Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > S10 S15 Luv Blazer > projects and builds
Old 01-12-2021, 05:44 PM   #51
Grizz1963
Grizz1963's Avatar
Re: GRIZZ’s English 2001 S10 Extra Cab 4.3 V6 Truck
So today was a rough one from a work point of view.
Busy
Started by 07.30 with online training.
Then from 09.00 more Teams based clinical trial review.
I also had a business review booked for 13.00
This stuff does my head in.
So my lunch hour was committed to my own mental health.
Based on looking under the hood on Sunday, I knew there were a few bits to be done.
K&N air cleaner, divides opinions
I discovered a long crack that had been partly repaired in the radiator cowl.
I was fortunate to be offered an upper half of one , price to be confirmed, same seller who has the steering wheel.
Screwdriver to the fore.
K&N filter undone and removed.
Can you say FILTHY DIRTY.
And rather large.
I also opened the other end to see if the throttle plate needed any attention.
Clean as a whistle.
I was also having advice from my good friend Ric Grassmick who lives in Arizona, and dailies and Autocrosses one of these trucks.
His day job is as an auto mechanic, so the right guy to speak to.
He also advised I look up the connector tube toward the MAF sensor at the divider plate, tooling for two potential caterpillars
These are a pair of very small resistor coils that may need cleaning.
He even sent a drawn diagram of what I needed to look for.
Looking up from the airflow straightener
I will get to these tomorrow in daylight,
Then back into the house.
Using Mr Muscle oven and grease cleaner to loosen the oil and grime the water ended up pretty soup-like.
Three repeats and some Fairy liquid, dishwashing soap and a couple of kettles of hot water saw it a lot cleaner and the water pretty murky.
Then put out to dry.
I got a K&N cleaning and oiling set, known as a “Recharger kit” from Euro car parts, and delivered to the local mechanics a mile from home.for £10.00 which was cheaper than anywhere else.
I will oil the filter tomorrow and reassemble the cold air induction kit.
Finally on my way home from picking up the oil, I saw a nice sunset.
More tomorrow.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside
MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger
IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE.
Grizz1963 is online now   Reply With Quote
Old 01-13-2021, 07:01 AM   #52
Grizz1963
Grizz1963's Avatar
Cleaned my K&N air filter setup yesterday and oiled it today.
Made a quick random YouTube clip as I thought it may be helpful to people like me who have not done it before.
https://youtu.be/Y1MNY0ibuiY
Hope its useful to some.
Old 01-13-2021, 02:48 PM   #53
Grizz1963
Grizz1963's Avatar
Originally Posted by 03. View Post
I still love those sunset pictures, the English countryside is hard to beat mate.
Thank you.
Couple more from my car. Exactly the same spot.
Old 01-13-2021, 03:23 PM   #54
Grizz1963
Grizz1963's Avatar
Postman rang today.......
Delivery of my pair of used, £25.00 or $34.00 clear indicator lenses and bodies.
When buying, I had to choose between paying £50.00 or $68.00 for a pair, showing out of stock in many places, or buying a used pair, that nobody would care about in a day or two after I fitted them.
Into the kitchen, grab a vegetable Knife and pry apart the one lense that showed old glue on the join.
Cleaned up the body and the lense, removing the old glue and general muckyness.
Then onto some rubbing compound, just to refresh the plastics. And yes, you could see the difference between them.
One on the left was already done, one on the right, not done.
Once both are done, there is not much difference to be seen, but I know it is done, which makes me happy.
Washed them, will glue the lense in place later.
Fit them over the weekend some time.......
Happy ? Me?
Of course.
Old 01-14-2021, 01:50 AM   #55
Just call me Sean
Just call me Sean's Avatar
What kind of glue are you going to use?
Originally Posted by Early Cuyler
Fights begin, fingerprints are took, days is lost, bail is made, court dates are ignored, cycle is repeated.
Just call me Sean is offline   Reply With Quote
Old 01-14-2021, 03:48 PM   #56
Grizz1963
Grizz1963's Avatar
Reply below.
