Big Block Transmission
I'm running a BBC 454 with a TH400 transmission with the original rear end and 295/50R15 tires. It runs and drives great but it revs pretty high at 60 mph. I believe the factory gears are 3.73. I want to install an overdrive transmission but I've read that a 700R4 won't hold up to a slightly built 454. So I've looked into a 4L80E which would work great but then comes the issue of not having a controller. They want huge money for a stand alone or you can build some kind of homemade one. Anyone have any experience with this?
Thanks Thanks |
![]() Join Date: Aug 2004
Re: Big Block Transmission
Find a 4l80, not the electronic, that will live a lot longer behind your BB than the 700 will
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
Moderator
![]() Join Date: Dec 2012
All 4L80s are electronic. You can get a stand alone controller out of a van, some had separate PCM and trans controllers.
60-66 Nut
I would suggest the 4L80E. Yes the controller and a TPS add up to some money. But you could get away with running a good used 4L80E versus spending $$$$$ having a 700R4 built to hopefully hold up behind a big block. The other issue with an electronic trans is the speedo is electric also. There is no speedo cable connection. There is info online on how to wire a factory ECM to operate an electronic trans as a standalone. That could be an option if you have more time than money
Its pricy but there is the Gear Vendors route.
My 1966 Chevrolet C10 Pickup |
Another alternative is to change the gearing in the rear and run taller tires. This will kill RPM but also probably reduce acceleration some. When I have looked at a 4L80, it was almost a wash with buying a Gearvendors.
#7 | |
Posted via Mobile Device |
You can run the ecm the 4l80e came with
Sloppy mechanic lays out how to do this https://sites.google.com/site/sloppy...ans-controller |
![]() Join Date: Apr 2009
Find Early Diesel Step Van And get Harness And Ecm works perfect
1966 GMC K25 V6 351E Original Utility Truck 2000 C3500 Hot Rod Utility Truck 2003 ROAD KING 100th 124ci 6 Speed 145CI M/P Pro Street FXR 2002 FXDP 2007 2500HD DURAMAX. DD Studio Teamsters / Mechanic Retired GM Master Tech 20 Years Retired Ford Tech 15 Years |
A CableX box works to change speedo from electric to cable
It's Better With Nitro
I run a US Shift TCM with my 4L80E. I think the Quick 2 unit and harness (TPS) are around $600.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes |
Tags |
700r4 |
