![]() Join Date: Aug 2004
Tilt column "truck clone"
$475 local for now. I may ship later if I can find good thick-wall tube.
Please respond in thread only per board rules, first "I'll take it" gets it. Selling a painted and converted motorhome tilt column. From a mid 80s GM chassis It has the straight shifter arm like a truck tilt Also has the metal gear indicator and L1/L2 script lens like a truck tilt I moved the NSS down so it's a bolt-in for your 67-72; I used my multi-meter to adjust it, you may need to fine tune it after install. Turn signal and tilt levers are new from GMC Pauls New GMC Paul's gear indicator Turn signal switch is new Good used cancel cam The gray illumination wire is long Includes a long pigtail for the Neutral Safety/Reverse switch Tilt mechanism is tight and smooth. The 4 bolts in the tilt mechanism that typically loosen over time have been removed and reinstalled with lock-tight. Tilt pivots were cleaned and lubed when removed to tighten the bolts. The bottom bearing was cleaned and greased The upper bearings were cleaned and greased The shift indicator bulb was replaced and tested OK, it has the green shade on it. Shifter lever end (inside column) is good, pivot is good Shift arm has nice chrome, it shines up well. There are 2 small ding spots, shown in the pics The finish on it is base/clear coat gloss black. The shift arm is metallic silver and includes the rubber bushing and metal sleeve New firewall and dash gaskets from GMC Pauls Firewall mount plate included, blasted and painted semi-gloss
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
Re: Tilt column "truck clone"
One more
![]() Join Date: Aug 2018
Very nice!
Thanks! My painter friend did the shiny stuff.
If you need to ship it , Home Depot sells white plastic pipe with a bell on one end . Pipe has small drain holes along the length but is plenty strong for shipping a column . Cut it to length , slide the column into the big end , the top of the column just fits inside the bell, I taped thin plywood on each end and then wrapped the complete pipe in packing tape .
![]() Join Date: Feb 2014
Clay, no need for a plastic tube. I'll take it
1971 LSX "Bonnie" build thread http://67-72chevytrucks.com/vboard/s....php?p=8026381 paypal is curtbarton1971@yahoo.com |
Flashed; thanks for the lead on that. I’ll look into it.
Curt; thanks man. I’ll get ahold of you sometime today. Sold to Curt
Tags |
column, tilt, tilt column, tilt wheel |
