11-21-2020, 11:26 PM | #1 |
69 507 two tone blue with white top interior colors
What blue dash pad door panels and vents where the light blue 507 trucks ?
11-22-2020, 12:06 PM | #2 |
Re: 69 507 two tone blue with white top interior colors
I had a similar truck but sold it, but I clearly remember it had dark blue door panels anid dark blue dash pad. Is this the color you are talking about:?
1972 Chevy Custom Deluxe Highlander, owned 34 years. 1970 GMC Sierra Grande 2500, unrestored, original. 1970 Chevy K10 Short Wide-bed, working on restoration.. 1967 Chevy K10 Short Stepside, unrestored original. 1969 GMC CST (Longhorn) 396, buckets, unrestored. 1995 GMC K2500, 65,000 miles, 454. |
11-22-2020, 02:00 PM | #3 |
I assume you're just referring to the primary paint code - but, just in case, if your truck is indeed paint code 507, then it was originally a solid light blue with no white top. If 537 (note georgieb's) then it had the white top originally.
Exterior paint color did not define a specific interior trim color - it only drove the selection of standard interior trim colors available. (i.e. a 507 or 537 truck could also have a black interior trim (dash pad, door panels, etc) or a few other colors). If your truck had a 606 RPO blue interior - then georgieb is your man, that's the only interior blue trim color that was available. Below pic, although not a very good one (sorry), shows the blue CST interior (i.e. vinyl w/scrollwork door panels) in the same shade of blue. Also note the blue a/c vents match the vinyl trim color, not the body color (although, we've seen some exceptions to that over the years). Just for grins, also note that 69 was the only year of the two tone seat cover, darker on the sides, lighter on the seat and back surfaces. Do you happen to have a pic of your truck's SPID? |
11-22-2020, 02:50 PM | #4 |
Yes it is a 537 white top truck
I used to have it as a parts truck Missing doors tailgate some interior I am getting it back soon digging up parts to build it i think it was blue interior only pic I have of it are from 90 feet away 5 bolt suspension 5.3 with a 4l80e 4 series posi Thinking also about 4.11 gears should be about 2300 rpm at 70 miles an hour with 28.5 tall tires |
11-25-2020, 05:44 PM | #5 |
Mines a 68, so the interior color option might be a bit different. It came from the factory with 537 light blue/off white exterior color and 614 blue vinyl trim interior.
Edit: not sure how to flip the pic |
