Old 04-01-2020, 05:35 PM   #51
ShortbedClayton
Re: 1972 Chevy Crew Cab “Denali”
I know it’s gonna be tough. Going with truck roofline for sure
ShortbedClayton is offline   Reply With Quote
Old 04-01-2020, 09:55 PM   #52
72 tigger
72 tigger's Avatar
Looking good- great progress
71 C10
72 K20
72 K10 Super
Kirk
72 tigger is offline   Reply With Quote
Old 04-01-2020, 09:55 PM   #53
Getter-Done
Getter-Done's Avatar
Looking good.
The Truck roof line will look better.
You have the material.
Just do it like Brandon done it.
84 Chevy K-20
Old 04-01-2020, 10:22 PM   #54
vitamin_c95
Excellent work. Kinda wish I had metal skills.
1971 C20 Longhorn 350/350 "Conquistador"
vitamin_c95 is offline   Reply With Quote
Old 04-02-2020, 07:23 AM   #55
ShortbedClayton
Thank you
Old 04-05-2020, 09:23 AM   #56
ShortbedClayton
Just playing around with whee and tire combos... fun fun but now it’s timw to get back to working on the thing. Next task is to get floor rust repaired and get to rockers and cab corners
Old 04-05-2020, 11:12 AM   #57
cst204x4
Very nice work! Following
1970 CST 4x4 collecting nos parts for this project
1972 cutlass owned since 1984
1972 cutlass conv
1970 Cutlass conv
1981 chevy shortbox
1986 grand national
2004 2500HD Crew Cab 66,000 miles
cst204x4 is offline   Reply With Quote
Old 04-23-2020, 02:26 PM   #58
ShortbedClayton
Took some time away from the cab and decided to restore my k20 hubcaps for this build. First I polished them and removed old paint. Then I taped off the inlays where it should be black. Also taped off the bow tie.. Next was two coats of flat black. Upon the removal of masking tape i finished by painting the bow tie inlay blue. May be a tad dark but should look good in new steel wheels.. overall it took about 12 hours... but worth it in the end
Old 04-24-2020, 06:24 AM   #59
72 tigger
72 tigger's Avatar
Caps turned out great!
71 C10
72 K20
72 K10 Super
Kirk
Old 04-24-2020, 11:46 PM   #60
cornerstone
cornerstone's Avatar
That first picture of the sun glistening off of that cap is pure chrome goodness.
Brian
1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod.
cornerstone is offline   Reply With Quote
Old 04-25-2020, 12:40 AM   #61
3757chevy
3757chevy's Avatar
I agree.
'67 Stepside (bought 1997-sold 2021) '96 Bronco Eddie Bauer (inherited 2010)
MIKE
3757chevy is offline   Reply With Quote
Old 08-13-2020, 10:34 PM   #62
Willowrun
Willowrun's Avatar
Great build! Any updates?
Old 08-14-2020, 03:49 PM   #63
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Wow, great build!!! I really like your K10 too. Great fab work you did on this unit. Someday I'll get around to building one.
Ryan
1969 Chevy milk truck
Old 08-19-2020, 09:41 PM   #64
ShortbedClayton
Not much to update. Still work on it as much as I can. Been in the mid to high 90s past few weeks so that slows progress. Did remove the outer roof and start laying in the inner roof.
Old 08-19-2020, 09:45 PM   #65
ShortbedClayton
Been building some hickey parts for this project as well. Tried to replicate them as best as I can. Made a couple front axle trusses and for one up. Looks real good. Also to my knowledge they never made a finned aluminum diff cover for the 3/4 ton HO52 rears. So I started messing with some metal and ended up with a nice looking diff cover. Painted that up tonight to look like an aluminum one. Super happy with it.
Old 08-19-2020, 09:45 PM   #66
Getter-Done
Great job.
That's going to look smooth.
84 Chevy K-20
Old 08-19-2020, 09:47 PM   #67
ShortbedClayton
Originally Posted by Getter-Done View Post
Great job.
Thanks my friend. Not looking forward to the overhead welding and a little worried about worpage but won’t know until I get to it. Hoping to knock it out on labor day weekend
Old 08-19-2020, 10:35 PM   #68
gmc684x4
Very sweet build truck of dreams coming to life
gmc684x4 is offline   Reply With Quote
Old 08-19-2020, 10:49 PM   #69
Getter-Done
This is very similar to the plan I hope to use with my Headliner.
Just a suggestion
I would weld a Jig.
If you run a solid bar with{ tabs (down ward) } where you can bolt to your upper shoulder seat belt bolts.
. Slotted brackets front side or back That would be slotted etc. etc. to hold the roof Up to keep it some what in position.
You could put a Sheetmetal screw to hold it also.
Then use it to support the roof while you are welding/
It will help with the heating and cooling of the roof panel for your plan.
Just suggesting.
Hope this helps.
Your are making Great Progress.
I hope to get back to work on my in a few months.
84 Chevy K-20
Old 08-20-2020, 03:54 PM   #70
Dieselwrencher
Great work on the diff cover and truss. I remember seeing a Hickey diff cover for a HO52 but I don't remember who had it. Definitely super rare.
Ryan
Old 12-03-2020, 08:37 AM   #71
ShortbedClayton
Update for my fellow crew cab enthusiasts. Got the inner roof all welded in. Outer roof is also attached and the metal work in the inner and outer roof is complete.. on the inner roof I added an additional interior light to light up the front seats and console area...
Old 12-03-2020, 08:41 AM   #72
ShortbedClayton
Took advantage of the extended thanksgiving vacation and tacked some major rust repair of the c10 cab back I used. I got in a pinch trying to find a rust free cab back so I settled for average PA rust. I got both rear supports replaced, numerous floor patches, both cab corners, and I re worked my trans tunnel transition so carpet and sound deadened will lay down nicer. Still have some rust in the front half to fix and rockers and such but progress is progress.
Old 12-03-2020, 08:44 AM   #73
ShortbedClayton
Also in the last few months I took the time and worked with a fella up in Canada and got a 3D rendering for this build and he knocked it out of the park. Defianly got my motivation back for sure. If you need a rendering done I highly recommend Chad at RenderedRides. Killer work..
Old 12-03-2020, 10:20 AM   #74
1971Stepside
Almost Satisfied
1971Stepside's Avatar
Wow!! Those renderings are very nice and that truck will be beautiful. I love watching this thread. I would love to tackle something like this, but watching you do it is much cheaper
Now that you are motivated, let's see updates each week!
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021.
"I can't complain, but sometimes I still do. Life's been good to me so far."
1971Stepside is offline   Reply With Quote
Old 12-03-2020, 11:07 AM   #75
ShortbedClayton
I’ll try to post more updates as progress happens. Thanks for the encouragement I’m excited to make more progress
