08-12-2021, 01:19 PM | #1 |
newly minted old timer
temporarily plugging a power steering pump
I have my project engine (2018 l96 out of an express van) set up on a run stand. I would like to find an easy way to allow me to run the motor without bypassing the pump. can the pump outlets just be plugged, fluid added, and ran? or does it have to circulate? can the lines be plumbed together if so?
____________________________________________ 72 c20 longhorn 65k org miles and counting! 69 k10 Suburban |
08-12-2021, 04:44 PM | #2 |
Re: temporarily plugging a power steering pump
My .02 is to loop them. I think as long as the pump is turning it's putting out some level of pressure. Maybe a -6 90 degree out the pressure side looped to the return nipple?
08-13-2021, 09:02 AM | #3 |
Sounds like a bad idea to me. By looping you will be pressurizing the return side of the pump which normally does not see high pressures.
08-13-2021, 09:43 AM | #4 |
How long do you plan on running it ? Just pull the belt .
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
08-13-2021, 10:34 AM | #5 |
I would just rather plug it.. can anyone think of why not?
the engine will run for a while..dont want to mess with the belt
08-13-2021, 12:47 PM | #6 |
I'd just loop it back into the lid. It may make a mess since it's wide open and those vane pumps can move a lot of fluid when there's no restriction to the pressure.
I would zip tie it and also have a rag to keep the opening covered since it could be "splashy" in there.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
08-13-2021, 04:36 PM | #7 |
Another thought would be get a steering box that could be temporary and plumb the lines like normal. A used box even it leaks a bit.
08-13-2021, 10:08 PM | #8 |
loop it. thats exactly how it flows when you're not turning the ps box.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205 86 k30, 89 diesel burb, 76 gmc pathfinder 71 longbed 5.3 4l80 http://67-72chevytrucks.com/vboard/s...d.php?t=522535 |
08-15-2021, 09:09 PM | #9 |
You can not just plug the outlet. Do. Not. Do. That.
Either feed the outlet back into the return port, or run the engine with the belt off. |
10-04-2021, 11:56 AM | #10 |
just a follow-up on this.. i have started the motor and connecting the hoses together works just fine.
https://www.youtube.com/watch?v=HCxUIWmWNQA
10-05-2021, 05:56 PM | #11 |
low n' slo
that thing is so quiet sounds nice
67 1/2 ton Suburban - Project DRGNWGN. Build thread -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
10-06-2021, 01:22 PM | #12 |
I looped the pressure side back into the return and filled it with fluid....worked fine.
I'm using braided PS high pressure hose and stainless -AN fittings 2002 LS1
1967 C10 Step side 1968 C10 Step side 1970 Chevrolet K/5 Blazer 1972 Chevrolet K/5 Blazer ............. |
10-10-2021, 02:19 PM | #13 |
MT dave, what power steering pump did you use? The van's come with a remote mounted reservoir, correct?
69 C10 fleetside long bed - 6.0/4l80E in progress |
10-13-2021, 08:34 AM | #14 |
nope the motor came with it right out of the van.
