Old 03-30-2021, 07:26 AM   #1
richards72chevy
richards72chevy's Avatar
Would this be an ignition switch problem?
Yesterday morning I started my truck and went back inside to finish up getting ready for work.It was idling for about 5 minutes put it in reverse and it died.I restarted drove to work no problems.This morning started it drove it to work noticed that my dome light didn't come on like it usually does when I turn it off it wouldn't restart for the first two times I turned the key switch then my interior and dash lights came on and it fired right up.I am not sure what else it could be besides my ignition switch.I would appreciate if you guys think it could be any thing else.It is 02 silverado with close to 258,000 miles on it.
richards72chevy is offline   Reply With Quote
Old 03-30-2021, 09:03 PM   #2
Re: Would this be an ignition switch problem?
I had a similar issue on my 2005 Silverado. It was the module in the door latch, that goes to security/body model. It wouldn't recognize the Dorr was closed and caused battery to run down or wouldn't allow it to start
1981 GMC High Sierra SWB Stepside
Board Vendors
It's scary when you start making the same noises as your coffee maker.
Old 03-30-2021, 09:30 PM   #3
richards72chevy
Thanks I will have to check that out.My battery isn't running down but I do have the security light.I guess there is also a relay for the starter that can cause the problem I'm having.
Old 03-31-2021, 09:05 AM   #4
hatzie
Moderator
hatzie's Avatar
Doesn't crank or doesn't start?
My truck is cranky about cranking. I narrowed it down to the connection from the starter relay to the Crank terminal on the starter. I think it may be the fuse/relay block but I haven't torn into it yet.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
hatzie is online now   Reply With Quote
Old 04-01-2021, 07:12 AM   #5
richards72chevy
It doesn't crank.I had no problems this morning.I will probably check and clean all of my grounds this weekend.That is the cheapest easiest thing to do first.If it still continues I will swap around the relays.
Old 04-01-2021, 08:43 AM   #6
hatzie
Moderator
hatzie's Avatar
Swap the DRL and Starter relay. It takes a couple seconds.
Old 09-20-2021, 07:10 AM   #7
richards72chevy
Where is the DRL?
Old 09-20-2021, 12:53 PM   #8
hatzie
Moderator
hatzie's Avatar
Daytime Running Lights. Any of the ISO 280 relays in the box are good candidates to play swaptronics with.
Old 09-23-2021, 07:12 AM   #9
richards72chevy
Thanks I will have to try that if the problem comes back again.
Old 09-23-2021, 07:25 AM   #10
richards72chevy
Unfortunately my truck is doing this now as well.They say the grounds can be an issue on these trucks.Some say the problem is in the starter wearing out.My engine just barely turns over after driving a long distance when I try to restart it.Let it cool down and fires right up.Also on the right side of the engine is a fuel pressure regulator you can unplug the vacuum line going to it if has fuel dripping out it's bad.Mine has no fuel dripping out.
Old 09-23-2021, 05:12 PM   #11
hatzie
Moderator
hatzie's Avatar
Check the main ground connections but slow hot crank really sounds like a starter problem.
Old 09-27-2021, 09:27 AM   #12
richards72chevy
Took the starter off and took to the local business that rebuilds them.He said let's do a load test on the battery first.I think to myself ok battery is not that old but this guy knows more than I do.I have a bad battery.He said that's what's causing the slow crank.Im not for sure if that could have caused my truck to randomly shut off I forgot to ask him about that.
Old 09-29-2021, 04:01 PM   #13
kev2809
low n' slo
kev2809's Avatar
to me it sounds like a bad battery...or loose terminals. if that battery is over 2 years old (which is usually right after the warranty) then I wouldn't trust it anyways
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is offline   Reply With Quote
Old 11-13-2021, 07:43 AM   #14
richards72chevy
Slow crank problem went completely away and the random shutting down hasn't happened again.Crazy thing is I had random slow cranks shortly after putting in that battery.Even on cold mornings it fires right up.I think the battery was under two years old but of course AutoZone didn't have it in it's system.The guy that tested my starter and battery said that battery quality has went to crap over the last year with all battery brand's.
Old 11-13-2021, 08:43 AM   #15
hatzie
Moderator
hatzie's Avatar
Sounds like that battery was bad right from the get go.
I've been less than impressed with quality from all of the big three battery outfits (East Penn, Johnson Controls, & Exide) in the last half decade.
I went through three batteries when I replaced the 10 year old Delco battery in my Impala in 2018.
I'm not sure who was making batteries for AC Delco in 2008 but I want more of those. Two new batteries failed in about a week and the third made it five months. I went through the charging system with a fine tooth comb four times and found nothing amiss. Crossing my fingers that this one makes it through its' third winter.
If I have another failure I'm going to consider a building a Maxwell supercapacitor pak and carrying a Lithium Ion jump pak. They're the closest thing we have to Phillip Jose Farmers' batacitor.
Copyright ©2000 - 2021, vBulletin Solutions Inc.
Copyright 1997-2020 67-72chevytrucks.com
