08-29-2021, 07:04 PM | #601 |
Re: My 1970 GMC “Project Splice”
I'm so close I can almost taste it to being done with marglass. I'm hoping one more evening and I should be into the regular filler. I have something on the way to help with getting it like glass so hopfully that will show up soon as well.
09-05-2021, 06:43 PM | #602 |
Woo hoo! Finally done with marglass for the time being. I also managed to get a coat of regular filler across the whole roof. Wow, I figured it was straighter Going to need to get some other grits of sandpaper now. One more skim across the roof followed by a good blocking with 180 and the roof will be ready for primer. Too bad I still have the rest of the cab to fill before primer.
09-06-2021, 04:38 PM | #603 |
Great job on your cab!!!
09-06-2021, 11:21 PM | #604 |
09-06-2021, 11:47 PM | #605 |
Alright so I'm a bit rusty at this whole bodywork thing. I put down another coat on the roof and sanded it too far with 80 grit and still ended up low. I'm definitely not a professional here by any means. I ended up putting a guide coat down to get the 80 grit scratches out which is how I realized I was low in spots. I didn't have any guide coat on hand and the local body supply store was closed for the holiday so I picked up some black chalk from home depot. Worked great and a fraction of the price. Just sprinkled in on and spread it around with a chunk of foam. I got a third coat of filler on the roof including the edges this time. I definitely recommend completely coating the panel you are working before sanding, it worked much better that way instead of trying to feather the edges. I now have the roof sanded in 80 grit but this time I left it just above finish so that I will be able to sand out the 80 grit scratches with 180 before burning through and getting high spots. It's hard to see in the 4th picture but the black chalk shows my low spots. 5th picture is how it is sitting now. Ready for more guide coat and blocking with 180 grit.
09-07-2021, 08:32 PM | #606 |
Looks great! I’m sure your arms are jello by the time you’re done. It’ll pay off though with nice straight panels. Keep it up, I’m enjoying the updates.
09-07-2021, 08:50 PM | #607 |
Thanks man! Great to know that people are following along. The arms were definitely a little sore after all that sanding
09-07-2021, 11:35 PM | #608 |
Got some goodies today from Big Kid Blocks. I had previously ordered a wicked door gap tool from them and had been looking at there blocks for a while as well. I finally pulled the trigger as I needed some blocks that can follow curves and these look awesome. I'm still waiting on one piece as it was back ordered but I'm excited to try these things out. The one with the spheres is made to follow curves. There is another one that is shorter for curves but that is the one back ordered. Too bad I won't have time to play with them till next week.
Second picture is the door gap tool which looks deadly and I'm excited to use it as well. |
09-19-2021, 12:24 AM | #609 |
Wow what a rough go I had last week. I ended up feeling a bit sick last weekend which rolled into a fever and a wicked headache. I got tested and thankfully it was not covid. Today is the first day since Tuesday that I was able to get outside and do anything. The rest of my week consisted of lying in bed with ice on my head for the headache, nothing else worked. So I finally had a chance to try out the new blocks tonight. What a diffrence! I was still quite a bit further away than I figured from having the roof minty. Felt good to get something done.
09-26-2021, 08:16 PM | #610 |
These blocks I bought are the answer! I am in my final sand on the roof..... finally . It definitely should not take this many coats if anyone is wondering, I have been trying to get back into body work after several years. I am finding with these blocks, being that they have flex, it is very difficult to oversand, which has been my biggest mistake so far. The pictures don't look much diffrent week to week here but that should change now that I'm getting back into the groove. Progress should increase quite rapidly. It will also be much easier not having to work off of ladders and such once I'm done the roof. This is the boring stage so hopfully I can keep everyone's interest.
09-26-2021, 09:51 PM | #611 |
I'm still in
Nice work I am all about buying the right tool for the job at hand.
09-26-2021, 10:18 PM | #612 |
Right on man! Thanks
10-03-2021, 08:18 PM | #613 |
Roof is finally ready to prime. The new blocks showed me how much of a liar the old block was. Notice the several diffrent layers of filler I burned through around the edges. After I finished blocking the roof, I used a technique that I learned from an old school body man that was in the industry for pretty much his whole life. That technique is to have a piece of paper between your hand and your work while doing a feel over for waves and such. It makes a huge difference in being able to feel the imperfections.
I got some filler around the back window as well and started blocking that out. Much less standing on steps and ladders now and that is nice. |
10-04-2021, 12:56 PM | #614 |
Man this thing is looking good.
Doing bodywork can really suck. When I do it I wear a latex glove. This seems to help me to feel the imperfections and helps your hand to slide smoothly over the surface. I am almost done with the welding on my sons cab. Shaved the hump on the firewall where the heater box was. |
10-04-2021, 02:03 PM | #615 | |
10-04-2021, 02:54 PM | #616 | |
Here's a few of where it is now. The passenger side firewall has been shaved where the bump out is and also the hole where the blower motor was. [IMG][/IMG] [IMG]capture[/IMG] |
10-04-2021, 03:36 PM | #617 | |
10-05-2021, 06:52 AM | #618 |
Thanks and you will be before you know it. This is a couple years on/off to get it just to this stage.
10-07-2021, 12:07 AM | #619 |
Got some more filler work done tonight, I'm almost done with around the back window, bit more sanding, a few small touch ups and then on to the the back wall of the cab. Looks like so much fun..... Also the paint divider trim pins also make things fun.
10-07-2021, 12:26 AM | #620 |
Looks good! Crazy to think how much of that stuff ends up on the ground. Are you going to do the entire back of the cab? From my experience, it was a real pain, especially for an area on the cab that no one ever sees. Keep it up!
10-07-2021, 12:54 AM | #621 |
Oh man I've put so much on the ground already. I've used over half the gallon to get to where I am. I am going to do the entire back of the cab because I am far too much of a perfectionist and it will absolutely drive me crazy if I don't do it. I will keep the updates coming as quick as possible, for some reason I get quite motivated when it comes to bodywork, I don't know if there is anyone else out there who actually likes bodywork stage.
10-07-2021, 08:30 AM | #622 | |
I assume you are going to run the factory trim. I ground the pins off because we are not going to run any trim. Keep the pics coming. |
10-07-2021, 09:16 AM | #623 | |
10-07-2021, 02:03 PM | #624 | |
No idea what my son's is going to be painted yet. Since it's being built mainly as a drag truck he's less interested in paint than go fast parts. LOL But since I have access to a full bodyshop, spray booth and all the tint colors on a paint machine I refuse to let it have a crap paint job. |
10-07-2021, 02:07 PM | #625 | |
