Old 04-21-2021, 04:40 PM   #1
Loco83
Loco83's Avatar
Charcoal cannister, 1983 Silverado
Looking for a canister as mine has been contaminated with gas, truck started running rough and had gas come out one of the lines going into the canister, this is the Part# 17061005BT. All the parts places have them discontinued, engine is a 305. I purged the canister with shop air and put it back in and the truck runs normal, just a short term fix till I can get a new canister
Loco83 is offline   Reply With Quote
Old 04-21-2021, 06:26 PM   #2
Loco83
Loco83's Avatar
Re: Charcoal cannister, 1983 Silverado
Found one on FleaBay after reading TKCR post,
http://67-72chevytrucks.com/vboard/s...d.php?t=664523
Old 04-21-2021, 07:32 PM   #3
TKCR
TKCR's Avatar
Wow, that was an old post too. But happy to hear you found one.
TKCR is online now   Reply With Quote
Old 04-23-2021, 05:44 AM   #4
LT7A
I didn't realize they could go bad. It seems like it could return to normal service after drying it out. I'm willing to get an education here. I thought that the canister was a place for unburnt gas vapor to to be captured when a vehicle is shut off and then drawn back in to be burned once the vehicle is running again. So I would have guessed that your problem is in the return line. That the vapors aren't being drawn off and burned.
Old 04-23-2021, 06:43 AM   #5
cadillac_al
For future reference, I saw a video once on how to rebuild them. Must have been on youtube.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
cadillac_al is online now   Reply With Quote
Old 04-23-2021, 08:46 AM   #6
TKCR
TKCR's Avatar
I remember looking that info up myself about rebuilding or whatever. For me, the price of the new canister was worth not going thru the hassle. For the most part those canisters looked to be somewhat sealed.
Old 04-23-2021, 05:18 PM   #7
Loco83
Loco83's Avatar
Yup mine was sealed but the 1983 GM shop manual shows it as being open bottom with an air filter???. Turned mine upside down and drained all the fuel that was in it then blew air thru it to dry but mini chunks of charcoal started blowing out so I knew it was toast
Old 04-24-2021, 04:52 PM   #8
Pontiac1976
Pontiac1976's Avatar
If you have Charcoal canister and it's not broken from these year and it not to dirty in side or too much oil has got in to it.
You can save the charcoal by trying to dry it out but with controlled air pressure to lower the air going in. (low air pressure just enough for air get throw but not blow up the charcoal up and out.) You could try like a fish air pump maybe. I would do this out in hot day in the sun do this a few times let it sit for a week. Then make sure it got a new filter keep clean.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
Old 04-29-2021, 12:18 PM   #9
Loco83
Loco83's Avatar
New canister delivered yesterday, holding off hooking up till I go in for her smog test in June.
Old 05-03-2021, 11:23 PM   #10
rodstored-72
chevy truck fan
rodstored-72's Avatar
loco, good luck with the emissions test. In my build I am keeping the emisions (as much as needed here in AZ) luckily my truck still had the OG canister...
rodstored-72 is offline   Reply With Quote
Old 05-04-2021, 08:57 PM   #11
71gmcC15
71gmcC15's Avatar
Why even mess with it and delete it. Plug of the vacuum lines and put a filter on the line coming from the tank. and throw it way. That's what I do anyway. Thare not needed unless you have emissions whare your from. Which if you do I'm sorry.
( second times the charm) 71 gmc c15 307 sbc 373 rear gears positrac sm 465 trans. ( not listed on spid but is original )
94 chevy k1500 350 tbi 373 rear gears 4l60e one wheel peel. Gutless
07 gmc sierra classic rcsb 4.3 lt 5 speed w/t
04 chevy Silverado 1500 ext cab 5.3 4l60e.
81 chevy Scottsdale k10 muncie sm465 Np208 10 bolt 8.2 ( Old Green)
71gmcC15 is offline   Reply With Quote
Old 05-04-2021, 10:35 PM   #12
Loco83
Loco83's Avatar
No can do, the Smog NAZIS here go over the engine bay with a fine tooth comb, If you don't pass the visual test it's over let alone having to run the truck on the rollers.
Old 05-05-2021, 09:24 AM   #13
SCOTI
SCOTI's Avatar
And there-in lies the stupidity of the whole process. It can barely pass the actual emissions test by less than .05% based on 80's standards & have every little do-dad it's supposed to & they'll approve it.
But... It could actually burn much cleaner on actual emissions (like a newer vehicle) yet be failed because a 'visual' inspection says a specific part is missing. So even though that EGR isn't there any more & it pollutes half as much as the standards require, it's a fail.
You know.... Saving the Planet & all.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 05-10-2021, 11:59 AM   #14
rodstored-72
chevy truck fan
here.. here...
Old 05-28-2021, 07:01 PM   #15
Loco83
Loco83's Avatar
Well the old girl passed her smog test, gave her a good tune up, cap and rotor, plug wires and plugs. oil change and new air filter, i'm sure the new charcoal canister helped as the old one was full of gas. Good for another 2 yrs.
Old 05-28-2021, 07:52 PM   #16
TKCR
TKCR's Avatar
Congrats on passing the smog test
Old 05-28-2021, 08:44 PM   #17
Gregski
Gregski's Avatar
excuse me while I go hug my pre SMOG '74 Dime
I feel you my California brother
Gregski is offline   Reply With Quote
Old 05-28-2021, 09:34 PM   #18
Loco83
Loco83's Avatar
Old 05-29-2021, 11:01 AM   #19
Pontiac1976
Very good to hear that your good for another year.
