02-14-2021, 07:10 PM | #1 |
LO5 V8 coolant lines and transmission line
after ages searching think i found the coolant lines for the v8 truck mine are leaking
this the right ones guys? lower oil coolant line https://www.oreillyauto.com/detail/b...ckup-rwd?pos=1 upper oil coolant line https://www.oreillyauto.com/detail/b...ckup-rwd?pos=1 does mention this without axle ratios 2.73, 3.08,3.42,3.73 what is my truck? 1992 standard cab 2 door silverado 5.7 V8 automatic 8 foot bed. looking for the AT line for other side part number for that, only one line that side? |
02-14-2021, 07:19 PM | #2 |
Re: LO5 V8 coolant lines and transmission line
https://www.ebay.com/itm/39217011434...xoCB0oQAvD_BwE
this the correct AT lines i know i have 700r4 tranny by checking RPO CODE. |
02-14-2021, 07:51 PM | #3 | |
I deleted my oil cooler. The crappy push connectors leaked even with new lines. The older trucks had threaded fittings on both ends.
02-14-2021, 07:59 PM | #4 |
ok looking for parts that work any ideas fit this truck..
02-14-2021, 09:14 PM | #5 | |
You probably need 625-139 and 625-140.
02-19-2021, 09:43 PM | #6 |
ok thx seen a few videos now how to correct the issue of the quick connect fittings.
02-19-2021, 10:55 PM | #7 | |
Those are the two options I thought were the best. Delete the oil cooler with an oil filter adapter from an engine without it. I had one. Or use an oil filter adapter from an older truck which has threaded connectors instead of the push ones. I also have one of those, but I didn't want to buy lines so I deleted it.
