Old 03-03-2021, 12:58 AM   #451
Kronald_70GMC
Kronald_70GMC's Avatar
Re: My 1970 GMC Project
Passenger side door jamb is complete. Just a small amount of grinding/welding to do on the bottom of the rocker and this side is completed!
Kyle
1970 GMC "Project Splice"
2017 Silverado LTZ (Daily Driver)
IG: kyle_ronald
Kronald_70GMC is offline   Reply With Quote
Old 03-04-2021, 01:02 PM   #452
NGN
NGN's Avatar
I notice your blue door hinge didn't match all that nice shiny metal work lol.
I didn't want to stop reading I was hooked as soon as I started reading your work. Man real nice work your doing there.
NGN is online now   Reply With Quote
Old 03-04-2021, 02:08 PM   #453
Kronald_70GMC
Haha I have so many different trucks worth of parts going on here. I probably have almost all the colours available on these trucks. I will try to keep the progress coming somewhat steady for you. Thanks for the compliments! Just the motivation I was needing.
Kyle
IG: kyle_ronald
Old 03-08-2021, 12:47 AM   #454
Kronald_70GMC
Ok so I have been trying to get some progress in this past week on the cab. It has been very intermittent due to the fact that I have been on call with work which has had me running around like crazy. I did manage to get half of the roof seam all welded up and started to strip the paint from the roof. Not alot of progress but it's something.
Kyle
IG: kyle_ronald
Old 03-09-2021, 11:50 PM   #455
Kronald_70GMC
I got some good motivation today to get some more done on the cab. Went to see my brother's freshly painted cab after work. So after supper I went out and started attacking the remainder of the old paint on the roof. Didn't quite get it all off but I got a huge chunk done. Hoping to prime the passenger half of the cab in the coming weeks. Sorry for the sideways picture, not sure how to flip them from my phone.
Kyle
IG: kyle_ronald
Old 03-10-2021, 02:10 AM   #456
Scurry67
Looks like your brothers truck is coming along. Before you know it, you’ll be there too. The paint stripping is a big chore, but looks like you’re making good progress. Keep the pictures/progress coming, Ive been enjoying following along
67 SWB First Build
http://67-72chevytrucks.com/vboard/s...d.php?t=777171
Scurry67 is offline   Reply With Quote
Old 03-10-2021, 04:36 PM   #457
Kronald_70GMC
Thanks man! At least the roof is the only paint I have to strip. Quite happy that I bought this cab already blasted. Saved me a ton of time and mess. I'll try to keep the progress steady
Kyle
IG: kyle_ronald
Old 03-12-2021, 10:53 AM   #458
Kronald_70GMC
Finished stripping the paint off the roof last night and continued with welding the roof seam.
Kyle
IG: kyle_ronald
Old 03-12-2021, 08:11 PM   #459
TA_C10
TA_C10's Avatar
Looks good all that clean shiny metal
TA_C10 Stage 1 build - http://67-72chevytrucks.com/vboard/s....php?p=8333444
"It's only money".
TA_C10 is offline   Reply With Quote
Old 03-14-2021, 07:27 PM   #460
Kronald_70GMC
Thank you TA.
Today was a good progress day! I got the rest of the roof seam welded shut as well as ground down. After that, I went back to the passenger side and did the grinding under the rocker. Im very impressed with how my work in flattening the pinch seam at the bottom of the rocker turned out. I was also able to get a preliminary fit of the drivers door and fender all done. It's not horrible, though I did have to bend the window frame out about 1/2" as it was touching the pinch weld and there was no way that I would have fit the weatherstripping in there. As far as gaps go, the upper gaps are quite large and will require addressing once I hit body work stage. The rear gaps are quite nice as are the front gaps between door and fender. Bottom gaps are obviously non exsistant at this time.
My lower fender mounting bolt lined up nicely with where I had assumed the lower pillar would sit so that is good news. Next is both lower pillar repairs.
Kyle
IG: kyle_ronald
Old 03-15-2021, 10:14 AM   #461
OL SKOOL
OL SKOOL's Avatar
The bottom of that rocker looks awesome. I always hated that part hanging down lower then the bottom of the front fender. How much time do you have in removing that. Your cab looks great and a DIY guy. Just read your build through nice work! I will be checking in with you.