Rain
Rain
Rain
Outside the house people continued to drive like idiots, loads of surface water.
So not much progress outside.
However, I did go digging for something, and ended up with some other things
Also discovered that this will be the right product for resealing the lense to the body of the indicator.
Lunch was a cuppa soup and some of my home made Beef Biltong (not quite Jerky)
Doorbell rang, postman with a hand full of small parcels
Included were these from @rich Thank you.
Chromed light bulbs to go into the new indicator lenses in order for them not to look like fried eggs with the yellow regular bulbs.
Also included were the clear side repeaters and a third parcel with flea poison, I did not realise it was not for me, just opened it, then realised I did not have a dog, not had one for 25 years.
Lastly, had to go grab some food and came upon these guys........
Hopefully there will be a break in the weather by the weekend so that I can refit the air intake, and change out the lights.
Easy peasy.
Old 01-15-2021, 05:46 AM   #57
Grizz1963
Grizz1963's Avatar
Rain seems to have dried up overnight, with much more predicted along with possibly some snow and cold for the weekend.
So this morning it was dry and not too cold, so by 07.30 I was outside to grab the opportunity to refit the air filter and check a few more bits out.
I was also chatting with Dennis in Missouri as he could not sleep, getting tips on the things to look out for and little things to touch on while getting this truck to an even better place than it already is.
Big old hole where the filter and ducting goes, it is also isolated to keep the truck getting cold air, rather than warm air from the engines heat.
Refitted and mounted in a way that has it hanging loose, rather than chafing against any of the body or engine parts.
Looks better, hopefully the clean will benefit the engine.
While I was there, I thought getting a record of these stickers that do not come off, would be sensible, as I will be fitting a replacement radiator cowl.
And identified another weekend job........
Can you guess.
Yup, drain the radiator, flush it well, and refill with fresh green stuff.
Along with the other jobs lined up for it, as long as I get some gaps in the weather.
PS. It is Friday after all.
Old 01-16-2021, 06:48 AM   #58
Grizz1963
Grizz1963's Avatar
So the rain has set in for the weekend it seems.
I had hoped to get some jobs done today and tomorrow, but that’s not happening.
So I reassembled the drivers indicator lense using this claimed to be special, adhesive.
Assembled, cleaned and put aside to dry.
Then went out to try get the side repeaters fitted.....
Very different, went to motor factors, no luck in finding amber bayonet fitting type bulbs as the fittings are not pinch type.
Also the actual stalk fitting on the new oval ones are thicker, and on receiving them I realised I don’t really like them, neither size nor design.
So ordered a new set of fittings for pinch type bulbs to be soldered in place next week........
And once I got home, sitting chatting with @craigrk decided to get a different set of lenses as I preferred these much more, they also suit the crystal style of the front end more.
While in the parts store, also bought 5 liters of concentrated antifreeze, as I am going to drain the cooling system and the heater channels and refresh all of the fluids.
Did I mention the truck was a keeper?
Bought the long life stuff.
Waiting for the weather to change.
Lastly..........
Question time:
16” wheels fitted with 195/55 tyres.
Any ideas as to what they are etc.
Terrible advertising on FB marketplace gives no more information.
Not on this BMW wheels site afaik http://www.bmwstylewheels.com/
Thanks.
Old 01-16-2021, 03:03 PM   #59
Grizz1963
Grizz1963's Avatar
[quote author="@tineca" source="/post/2653307/thread" timestamp="1610753749"]Just for interest
https://www.ebay.co.uk/itm/DROF-JEEP...edirect=mobile
[/quote]
Made me chuckle.
Ever seen a Ford reverse really fast?
Becomes a DROF
This is less finessed and refined than the Jago or Eagle though.
Will be a bargain for someone.
Old 01-17-2021, 04:57 PM   #60
Grizz1963
Grizz1963's Avatar
So today was my birthday
Yesterday was Sally’s and my 100 weeks anniversary
How this girl has not killed me, nobody knows
She had to work from 07.00 which meant being up by 05.00
It may not be apparent, but we do live separately in different homes.
What this meant though, was that I got to spend my day in a way that I really love to spend special days.......
