11-27-2020, 03:44 PM | #1 |
Front bumper mounted spare tire
Got a 94 k2500 with a slide in camper and getting to the under mount spare is a pain thinking of building a mount for the front bumper. Anyone done it ? Any issues to worry about? Any pics?
11-27-2020, 04:01 PM | #2 |
Re: Front bumper mounted spare tire
Only thing I have heard of is the cooling/overheating possibility. The tire will block most of the air flow from going directly thru the radiator, so make sure you leave a decent gap between the spare and from of grill so air can get into the radiator.
Bill 1970 Chevy Custom/10 LWB Fleetside 2010 Toyota Tacoma PreRunner SR5 Double Cab - DD Member of Louisiana Classic Truck Club (LCTC) Bill's Gallery Life isn't tied with a bow, but it's still a gift. Live simply. Love generously. Care deeply. Speak kindly. Leave the rest to God! Last edited by Palf70Step; 11-16-2021 at 05:11 PM. |
11-27-2020, 10:29 PM | #3 |
Used to see just such a spare tire mount style on the earlier square body trucks in the late 70s into the 80s. Was quite popular then with the amount of bed mounted cab over campers of the times. Good advice about the spacing out from the grill for air movement. Be sure you have a good radiator/fan shroud and proper fan/clutch and water pump. Don't see it much today but used to be quite prevalent on the road. Thinking welded braces and upright coming up off the front frame horns is the ticket. Good luck.
1971 Chevy 1/2T 4x4 LWB 350 V-8 Was sm465-now 350TH/np205 Tilt, Tach, Towhooks Original Truck AM/FM Wellington, Ks |
11-28-2020, 01:08 PM | #4 | |
Did the original crank up mechanism fail? I'm not sure why some aftermarket outfit isn't making a heavy duty replacement? Or one could get the spare crank/winch off of a newer junkyard pickup and adapt it to the GMT400 frame.
Current/past Chevy/GMC trucks: 1958 Chevy C-60; 1965 GMC C-50; 1965 Chevy C-10; 1971 Chevy K-10; 1973 Chevy K-20; 1976 GMC C-20; 1977 Chevy C-10 Suburban; 1980 Chevy K-10; 1989 Chevy K1500; 1991 GMC V1500 Suburban; 2016 Chevy K2500 HD Other vehicles: 1988 Jeep XJ; 2011 Toyota 4Runner |
11-28-2020, 02:04 PM | #5 |
Thanks guys I'm going to give it a try . My 79 g20 van has a front mount and dont run hot hope for the best I guess. No the factory stuff works but my camper hangs over the bumper so I can't get to the tire winch hole.
11-29-2020, 12:59 AM | #6 | |
This is mine. I made it from a van tire carrier and bolted it to the brushguard. No cooling problems, this is Florida and I always pull a trailer with the a/c cranking.
11-29-2020, 02:40 AM | #7 |
I have this one for 70’s Ford. Pretty simple design
11-14-2021, 10:03 PM | #8 |
11-14-2021, 10:16 PM | #9 |
11-15-2021, 10:40 PM | #10 |
Awesome, I can’t figure out a way to message you since your inbox is full. Maybe shoot me a PM and we can work something out. Thanks!
Steve Member of the Foot Pedal Club '83 Chevy K20: 6" Rough Country, 3" Performance Accessories BL, Bushwacker Cutouts, 38x15.50 Mickey Thompson Baja Claws, 350 HP 350 crate engine from Jegs, Turbo 400 |
11-16-2021, 05:10 PM | #11 |
How about $85 and shipping? I cleaned out in box too
11-16-2021, 09:38 PM | #12 |
PM sent. Thanks!
