Old 04-04-2021, 02:19 PM   #1
FishEyes
72 K2500 Rear Axle Identification.
Hello, Need some help identifying what rear end this is... Looks like a HO52, but not sure the ratio. Its on my 72 K2500 Sierra. I have looked at the identification charts but i don't have any letters in front of the numbers so i am a bit confused. Any help or ideas would be great. Thanks.
FishEyes is offline   Reply With Quote
Old 04-04-2021, 05:10 PM   #2
Joesjunk
Joesjunk's Avatar
Re: 72 K2500 Rear Axle Identification.
There’s a 3 letter code stamped on the top of the 3rd member. If it’s a 70 or older it will be 3 letters.
It’s either 4:10 of 4:57.
72 3/4t Custom Deluxe 402/auto 66k Original paint
71 3/4t 4x4 Custom Deluxe 10k original miles Original paint
71 3/4t Cheyenne 402 70k original paint
72 3/4t 4x4 Custom deluxe
72 3/4t 4x4 Custom deluxe 91k original paint
72 Cheyenne/30 Dually
69 Camaro SS396 4-speed
13 GMC 2500HD Duramax I bought new
05 Jeep Wrangler "Willys Edition" 12k miles (I bought new)
85 3/4 ton 4x4 Scottsdale 33k miles original paint
86 1 ton 4x4 SRW Silverado 454 restored
80 1 ton 4x4 SRW Silverado 9,434 original miles!! original paint
95 GMC 1 ton dually 4x4 my dad bought new
95 GMC 3/4 ton 4x4, regular cab 454, 31k original miles
2002 2500HD 4x4 regular cab 6.0L 67k miles
2002 2500HD 4x4 regular cab 8.1L 28k miles
2003 GMC 2500HD 4x4 regular cab Diesel 93k miles
67-72 Parts for sale
Joesjunk is offline   Reply With Quote
Old 04-04-2021, 06:24 PM   #3
57taskforce
All about them K’s
57taskforce's Avatar
The engine it came with can help shed some light on it but is not a total guarantee. Small blocks had a standard ratio of 4:11 with the inline 6’s having 4:56 as standard I believe. I’m not sure what the GMC V6’s had for standard. That Might help get you in the ballpark at least.
Tyler
'72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879
‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206
'98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's
‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue
‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0
Old 04-04-2021, 07:01 PM   #4
FishEyes
Its has a 350 in it. It must be 4:56 then cause it runs round 3200rpm-3500rpm doing 60MPH down the hwy. Thanks for the info will also check the top of the 3rd member.
Old 04-04-2021, 09:41 PM   #5
jocko
jocko's Avatar
Can you post a picture of the SPID (sheet pasted inside the glovebox door)?
What engine was it born with? Does your VIN start with TK"S" or "E" or "M"?
All these things can help determine what your truck was born with and what it has now. Keep in mind that your speedo may be way off depending on tire size (use a GPS to determine your rpm at an actual GPS speed).
If your truck was born a V8, as Tyler pointed out, your stock ratio would have been 4.10 (in other words, if you still have your SPID, and it has an "E" in the VIN (& 350 appears on your SPID), but NO rear ratio appears on your SPID - your truck was born with 4.10s).
But since who knows WHAT someone may have swapped in over the last 49 years - with GPS speed, eng rpm at that speed, and tire diameter, we can tell you precisely what you have now.
Look fwd to some pics! We like our K20s around here
Old 04-04-2021, 11:22 PM   #6
Mike C
Mike C's Avatar
Unless removed by a PO, the Dana 44 should have a ratio tag under a cover bolt and will match the rear (unless some serious PO stupidity...)
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 04-05-2021, 09:16 AM   #7
FishEyes
The SPID doesn't have the gear ratio on it. It is a TKE, and the tires are 265 75 R16. I will do the GPS test when i get home on Wednesday, and get some pics up Wed eve. Thanks again.
Old 04-05-2021, 09:18 AM   #8
FishEyes
Thumbs up Re: 72 K2500 Rear Axle Identification.
Great idea never thought of that.
Old 04-05-2021, 09:33 AM   #9
MJN
MJN's Avatar
Here is where the rear axle info is stamped on the Eaton third member
'51 South Bend Model "9A"
'56 Chevy 3600 NAPCO
'08 GMC Envoy Denali
'12 GMC Sierra 2500HD Denali
'17 GMC Yukon XL
VCCA member #58596
http://www.nohrco.com
Old 04-05-2021, 01:06 PM   #10
57taskforce
All about them K’s
If it was a small block truck originally and no spid ratio call out, it was born with 4:11’s. Hard to tell what has been done thru the years but probably a reasonable bet it’s got 4:11’s.
Tyler
Old 04-05-2021, 01:33 PM   #11
MJN
MJN's Avatar
My book shows 70 and newer the codes are 3 letters and 69 and older are 2 letters.
'17 GMC Yukon XL
VCCA member #58596
Old 04-05-2021, 02:30 PM   #12
DeadheadNM
Carpe manana
DeadheadNM's Avatar
It's an Eaton axle but just a clarifying question. Didn't GM use a D60 for K2500s rather than the Ho52 seen with K20s?
Old 04-05-2021, 04:32 PM   #13
Fbks_Cruiser
Fbks_Cruiser's Avatar
My 1972 K2500 has Dana 60 in the rear. Maybe HO52 is a Canadian thing eh?
1972 GMC K2500 Super Custom
Matt
Fbks_Cruiser is offline   Reply With Quote
Old 04-05-2021, 05:38 PM   #14
gmc684x4
I have two k20s both eaton a c20 and c30 d60 diffs
Stock 350 k20 trucks are usually 410 gears both mine have a lockers the other is a straight 6 4.57 gears
gmc684x4 is offline   Reply With Quote
Old 04-05-2021, 06:36 PM   #15
FishEyes
LOL, the ol girl was born in Fremont, CA.
Old 04-05-2021, 10:25 PM   #16
Joesjunk
Joesjunk's Avatar
You are correct Pete, I missed the GMC part. I don’t think I have ever seen an HO in a GMC before.
Old 04-05-2021, 11:53 PM   #17
FishEyes
So the Dana 60 rear end was how the K 2500 came from the factory?
Old 04-06-2021, 06:52 AM   #18
71250
Not to hijack the thread.. but I have 71 250, so I’m guessing the ratio is a 4:56?
71250 is offline   Reply With Quote
Old 04-06-2021, 07:10 AM   #19
71250
Old 04-06-2021, 08:42 AM   #20
Joesjunk
Joesjunk's Avatar
To the best of my knowledge GMC K trucks had Dana 60 rear axles and the Chevy had the Eaton.
Do you have a picture of your option sticker?
Old 04-06-2021, 08:58 AM   #21
FishEyes
I will get a pic put up tomorrow. There is not any axle info on the sticker thought. Thanks
Old 04-06-2021, 03:08 PM   #22
MJN
MJN's Avatar
I haven't seen this mentioned yet but have you had the cover off recently? Easy enough to pull the cover, count the gear teeth and you'll have your ratio, a little inspection and fresh oil.
'17 GMC Yukon XL
VCCA member #58596
Old 04-08-2021, 03:41 PM   #23
FishEyes
Thanks for all the help. Got the letters off the top of axle. RJH which points to 4:10 gears. Thanks for the tips.
