01-17-2021, 01:42 AM | #101 | |
Re: Anyone can buy an SWB...
I've been doing some tweaks to my OBS '99 CC SWB as well. Definitely not to your extent but a little lower than it was w/some fresh steering gear.
01-17-2021, 01:53 AM | #102 |
Thanks. I tried to sell the 98, almost couldn't give it away... I still have feelings for it so I disassembled it and said F it, I try something diff.
They just have great lines. Im going to raise the fender arches and run my 30+” tires with a 5” ride height. These pics are better. I work on it a little each day. Last edited by Inverter; 01-17-2021 at 02:02 AM. |
01-17-2021, 02:43 AM | #103 | |
01-17-2021, 02:50 AM | #104 |
Ha.. my knees dont like it when I squat for too long. What tweeks are you doin and what is the correction for?
01-17-2021, 04:55 AM | #105 | |
I've been wanting to build one of these for years and finally picked one up a couple months ago. It's already down to the frame and starting to stockpile parts and strip the body down to bare metal. I don't think it will be anything as crazy as yours, but you never know. It is a sickness, but I'm cool with it. Too many great ideas on this build threads that lead you down a rabbit hole. |
01-17-2021, 05:19 AM | #106 |
Yep. It can get out of hand.
Ive done it a few times. I would suggest not to get carried away buying parts ahead of time. Usually it takes years to finish a complete build. You likely will change your mind on some things and could get stuck with unwanted parts. One stage at a time. Start with chassis (frame/suspension/brakes), drivetrain (rear end), plumbing (brake/fuel lines), motor & trans, exhaust, body, in that order. Only buy parts for the stage you are in. This way you can have good access to your work without barriers like Laying out exhaust or mounting a motor/trans with the cab/body in the way. Be careful, eye protection n such. Enjoy the journey. Last edited by Inverter; 01-17-2021 at 05:52 AM. |
01-17-2021, 02:04 PM | #107 | |
http://67-72chevytrucks.com/vboard/s...d.php?t=816847
10-08-2021, 11:36 AM | #108 | |
Please tell me that this isn't still in lockdown... |
10-08-2021, 12:34 PM | #109 |
Active Member
Impressive work....Why buy what you can make!
10-09-2021, 12:21 AM | #110 |
Mad Skillz
10-09-2021, 12:56 AM | #111 |
You did all that work to make it a lowered shortbed? Congratulations?
Sorry, I liked it better as a longbed. |
10-09-2021, 10:14 AM | #112 |
And we're ok w/you guys. Nothing wrong w/long beds if thats your thing. '"All that work" was a wee bit more than just going from a LWB to SWB.
