Old 11-21-2021, 09:11 PM   #1
Canadian63GMC
Canadian63GMC's Avatar
Door edge question before I get too far
I’ve been at these doors, getting ready to install lower inner and outter skins, I had some damage from a previous accident (i can only assume) on the lower part of the door plus all of the nasty rust. Check out these pictures and let me know if your 60-63 (possibly 64-66) have this contoured front door edge. Maybe even if someone could post up a pic of there’s? I’d rather bang it flat now if I need to. I think you can see the front curled over lip I’m talking about…. Thanks! Name:  EA64E282-6C3D-467A-BD20-37FCD1A56E00.jpg
Canadian63GMC is offline   Reply With Quote
Old 11-21-2021, 09:30 PM   #2
SkinnyG
SkinnyG's Avatar
Re: Door edge question before I get too far
Do you mean how the edge of the door panel lays over at the flange?
Does not look correct, looks "dented."
1961 Apache: Shortboxed, pancake, step-notch, air-ride, boosted-LS
1977 Silverado: The Daily - shortboxed & dropped, potato-potato
V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7lbs in a 1lb bag
Lotus Super 7 Replica: Scratch-built street-legal rollerskate
SkinnyG is offline   Reply With Quote
Old 11-21-2021, 09:33 PM   #3
Canadian63GMC
Yep, that’s where I’m talking about, basically where the skin folds over the flange. It looks like it could be factory but I don’t have anything else to compare it to…
Old 11-21-2021, 11:51 PM   #4
SkinnyG
SkinnyG's Avatar
The door skin should be one smooth transition from the fender, through the door, into the cab.
Old 11-22-2021, 10:24 AM   #5
Canadian63GMC
Sounds good, I’ll hammer and dolly that front edge flat, thanks!
Old 11-23-2021, 01:38 AM   #6
ApacheNick
I just looked at both of my trucks and there should be a slight bend at the front of the door.
I suspect hammering that flat would cause interference problems with the fender.
Your door looks exactly like mine.
Nick
1961 Apache short stepside 4X4 SBW 348/4 speed
1960 Apache C-20 long fleet custom cab BBW 283/4 Speed
1967 rust bucket Olds Cutlass with a 455
1972 GMC K-15 350/4 speed long fleet
ApacheNick is offline   Reply With Quote
Old 11-23-2021, 07:41 AM   #7
Canadian63GMC
It looked factory! Haha, maybe I will have to hammer it back now…
Old 11-23-2021, 07:43 AM   #8
Canadian63GMC
Anyone else out there able to chime in?
Old 11-23-2021, 09:35 AM   #9
joesscamaro
Pretty sure it has that "rolled" edge from the factory. Like Skinny mentioned, if you're going for the seamless look, you would want to correct that. I think it all depends on what look you're going for.
joesscamaro is offline   Reply With Quote
Old 11-23-2021, 09:54 AM   #10
cwcarpenter98
cwcarpenter98's Avatar
My doors have a slight roll over to them. I've seen many builds that made every edge around the door flat and really fine tuned the gaps so that all the panels look perfectly flat from front to back. Looks real nice, but sure is a ton of work. I left my doors the way the factory did
Christian Carpenter
1963 C10 - Frankentruck 283, 3 speed with overdrive
Overdrive wiring here
1981 C10 - Penny
1995 Dodge Dakota Sport
Old 11-23-2021, 10:13 AM   #11
Canadian63GMC
Thanks for the info…. I’m kind of right in between now as I’ve hammered the front edge fairly flat… (still a slight roll). not sure which way to go from here. About to weld in the lower skin so I will see how the warpage is and how the forward edge blends together…
Old 11-23-2021, 10:41 AM   #12
bhap
Active Member
bhap's Avatar
Here is a pic from the assembly manual of the front edge of door to fender. You can see the taper in the front edge of door. Hope this helps.
bhap is offline   Reply With Quote
Old 11-23-2021, 11:16 AM   #13
SkinnyG
SkinnyG's Avatar
I apologize for steering you wrong; wasn't my intent.
After warping the hell out of m y door skins with the new bottom skin, I fabricated my own skins and did no such "curve." Last night I took a look at the full skin I removed from one of my doors, and they are curved at the both ends too.
I guess it comes down to what you want. I don't want the curve, so I didn't put any curve in.
My bad. I am pretty ignorant at times....
Old 11-23-2021, 11:17 AM   #14
Canadian63GMC
Well look at that… guess I need to hammer it back… try not to make too much of a mess! Thanks for that info!
Old 11-23-2021, 11:18 AM   #15
Canadian63GMC
Hey all good, more info the better!
Old 11-23-2021, 01:01 PM   #16
66C10LB
I am at a similar point, soon repairing my door bottoms like you. I think that the main thing to do is to install the doors on the cab while repairing the door bottoms to ensure that the slight curvature lines up, has proper gapping, and looks appropriate with the cab.
66C10LB is offline   Reply With Quote
Old 11-23-2021, 01:37 PM   #17
Canadian63GMC
Yeah, I will be hanging doors after stitching in lower skin and before I install the inner skin… I took a lot of tips from GIBSON63 off of YouTube and made a contour template to go off of but which was hard as I had accident damage on the fender and door. Actually used the new fender for part of the template contour. I think I will end up banging this back with the rolled edge like stock. See how it looks first I guess! The outter door skin patch panel had a major flat spot in the middle so I took the English wheel to it to give the bowed out center. Lots of work!
Old 11-23-2021, 05:41 PM   #18
66C10LB
Here is a picture in case it helps...
Old 11-23-2021, 06:53 PM   #19
Canadian63GMC
Nice to see someone is having just as much fun as me!
Old 12-03-2021, 03:55 PM   #20
Canadian63GMC
Hope I can post my next question on my same thread and maybe get another question answered. My door that I haven’t started on yet has a bracket noted in the pictures while the right hand door I’m working on doesn’t. I don’t really know what this is for and can’t find it in any catalogue… thoughts? You could tell it used to be there… Name:  FE8EBD9A-8DD3-4BDB-A17A-5EDE6E8E8C8C.jpg
Old 12-03-2021, 11:42 PM   #21
cwcarpenter98
That bracket is for stopping your window regulator in the down position. You can slide the bracket fore or aft depending on how far you want the window to go down into the door
Christian Carpenter
1981 C10 - Penny
Old 12-04-2021, 08:59 AM   #22
The Rocknrod
Moderator
The Rocknrod's Avatar
Yep, if you look through this thread there are pics. - http://67-72chevytrucks.com/vboard/s...d.php?t=548837
Old 12-04-2021, 12:12 PM   #23
Canadian63GMC
Excellent! Thanks a ton, exactly what I was looking for
Old 12-04-2021, 12:29 PM   #24
Canadian63GMC
Hard to find those anywhere!
Copyright ©2000 - 2022, vBulletin Solutions Inc.
