01-13-2021, 05:20 PM | #1 |
Front brake conv. ??
OK looked at the FAQ section and never noticed any ?? on using any of the brake parts from the vans or is it a total different suspension.My neck of the woods its hard to find 2 wd stuff ,but I know where a van is sitting
2001 Silverado K-1500 2005 FXDWG stage3 69 CHEVY Short/Step 327/4L60 373 posi 63 IMPALA 327 |
01-13-2021, 06:24 PM | #2 |
Re: Front brake conv. ??
Just be careful.
The van parts are a little lighter duty than the 2wd pickup parts. That is: a G10 van is like a super light C10; a G20 more closely resembles a C10 squarebody. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
01-13-2021, 10:20 PM | #3 |
OK Thanks
01-13-2021, 10:51 PM | #4 |
60-66 Nut
I would suggest a G20 van for a disc brake upgrade. The few that I have seen have a different LCA shaft than a C10 Squarebody. Be aware that the G series van steering boxes will not work for a power steering conversion if the box is mounted almost vertical with the pitman arm to the rear and pointing down. Those boxes turn the opposite of a pickup box.
01-13-2021, 11:02 PM | #5 |
Yeah thats what I was wondering so are the K10/20 steering boxes a good choice ?
2001 Silverado K-1500 2005 FXDWG stage3 69 CHEVY Short/Step 327/4L60 373 posi 63 IMPALA 327 Last edited by kaycee; 01-13-2021 at 11:02 PM. Reason: Brain tumor |
01-14-2021, 11:16 AM | #6 |
Just get some later model spindles and ball joints. You can find them on RockAuto.com if you like. Here I used 75 model spindles on my truck. Shows parts also. http://www.67-72chevytrucks.com/vboa...isc+brake+swap
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
01-14-2021, 08:51 PM | #7 |
You guys are awesome , Chevy Fleetside I read your post last night and thought Hell Yeah wasn't looking toward the engine removal for a complete crossmember swap at all maybe I can score some of these parts on my budget. Did you go with the same year 75 for the booster?
01-14-2021, 10:33 PM | #8 |
60-66 Nut
NO. You can not use a K series steering box and pitman arm on a C series truck. The box casting is the same but the sector shaft is different.
01-15-2021, 12:36 AM | #9 | |
I thought the G20 spindles are pretty much the same as the C10. I was looking at how to lower my G20 and people use the C10 drop spindles.
01-15-2021, 12:49 AM | #10 | |
01-15-2021, 11:14 PM | #11 |
60-66 Nut
Thank you. There are many,many,many boosters that are compatible with all of my booster brackets. Just not the squarebody boosters. Those have the factory mounting brackets riveted to them
01-16-2021, 12:02 AM | #12 |
Back in the day, I used 86 C10 spindles, rotors, and calipers on my 69 C10. But I also had to use a 73-87 C10 center link and tie rod ends.
Bought used spindles and center link for a song at a junkyard. Also found a used master cylinder, prop valve, booster, and mounting bracket from a 71-72 pickup. That was around 25 years ago, when junkyard parts for our trucks were plentiful. MPBrakes makes a complete kit for your 69 C10, but they are not cheap.
Mike 1969 C10 LWB -- owned for 34 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 23 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
01-16-2021, 11:59 AM | #13 |
What booster would be a good candidate for this ?
01-16-2021, 12:38 PM | #14 |
The factory used a single 11" booster, but an aftermarket dual 8" will work.
A stock one would have looked like this but was spaced out from the firewall with a bracket. Master cylinder bore diameter was 1-1/8" with power. Manual was probably 15/16" or 1". Here's a dual 8" setup from MP Brakes. They also make a dual 9". These guys make their own brackets using an actual firewall and pedal assembly in the process. Their pre- and post-sales support is second to none. https://www.mpbrakes.com/booster-mas...m-booster.asp?
01-16-2021, 12:41 PM | #15 |
Keep in mind that your engine will need to make at least 16" vacuum at idle for use with a vacuum booster. MP Brakes might even say 18" minimum for best performance.
01-16-2021, 02:08 PM | #16 |
Awesome ,got the ol gal fired up yesterday it has a 350 in it,now I need to move on to brakes and trying to decide what to do .The master cly. is toast so may just jump over to the power disc setup . OK 1 more ? if I do the spindle swap to newer wont that make my front a little wider than the rear?
2001 Silverado K-1500 2005 FXDWG stage3 69 CHEVY Short/Step 327/4L60 373 posi 63 IMPALA 327 Last edited by kaycee; 01-16-2021 at 02:14 PM. |
01-16-2021, 03:43 PM | #17 |
If there is any difference, I've never noticed it. 255-70x15 tires on 8"wheels. I'm talking about 73-87 spindles, center link, and tie rod ends.
Mike 1969 C10 LWB -- owned for 34 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 23 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! Last edited by MikeB; 01-16-2021 at 10:10 PM. |
01-17-2021, 04:58 AM | #18 |
I picked up a g20 last sumer I was thinking about using it for disc brake conversion cross reference spindles and a arms on rock auto listed them as the same
G20s also use the 1 1/4 hd brake rotor Another member on here posted 73 77 elcamino inner tie rods with 73 87 outer tie rods will fit the 67 70 center link I ended up with a complete 72 running gear for my build |
01-17-2021, 05:56 PM | #19 | |
The 1/4" extra on each side doesn't bother me at all. If it did, I would just add a 1/4" spacer to the stock rear end
Christian Carpenter 1963 C10 - Frankentruck 283, 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