Alone, at home, and working on something I either want to or love to work on.
Sally came around after work at about 5.00pm so I cooked us a quick butter chicken curry on 2 minute rice.
Desert was a 1/4 of a magnificent Maltese’s chocolate cake, and a nice cuppa coffee.
A good day indeed.
Old 01-17-2021, 07:02 PM   #61
Grizz1963
Grizz1963's Avatar
So doing stuff on your birthday that makes you happy?
In my case, today was started off with a quick 6.45 minute School of YouTube lesson on how to remove the headlights, indicators and grille on an S10 Truck in 4’C or 40’F temperature without breaking anything, especially mounting tabs.
Reflection on the iPad screen is the very rough, English style Pebble Dash plaster on my 1921 built home.
Thought I would start with the passenger headlight as its fastening tabs are stuck between the battery and radiator core support and kinda tight for my large hands.
Good start...... bodgeworks always a good place to start.
The indicators, position lights etc may have been changed when the truck had its first UK MOT road test in 2006 where I know it failed due to the lack of side repeater lamps amongst other things.
I will fix these things as I discover them.
Lights out....
Followed by indicators.
Old and new indicator lenses.
And then BURGER !!!!
Indicator bulbs are “pinch pull” or whatever they are called, so the chrome bayonet items @rich had sent were not going to get used here.
Need to get some from the local motor factors.
Grille off and headed for the garage to take apart
So with the grille removed, the next job was to disassemble it it to its final component form for cleaning and processing.
20 years of life as we know it, on the grille that was apparently originally painted body colour in a matte finish has left it looking pretty sorry for itself.
Closer up.
As I kept disassembling, I found more and more bits I did not like.
To that needed bits of attention to get to a look I preferred.
More in a bit.
Old 01-17-2021, 07:46 PM   #62
Grizz1963
Grizz1963's Avatar
After removing the grille, I noticed just how grubby and greasy the centre support was.
The bonnet/hood release cable looked like a challenge for about 15 seconds.
A 13mm socket and 3 bolts later......
Wire brush, white spirit wipe down, two coats of black primer, two coats of Stealth Black Wheel paint, JOB DONE.
Once the paint had dried, I generously applied some spray on White Lithium grease, which once reassembled clearly made the hood release work much more smoothly.
I also put some on the threads of the bolts before returning them to where they came from.
Refitted, release cable reconnected, looked loads better.
You will also notice just how clean the front slam panel actually is, almost no rust, just a bit of staining which could be polished away.
Interesting way the light and house shadow fell at the drivers door. Making the rear look distinctly grey and insipid
Another job that I decided to do today was to “FIX” the front grille badge, at least until I get around to ordering one from the USA or if I can get @craigrk to do a clever 3D print for me.
It had delamination of the gold leaf in the badge, as well as a crack.
Any fix would be an improvement imho.
Final result after about 5 coats.
Happy so far.
It is way past my bedtime.
A few more bits tomorrow for those following closely.
Weekend over too, thanks for checking in.
Later.
Old 01-17-2021, 11:07 PM   #63
Just call me Sean
Happy birthday! I hope you got a conjugal visit too.
It's coming together nicely.
Old 01-18-2021, 05:53 AM   #64
Grizz1963
Grizz1963's Avatar
Thank you very much, I am quite pleased so far.
Conjugal visits are never on when she has been up since 05.00 and working in a factory, lugging 20 liter vats of juice about etc, saying that, I am a good salesman
Final post for yesterdays work done.
When I bought the truck, the bonnet/hood was standing proud on the passenger side by about 8-10mm
The previous owner had told me he had repainted the drivers fender and hood, due to some paint damage and lacquer peeling.
This was not a problem for me, at 20 years old, the truck still looks better than may 3 year olds.
Dennis who has his body shop in St Louis, Missouri has worked on many of these S10 trucks back in the day, had told me these trucks had very little room for adjustment of panel gaps if disassembled or found not to be aligned.
So it was with trepidation I decided to give it a go, to see if I could improve the alignment.
Started with this.
Played with these.
