11-21-2021, 09:11 PM | #1 |
Door edge question before I get too far
I’ve been at these doors, getting ready to install lower inner and outter skins, I had some damage from a previous accident (i can only assume) on the lower part of the door plus all of the nasty rust. Check out these pictures and let me know if your 60-63 (possibly 64-66) have this contoured front door edge. Maybe even if someone could post up a pic of there’s? I’d rather bang it flat now if I need to. I think you can see the front curled over lip I’m talking about…. Thanks!
11-21-2021, 09:30 PM | #2 |
Re: Door edge question before I get too far
Do you mean how the edge of the door panel lays over at the flange?
Does not look correct, looks "dented."
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS 1977 Silverado: Shortboxed & dropped, potato-potato V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag Lotus Super 7 Replica: Scratch-built street-legal rollerskate |
11-21-2021, 09:33 PM | #3 |
Yep, that’s where I’m talking about, basically where the skin folds over the flange. It looks like it could be factory but I don’t have anything else to compare it to…
11-21-2021, 11:51 PM | #4 |
The door skin should be one smooth transition from the fender, through the door, into the cab.
11-22-2021, 10:24 AM | #5 |
Sounds good, I’ll hammer and dolly that front edge flat, thanks!
11-23-2021, 01:38 AM | #6 |
I just looked at both of my trucks and there should be a slight bend at the front of the door.
I suspect hammering that flat would cause interference problems with the fender. Your door looks exactly like mine.
Nick 1961 Apache short stepside 4X4 SBW 348/4 speed 1960 Apache C-20 long fleet custom cab BBW 283/4 Speed 1967 rust bucket Olds Cutlass with a 455 1972 GMC K-15 350/4 speed long fleet |
11-23-2021, 07:41 AM | #7 |
It looked factory! Haha, maybe I will have to hammer it back now…
11-23-2021, 07:43 AM | #8 |
Anyone else out there able to chime in?
11-23-2021, 09:35 AM | #9 |
Pretty sure it has that "rolled" edge from the factory. Like Skinny mentioned, if you're going for the seamless look, you would want to correct that. I think it all depends on what look you're going for.
11-23-2021, 09:54 AM | #10 |
My doors have a slight roll over to them. I've seen many builds that made every edge around the door flat and really fine tuned the gaps so that all the panels look perfectly flat from front to back. Looks real nice, but sure is a ton of work. I left my doors the way the factory did
Christian Carpenter 1963 C10 - Frankentruck 283, 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
11-23-2021, 10:13 AM | #11 |
Thanks for the info…. I’m kind of right in between now as I’ve hammered the front edge fairly flat… (still a slight roll). not sure which way to go from here. About to weld in the lower skin so I will see how the warpage is and how the forward edge blends together…
11-23-2021, 10:41 AM | #12 |
Here is a pic from the assembly manual of the front edge of door to fender. You can see the taper in the front edge of door. Hope this helps.
11-23-2021, 11:16 AM | #13 |
I apologize for steering you wrong; wasn't my intent.
After warping the hell out of m y door skins with the new bottom skin, I fabricated my own skins and did no such "curve." Last night I took a look at the full skin I removed from one of my doors, and they are curved at the both ends too. I guess it comes down to what you want. I don't want the curve, so I didn't put any curve in. My bad. I am pretty ignorant at times....
11-23-2021, 11:17 AM | #14 |
11-23-2021, 11:18 AM | #15 | |
11-23-2021, 01:01 PM | #16 |
I am at a similar point, soon repairing my door bottoms like you. I think that the main thing to do is to install the doors on the cab while repairing the door bottoms to ensure that the slight curvature lines up, has proper gapping, and looks appropriate with the cab.
11-23-2021, 01:37 PM | #17 | |
11-23-2021, 05:41 PM | #18 | |
11-23-2021, 06:53 PM | #19 |
12-03-2021, 03:55 PM | #20 |
Hope I can post my next question on my same thread and maybe get another question answered. My door that I haven’t started on yet has a bracket noted in the pictures while the right hand door I’m working on doesn’t. I don’t really know what this is for and can’t find it in any catalogue… thoughts? You could tell it used to be there…
12-03-2021, 11:42 PM | #21 |
That bracket is for stopping your window regulator in the down position. You can slide the bracket fore or aft depending on how far you want the window to go down into the door
12-04-2021, 08:59 AM | #22 | |
Moderator
12-04-2021, 12:12 PM | #23 |
Excellent! Thanks a ton, exactly what I was looking for
12-04-2021, 12:29 PM | #24 |
Hard to find those anywhere!
