3100 LSA/TR6060 http://67-72chevytrucks.com/vboard/s....php?t=805949‘ '70 Chevy C10 LWB 350/sm465 ‘74 Chevy C10 SWB 5.3/4L80e, Vintage Air, Dakota Digital, US Mags |
#455 |
Re: Jesses' 48 PU
looks great, keep it going
https://67-72chevytrucks.com/vboard/...=797726&page=3http://https://67-72chevytrucks.com/...=797726&page=3 51 Chev 5 window on S10 with SBC 1958 Pontiac Wagon build https://67-72chevytrucks.com/vboard/...d.php?t=849781 |
#456 |
Re: Jesses' 48 PU
Hey Gigamanx, I decided on a DEEPMOTOR column. Picked it up on ebay for 160 or so. Nothing fancy, simple. I didnt want to spend big bucks on the ididit column although they are super nice with all the bells and whistles..
Its stainless steel, but i roughed it up used self etching primer and painted it white to match the interior
#457 |
Re: Jesses' 48 PU
I also used an emergency brake set up from a modern S10. I wanted a push/release assembly. Simple install, used the hinge hole for the top so that bolt will sinch down on the hinge and the brake assembly, welded two bolts to the kick panel and whaalaa... done. Routed the cable through the original ebrake pedal hole.
#458 |
Re: Jesses' 48 PU
Okay need advise... I quickly threw on the passenger door and know it needs adjusting. But this kept me up all night. I noticed the gap on the bottom. Obviously not the original doors to this cab. I am using new hinges from Classic Industries.
As we all know the hinge holes to the cab are slotted for up/down adjustment. How in the world can I adjust the bottom of the door to move in? Should I slot the holes for side adjustment? Has anyone faced this dilema?
#459 | |
Re: Jesses' 48 PU
#460 |
Re: Jesses' 48 PU
Yes her is some pics... will try to load up a short video as well.
#461 |
Re: Jesses' 48 PU
I couldnt load up my video. But I noticed the top front of the door makes contact. So obviously it needs to drop down an 8th or so, but it also needs to come out from the top and in from the bottom. So maybe I shim the top out and the bottom in...
#462 |
Re: Jesses' 48 PU
Thanks... I took the Bob Ross approach.. had a lot of "happy accidents"
#463 |
Re: Jesses' 48 PU
Jesse, I had to do some grinding in the hinge holes that go into the door to give me enough "slop" to adjust the door, and these are original doors, hinges and cab. After getting the belt all lined up, I still have a little gap at the bottom, similar to what you have, just not quite as much now that the rest of the door is fitting better. Hope that helps.
#464 | |
Re: Jesses' 48 PU
Meanwhile, im working on running the Wilwood universal emergency brake kit. Wish I had a lift like yours, im to old to be crawling in and out from under the truck.. LOL..
#465 |
Re: Jesses' 48 PU
Good for you. I had to rebuild all the door hinges. However, that may not fix all the door fitment issues.
I crawled under mine over and over, it hasn't been on the lift yet, and I'm way older!
#466 |
Re: Jesses' 48 PU
Been MIA for a bit.. have been traveling due to business and less time spent at home, I got the hinges back from the machine shop, installed the new pins and doors fit much better. The passenger side door went on with no issues, the driver side door still has a small gap at the bottom, I enlarged the holes to give it sideways adjustment and the gap is much smaller now. Still not happy with it, but stepped away from it for a bit.
#467 |
Re: Jesses' 48 PU
Huge improvement, I'd be thrilled if mine fit that good.
1951 Chevy Panel Truck |
#468 |
Re: Jesses' 48 PU
I had a similar problem with my doors. You may need to bend the hinges slightly.
Take a look at post #17 here http://67-72chevytrucks.com/vboard/s...d.php?t=578310 You may want to wait until you have the seals on your doors to get them set up just right.
1951 Truck, LS1/4L60 1964 Suburban, current project 2014 Silverado daily driver 1953 Westerner "canned ham" trailer, rebuilt 1974 Prowler trailer, rebuilt |
#469 |
Re: Jesses' 48 PU
Well its been a minute since I post an update. Between fighting Covid, work (so grateful to have still have a job) and the daily hustle its been challenging to keep up. I have been working on my truck here and there. I finally got to the trans cooler, wasnt sure where to put it and decided to go with where the battery used to live. Ran AN-6 lines and made some brackets to hold it in place.
#470 |
Re: Jesses' 48 PU
I was undecided on the window regulators as I have the originals, but after taking a close look at them. It seems as if someone tried some backwoods engineering repairs and the plastic roller thingys gone as well. I opted to buy new ones. So this weekend I decided to work on the doors. I layed down some Eastwood Thermo Coustic Barrier. It lays down easy, but obviously clening the inside and working the sheets inside the door is challenging... getting my fat hands and arms in and out of the inspection holes was... well lets just say it tested my patience... after numerous choice words, my arm getting stuck a few times... I finally got the job done. The doors sound solid now, no more empty can noise... but one thing I did not consider was the weight... the doors seem heavy now... so scratching my head... wish I would have done a little more research...
#471 |
Re: Jesses' 48 PU
My hands and arms look as if I got in a fight with a cat...
#472 |
Re: Jesses' 48 PU
After fighting that cat, I installed the window regulator, door latch and the door seal... I was dreading it as I was afraid to screw it up. After watching Jerry Kassis with Dr. J's Restoration on YouTube about 100 times... I built up the courage to go for it... a little messy but glad I watched his detailed video... so left door done and installed.
#473 |
Re: Jesses' 48 PU
Radiator is on for good as well...
![]() Check out my project: http://67-72chevytrucks.com/vboard/s...d.php?t=559086 Last edited by Rickysnickers; 05-03-2021 at 09:40 AM. |
#474 |
Re: Jesses' 48 PU
You're getting there. Looks good.
#475 |
Re: Jesses' 48 PU
Continued the sound/heat barrier project. Glad to finally have the cab floor, firewall and rear panel done.
![]() Check out my project: http://67-72chevytrucks.com/vboard/s...d.php?t=559086 Last edited by Rickysnickers; 05-14-2021 at 09:54 AM. |
