10-05-2021, 11:16 PM | #726 | |
Re: Project 67 DRGNWGN - 67 Burban!!
10-06-2021, 07:56 AM | #727 |
low n' slo
ya having no luck selling this yet though. I don't have Facebook so I posted on Craigslist, 5 miles, and offer up...no luck yet. I'm getting the front frame painted now along with the crossmember but that will be done by the weekend.
67 1/2 ton Suburban - Project DRGNWGN. Build thread -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
10-06-2021, 10:07 PM | #728 |
low n' slo
cleaned it up the best I could and brushed on some mastercoat coating. going to work on the crossmember the next couple days and hope I can get it on by the weekend
10-07-2021, 12:40 AM | #729 |
Looking good. My project is kind of in the same place right now. It would be nice if they went back together as fast as they came apart
10-07-2021, 08:29 PM | #730 |
low n' slo
lol yup so easy to rip apart and the next thing I know I have parts laid across my yard for a year
10-15-2021, 12:45 PM | #731 |
low n' slo
some of my pics don't want to upload....but anyways. got the crossmember sanded down and painted up and back on. 60 bucks in new grade 8 hardware
not sure which route I want to go down now, haven't had any bites on my donor truck so my motor issue is still at a stand still.
10-25-2021, 08:16 PM | #732 |
low n' slo
well, got the old ugly truck and motor sold and pulled in the replacement. 2002 tahoe, dash says 211k. waiting on my jump starter I ordered so I can try to crank it and see how it sounds. pulled off the wrecked stuff already. this one looks so much cleaner than the yukon one
10-26-2021, 10:43 PM | #733 |
Nice to hear the old one sold so you can keep moving forward��
10-27-2021, 06:54 AM | #734 |
low n' slo
ya I slapped a battery on it and cranked it and it sounds pretty good. couldn't drive it since the trans lines were throwing oil everywhere lol.
gonna pick at it over the week and hopefully have it pulled by next week
10-31-2021, 05:39 PM | #735 |
low n' slo
got it out and on the stand. started the minor teardown. going to order the gaskets mentioned above. hoping to have this motor dropped in within a few weeks but we will see.
10-31-2021, 05:41 PM | #736 |
low n' slo
little grimey in the front and also looks like it had an oil pan gasket leak
11-01-2021, 10:43 AM | #737 | |
The Older Generation
Mine was the same way. I got lucky, I cleaned it all up and re-tightened the pan bolts and it quit leaking. Mine had some modifications done to it before I got it and I wonder if they forgot to go around and double check the bolts. I don't think a few weeks is out of the question for a timeline unless you have trouble getting something you need. Keep us posted on your progress. LockDoc
11-01-2021, 01:41 PM | #738 | |
low n' slo
11-01-2021, 07:53 PM | #739 | |
Good deal. My engine was an LS1 so I didn't have to change anything on it. LockDoc
11-01-2021, 08:11 PM | #740 |
low n' slo
only reason for the pan change is because the air ride. believe the pan will hang too low.
11-02-2021, 02:04 PM | #741 | |
Yes, I'm sure it would. LockDoc
11-10-2021, 01:14 PM | #742 |
I am chasing oil leaks on my 03 Yukon LS. Do you have any good pictures of the LH side of the engine?
11-10-2021, 05:21 PM | #743 |
low n' slo
little update got the motor cleaned, painted, and resealed for the most part. going to work on getting the headers on, motor mounts, then fix the leaky seal on the trans and they should be ready to mate back up
11-10-2021, 05:22 PM | #744 |
low n' slo
sure what exactly are u looking at? I can snap some pics and post em
11-12-2021, 09:18 AM | #745 |
I am leaking a lot of oil. Are there any sensors or anything else on the LH side where it could be coming from. I already replaced them crank sensor seal.
11-12-2021, 11:52 AM | #746 |
low n' slo
the only sensor on that side is the coolant sensor for the ecm. is your leak coming from the top? only thing I can think of is valve cover or oil pan...?
11-13-2021, 09:20 AM | #747 |
Thanks I know the vale covers are leaking and the rear main seal too. I am just trying to get all of the parts lined up so I only have to tear it down once.
11-13-2021, 02:20 PM | #748 |
low n' slo
looking more like a motor
11-13-2021, 02:55 PM | #749 |
Looking good!
11-13-2021, 03:22 PM | #750 |
low n' slo
thanks my drill bit came in about 30 minutes ago so I drilled and tapped the head....this made me nervous lol
I'm not sure if the stock 67 sender will work though. when I get to the cluster, I will be modding it like ls1nova did with the s10 speedo. I will be adding a clock and camaro tach, and delete the circuit board and make a harness. so not sure if the idiot gauge temp sender is used or the 5 hole cluster temp sender. I believe they are 2 different ones?
