Old 04-21-2021, 10:43 AM   #1
ChevyCheyenne71
C30 Dually LB convert to Shortbed
I have a 157 inch wheelbase chevy Cheyenne dually. I want to convert it to a shortbed stepside. Has anyone done this?
Do you have any pics, threads or any info on a transformation like this?
ChevyCheyenne71 is offline   Reply With Quote
Old 04-21-2021, 11:56 AM   #2
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Re: C30 Dually LB convert to Shortbed
I know it's been done many times. Does your truck currently have a bed?
Ryan
1969 Chevy milk truck
Old 04-21-2021, 12:34 PM   #3
ChevyCheyenne71
No i remove the old one and i just bought a short Stepside bed with custom hole for the dually
Old 04-21-2021, 08:23 PM   #4
BLAZERMAN
Currently Blazerless
BLAZERMAN's Avatar
I thought of doing it using a long stepside bed, the problem is the higher kickup in the 157" chassis. I believe its a 2" higher kick so you will have to raise your cab that amount for body lines to match up. It would be much easier with the 133" C30 chassis which shares the same amount of kick as the 115"/127" chassis.
Do you have a pic of your custom bed? Im not sure what you mean by a hole for the dually?
1972 C/30 133" W.B. C&C
1970 GMC 3500 157" W.B. single wheel C&C
BLAZERMAN is offline   Reply With Quote
Old 04-21-2021, 08:53 PM   #5
Mike C
Mike C's Avatar
I agree with Blazerman. You need to find a 127' longbed frame with running gear and cut it down. Should be fairly cheap and easy score. May find someone who wants to build a C30 hauler and they would appreciate the uncut frame and running gear.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 04-22-2021, 07:46 PM   #6
Jeff's bowtie's
If you want a one ton frame find a longhorn frame and cut it down 18” works well. Here is a longhorn frame I cut down and then converted to a 4x4 with one ton axles out of a 81 K/30 square body
Jeff's bowtie's is offline   Reply With Quote