You can see this side fender has been loosened and refitted.
This side got to go down a bit.
And this side keeps me happy for now......
Result.
Happy with that for now.
While cleaning up the stainless steel front grille embellishers I saw these markings on the rear.
The other one showed “top” to define which one fits where.
I am guessing an enthusiast at some point made these up for the truck.
They came up lovely with steel polish as well.
And finally, I had a few challenges from various people about the position of the K&N filter, with people freaking out that it was going to suck up tons of surface water.
So overdrawn on the pic, is where the filter actually sits inside the engine bay.
Not sure if I mentioned, the grille was delivered in a carpark last night, socially distanced and all that.
More as it happens.
Old 01-18-2021, 10:52 PM   #65
Just call me Sean
I would put a stock filter setup back on. The K&N is a dirt magnet, because of the oil.
Old 01-19-2021, 03:52 AM   #66
Grizz1963
Grizz1963's Avatar
Morning Sean,
Living over here in England, these S10’s are rare.
So finding a used original filter system is pretty much impossible, so I am stuck with what I have and will just keeping the maintenance high.
The truck is probably going to do up to 3000 miles per year.
Old 01-19-2021, 08:01 PM   #67
It came out great Rian. Yeah hook up the ole hooter in the S10. Heart attacks or smiles will come your way.
Old 01-20-2021, 03:11 AM   #68
Grizz1963
Grizz1963's Avatar
Morning Bill,
Hopefully smiles, not heart attacks.
Seems I cannot edit that posting, could you please delete it, I have fixed the photos
Thank you @PhilA for grabbing these Chrome Amber bulbs in Louisiana, USA.
Looking forward to getting them into the truck too.
Was in the garage today because I needed a bit of time after they announced redundancies to be effective mid February, and get is a waste of energy, so I went to remove some lights from the wall that will go into the carport until I get the planned LED units up.
Found this claxon style hooter in one of the C10 parts boxes. It may be fun in the S10
I also reassembled the front grille badge.
Looks OK like this.
Closer up.
Absolutely pleased with the outcome so far.
Old 01-20-2021, 01:57 PM   #69
DPowers
One foot in front of the other
DPowers's Avatar
Nice work.
DPowers is offline   Reply With Quote
Old 01-20-2021, 03:42 PM   #70
Grizz1963
Grizz1963's Avatar
Originally Posted by DPowers View Post
Nice work.
Thanks a lot.
I am very pleased, a friend offered me a good replacement badge, but I declined it as I like this now,
Only one small thing done to the truck today.
It will split opinions, do I care??
Errrrmmm..... Nope.
Proud.
Old 01-21-2021, 03:53 PM   #71
Grizz1963
Grizz1963's Avatar
Love the little parcels.
New side repeater lenses landed.
Too big again, do I drill the holes bigger or modify the lenses......
Indicator light bulbs landed too.
These amber units were ordered before @phila got me the chrome ones for the truck.
Can you see what is wrong.
Currently a big thing....
Showing asss.
Another thing I have looked forward to for over a year was to fit one of my custom cast gas pedals.
These will possibly split opinion.
50 years ago guys made these in shop, they were everywhere.
I always loved them, and to me this one, custom cast by my good friend Andy Martin in Terlton near Tulsa Oklahoma is even more valued as it reminds me of my road trips, friends here in theUK and also in America.
A certain nod to great memories.
Life is good, remember that gang.
Old 01-21-2021, 04:32 PM   #72
DPowers
DPowers's Avatar
Love the big foot
Old 01-22-2021, 06:33 AM   #73
Grizz1963
Grizz1963's Avatar
Love the big foot
Thanks.
It certainly divides opinions
[quote author="@mk3rob" source="/post/2650641/thread" timestamp="1609660940"]Definitely get some rust protection on the underside. You can pretty much watch S10s rust!
Mine had 2 rear seats and I have to say you can ride with 3 people in proper comfort! I rode in the rear seat a couple of times after concerts etc when our lass drove and it was really comfy!
The ZQ8 stuff is really sought after and at times not so easy to get hold of so hold onto that! [/quote]
This is the trucks “build sheet” showing its whole DNA. What was put together to create it.
