01-09-2021, 10:25 AM | #1 |
Junior Member
68 hood edge molding
Anyone have a pic (side view) showing how tight the hood molding fits against the hood?
01-09-2021, 11:18 AM | #2 |
Old member
Re: 68 hood edge molding
The best I have. It's pretty tight.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
01-09-2021, 12:18 PM | #3 |
Oem
01-09-2021, 01:26 PM | #4 |
Junior Member
pjmoreland that's exactly what I needed to see. I didn't know that there was that much space between hood and molding, in other words I thought it fit tight against the hood like the fender eyebrows
Thanks Andy4639 for your pics also. |
01-09-2021, 02:54 PM | #5 |
Old member
You can maybe Massage the trim where the stud is to pull it in tighter and even add more studs and drill more holes if you like.
