11-11-2020, 04:47 PM | #1 |
Wandering Speedometer Needle at Highway Speeds
At speeds under about 40mph, my speedometer is stable, but it drifts around at higher speeds, as seen in this video:
https://youtu.be/5TxuNPqF8_g I swapped in another speedometer I had, and it was even worse, but acted basically the same way. It seems like bumps in the road are causing the needle to move around. What can I do to fix this? Do I need to get a new/reproduction speedometer? |
11-11-2020, 05:24 PM | #2 |
Re: Wandering Speedometer Needle at Highway Speeds
Try lubing the speedo cable. Doesn't cost any thing and it may help.
11-11-2020, 05:28 PM | #3 |
11-11-2020, 07:25 PM | #4 | |
Old member
Take the cable loose at the transmission and look at the plastic gear head it goes into. It's more than likely worn out. Take it out and buy the same gear put back in it. This is just example picture. Look into the end opisite of the gear that is where the cable goes. It should be nice and square like the cable and fit's pretty tight.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
11-11-2020, 07:54 PM | #5 | |
11-11-2020, 08:33 PM | #6 |
Old member
That gear looks OK. It could be the end of the cable that goes into the speedometer head also. Are the cable end going to the gear itself. How do they look?
11-11-2020, 09:38 PM | #7 |
The cable ends look perfect to me. Here are some mediocre photos of them.
11-11-2020, 10:06 PM | #8 |
If he doesn't chime in PM TBONE1964. He will be able to talk to possible problems inside the speedometer itself.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
11-11-2020, 10:08 PM | #9 |
11-12-2020, 11:09 AM | #10 |
What did you lube the cable with?
Did you pull it apart and clean it inside plus the cable. |
11-12-2020, 11:18 AM | #11 |
I used a Teflon based light grease that is designed for bicycle cables. I pulled the cable out of the housing, wiped it off, applied the grease and reinstalled. I didn't clean the housing.
11-12-2020, 11:44 AM | #12 |
I clean them out inside and the cable with acetone.
Then use white lithium grease for lube applied sparingly. Make sure the cable is held in place along the lower firewall too. |
11-12-2020, 11:46 AM | #13 |
I'll give it a good cleaning with solvent. I have it fastened to the firewall with the original clip.
11-12-2020, 12:33 PM | #14 |
Sheesh, mine always wanders like that and I never really thought anything of it. I guess I have another thing to fix.
1968 GMC C2500 Long Bed Fleetside |
11-12-2020, 01:22 PM | #15 |
That's what I'm wondering. Maybe this is common simply due to the age of our trucks. This is my fourth C10, and none of my previous trucks had this issue, but the last one I had was 13 years ago.
11-12-2020, 04:13 PM | #16 |
I have used graphite dust to lube the speedo cable, but the most reliable ground speed indicator is a GPS device on the dash.
11-12-2020, 04:55 PM | #17 |
I think cable issue is the most likely cause of a bouncing speedometer. I would remove the cable, pull the inner cable out of the sheath and a suitable lubricant (i.e. not lithium grease) such as:
https://www.amazon.com/Ags-Kable-Eas.../dp/B000ZO0EA2 |
11-12-2020, 05:06 PM | #18 |
I just put this new cable in and lubed the heck out of it, as did the OP, so I don't think it's the issue here
11-12-2020, 06:19 PM | #19 |
How the routing, do you have a sharp bend in the cable. Maybe disassemble the speedometer and lube the part of the cup/magnet part that the cable spins. Maybe it is binding due to hard grease at the housing.
11-12-2020, 06:42 PM | #20 |
The routing seems good to me, and there are no sharp bends. I already put a drop of light oil on the speedometer input shaft.
11-12-2020, 07:19 PM | #21 |
When I pulled my cable and housing out, Cleaned the inside of the housing and could not believe the grit and gunk that came out of it.
after a couple of good cleanings to the housing and cable, lubed with speedometer cable lube and good as new.
1968 C20 Fleetside 396 4sp PS PB AC CST . https://www.youtube.com/watch?v=RWK8GgWD4uA |
11-12-2020, 09:45 PM | #22 |
I have found those offset spedometer correction boxes [used when you have bigger than stock tires] tend to amplify the bounce.
11-27-2020, 03:16 PM | #23 |
I sent my speedometer to TBONE1964 and he ended up replacing the entire speedometer head with good used unit. The speedometer is drastically improved over my old unit. It is rock steady most of the time. It still swings around if I hit a bump or dip, but that seems unavoidable. Here's a video of it in action.
https://youtu.be/Cvvz8rQTz_E |
11-27-2020, 03:47 PM | #24 |
My rig just rolled over 400,000.
11-27-2020, 04:23 PM | #25 |