It seems to be pretty special, and I am both pleased and thankful to have been able to tick a box on my lust list.
Read and interpreted by some clever people out there
G80 and ZQ8 are posi track rear and sport suspension
G80 is the LSD, nice.
ZQ8 is a code and a trim package, so your truck is a ‘ZQ8’
They had a factory lowering kit, around 2in or so, springs and leafs. A tighter steering box and some other nice things. The Xtremes got the same setup but got a body kit and some badges.
This is kind of an aside since you're curious about rpo codes, but the guys who have the super sport S10’s look for the B4U code. SS trucks were the first to receive the ZQ8 suspension in 96 until they stopped the SS in 98. The ZQ8 then became its own trim package so to speak
That is the rear end. I think the codes that start with G are the gears for the rear. Not 100% but I think that's what it means. And G80 is a locking or semi locking rear end if I remember right.
GU6 = 3.42 gears
G80 = POSI limited slip
L35 = v6 4.3l vortec
M30 = 4spd overdrive transmission
ZQ8 = Sports suspension package
So living here in England poses it’s own challenges when owning a 20 year old American pickup truck.
Parts for one, and even maintenance as you cannot just drop it off at a local dealer to get things serviced or repaired.
Part of the pleasure than becomes figuring stuff out, researching, asking questions or guys like @pauly over for a coffee pretending you do not need their technical or physical expertise ( just how hard to hit a control arm, or whatever with a 5 pound hammer in winter)
Finding hard to get bits, gets harder when it is a slightly less common model too.
So my truck came with a set of Cragar S/S 2 piece, 17” in 8J wheels, including a spare, 255/45 17 Nankang tyres, all with almost full tread etc.
Perfect wheels for daily use.
But I did not like them, and always coveted the LQ8 5 spoke 16” 8J alloys some trucks came fitted with.
Actually do not recall seeing any in the uK on trucks, ever.
So I was looking out for alternatives, and had kinda settle and made peace with getting thick adapters and going with a set of Range Rover Mondials in 18” or a full set of 17” 7J BMW steels.
I was on an American FB S10 group, asking about tyre choice for the 7J wheels when I got a message from a U.K. based GMC S15 Sonoma owner...... Surprise !
He had owned his for some time, but during the whole 2020 COVID-19 shut down, had stripped it down and was doing a 1939 Willys shark nose truck rebody, he had sold all the body panels except the rear bed and still had a set of 4 LQ8 wheels, with some tyres fitted, tyres could be fried though.
Would I be interested in those as an alternative to the Mondials and BMW steels?
He had not realised these were my personal Holy Grail of wheels, as I was trying to do the truck justice as it is in such good condition. Adding originality as far as I could, with a few cosmetic tweaks,
We have spent about two hours on FB Messenger video (a first for him, he is 67 and not a techie) getting to know each other.
And of course agreed to me buying the wheels from him, not cheaply, but certainly a fair price I was prepared to pay.
Collection based on current lockdown uncertainty to be in the next three years or more.
Stock photos from Google.
And what my truck would look like.
I am super pleased, yes there are other options, other lols, and prettier wheels, but it’s what I wanted.
Looking at these in the USA, even the price per one, wheel plus tax, duty, real world shipping etc makes for an expensive transaction.
Even just the centre caps would not be cheap from eBay and once you get stung with tax and import duties on top of shipping, this was not the route I planned on going.
Just to give an idea of their cost to me.
And an afterthought, speaking of COVID-19
Later guys, back to day job stuff, Friday today.....
Weekend soon.
Old 01-22-2021, 03:07 PM   #74
Grizz1963
Grizz1963's Avatar
I asked for a few pics on one of the S10 groups, great response and chats ensued.
Wanting to see just how much dish they show.
I was not disappointed
MARMITE
See it for what it is.
And lastly, this one, I like.
Yup..... looking forward to these wheels.
Old 01-22-2021, 05:14 PM   #75
Always liked the look of those wheels. Good luck and hope you can fetch them soon Rian
