Old 08-25-2021, 11:44 AM   #1
6600DURAMAX
6600DURAMAX's Avatar
LS Headers on Blazer K5 4X4 Frame
What are the header options for an LS on a Blazer K5 4X4 frame - only want to buy one set. Considering buying set now before frame goes to powder in case of minor clearance issues.
Was hoping to just buy a set that fit, no questions asked
Wanting chrome/ceramic coated
thanks guys
1972 K5 Build - plans - LS3-6L80e-One Tons.....
1971 CREWMAX Build.....at body shop for couple more years
6600DURAMAX is offline   Reply With Quote
Old 09-04-2021, 02:24 PM   #2
6600DURAMAX
Re: LS Headers on Blazer K5 4X4 Frame
TTT
no responses ….
Old 09-04-2021, 05:00 PM   #3
greentruck
greentruck's Avatar
I used these Doug Thorley headers with no fitment issues.
http://www.dougthorleyheaders.com/th...-headers_15738
https://www.summitracing.com/parts/dte-324y-c
I also used the same Dirty Dingo motor mounts that you did. Mine is a K-10 and not a Blazer but I think the fitment would be the same? Their description calls out Blazer and Jimmy so they should work.
For some people driving is one long series of corrections...
Last edited by greentruck; 09-04-2021 at 05:12 PM. Reason: out of stock in original link
greentruck is offline   Reply With Quote
Old 09-04-2021, 06:19 PM   #4
Richard
Used Doug Thorley as well but the 1 7/8" mid length. Do not like the look of exhaust hanging under a frame. Required minor trimming on top rail. Can see them mounted in page 7 of my build thread. I am using the Pacific Fab crossmember. As noted in my post, there is minor interference with passenger side shackle bolt. Probably could be rectified by trimming bolt.
http://www.dougthorleyheaders.com/th...-headers_15737
I purchased from Summit for free shipping
https://www.summitracing.com/parts/dte-323y-c
Richard
Old 09-07-2021, 05:48 PM   #5
6600DURAMAX
Thanks guys..... that gives me some solid options
Old 10-19-2021, 10:50 PM   #6
6600DURAMAX
Anyone running Schoenfeld Headers on their K5 of K10 ??
Old 10-19-2021, 11:08 PM   #7
6600DURAMAX
Can I get a few installed pic at some point
thanks
Old 10-23-2021, 01:20 AM   #8
Richard
thanks
There are some in my build thread starting on page 7
Richard
Old 10-24-2021, 08:36 PM   #9
6600DURAMAX
You mentioned some inference with the frame... is this something you have a pic of? Bout ready to send frame to powdercoat but don't have the headers yet. This might be a problem. Plus I am running leaf springs..... how much interference was there with the leaf springs ?
Old 10-27-2021, 12:21 AM   #10
Richard
Just saw this yesterday. Can take the requested pics for you tomorrow as I will be working on the truck
Richard
Old 10-27-2021, 02:52 PM   #11
Acregger
I actually used the blackhorse racing headers in a K10 with no issues at all
Acregger is offline   Reply With Quote
Old 10-27-2021, 03:08 PM   #12
6600DURAMAX
Any part number on the Blackhorse headers - don't see them on their website? Any pics ? How the quality? - wouldn't expect it to be to good for the low price?
Richard - any luck with those pics? I can PM you my contact info if easier
thanks guys
Old 10-28-2021, 02:22 AM   #13
Richard
Working on truck all day. Did get some pics for you hope they help. Left and right header to frame and passenger side shackle bolt. Should be able to trim bolt or reverse to eliminate interference, not as bad as I originally thought. I moved motor back almost 1" from test fit. So I will need to remove some more of the upper frame. You can see it is not a lot. Only removed maybe 1/4" and just need a bit further back.
Richard
Old 10-28-2021, 08:27 AM   #14
6600DURAMAX
Thanks Richard those do help a bunch - I have an issue with sliding motor back right now. I am running a 6L80 with 208 and already have a huge rear driveshaft angle, sliding the motor back will only make it worse. Driveshafts were ordered yesterday so hopefully I wont need to slide it.
Old 10-30-2021, 06:58 AM   #15
Acregger
thanks guys
I got the blackhorse headers on ebay. They fit good and I had no issues. They seem pretty well made, I am sure they are lesser quality then others but I figured if they didn't work or needed modified I was out less money