OL SKOOL is offline   Reply With Quote
Old 03-15-2021, 02:15 PM   #462
Kronald_70GMC
Thanks for the compliments. It really didn't take that long to do it. All I did was flatten the bottom of the rocker, fold over the inner rocker and thats really all there was to it. The more difficult part was the bottom of the cab corner and that wasn't overly difficult either. Just a small cut and re weld.
Kyle
IG: kyle_ronald
Old 03-17-2021, 12:14 PM   #463
Kronald_70GMC
Last night it was time for the lower front pillar repair. I tried as much as I could to make it look like the factory piece as these things look like junk from aftermarket. As I knew would happen, I had to modify the location of the hole for the fender mount. Not quite ready for install yet but I'd say it's close.
Kyle
IG: kyle_ronald
Old 03-18-2021, 09:23 AM   #464
Kronald_70GMC
And here it is, mostly welded in.
Kyle
IG: kyle_ronald
Old 03-18-2021, 10:43 AM   #465
Chevys4life
You are doing an awesome job on that cab. It will be better than factory!!!!
Chevys4life is offline   Reply With Quote
Old 03-18-2021, 10:57 AM   #466
Kronald_70GMC
Thank you! I sure hope it never rusts again after all this
Kyle
IG: kyle_ronald
Old 03-19-2021, 03:33 PM   #467
Kronald_70GMC
I have the day off of work today so I'm getting stuff done! The front lower pillar is all welded in and ground down. The rear pillar is tacked in and ready to be cut apart on the outside edge and modified to have the curve that is required to weld in the rocker. Hopefully I'll be done the rear pillar by the end of the day. Forgot to take a picture of the rear pillar tacked in.
Kyle
IG: kyle_ronald
Old 03-19-2021, 09:49 PM   #468
Kronald_70GMC
I got the lower pillar patch welded in for the most part. I had to splice the outer edge and expand it 5/16" to line up with the existing panel and make the curve to follow the rocker panel. I ended up having to cut the lip that accepts the cab corner off and run it through my dad's shrinking die to get it to have the curve as well. This is what I was unable to do on the passenger side as I did not catch this until the cab corner was welded in. It isn't nessacary but it will make my cab corner install go better. I did not have time to get the corrected lip welded back on but once I do, I will be ready for cab corner and rocker. Second side is going much quicker than the first.
Kyle
IG: kyle_ronald
Old 03-21-2021, 04:38 PM   #469
Chevys4life
Looks good!!!!
Old 03-22-2021, 11:56 PM   #470
Kronald_70GMC
Originally Posted by Chevys4life View Post
Looks good!!!!
Thanks.
Kyle
IG: kyle_ronald
Old 03-22-2021, 11:58 PM   #471
Kronald_70GMC
The rear pillar is complete. Time to see what sort of fun the cab corner is going to be.
Kyle
IG: kyle_ronald
Old 03-25-2021, 11:04 PM   #472
Kronald_70GMC
I was playing around with cab corner fitment tonight and I gotta say, this side looks promising. I should not have to section it at all. So far I've got it cut down close to size and removed the vertical lip at the bottom. I tried to take some better pictures of my process for that so hopefully that will help if anyone was unsure before.
Kyle
IG: kyle_ronald
Old 03-26-2021, 03:01 PM   #473
chewychevy67
Looks much nicer without that bottom lip. Nice job.
chewychevy67 is offline   Reply With Quote
Old 03-26-2021, 03:21 PM   #474
May70
May70's Avatar
I seen you did what I did on the rocker cap, looks good. Bout time you got back to work!!! haha jk looks good
70 C20 Build link : Project Montezuma
http://67-72chevytrucks.com/vboard/s...d.php?t=794479
How to repair that rusted out 67-72 c10-c30! Please subscribe!
https://www.youtube.com/c/MaycoCustomRestorations
May70 is offline   Reply With Quote
Old 03-26-2021, 03:45 PM   #475
Kronald_70GMC
Thanks guys.
Kyle
IG: kyle_ronald
