Ridetech Arms, Dropped Spindles, and 15" Wheels
I know that factory lower control arms interfere with 15" wheels when running a drop spindle. Does anyone know if running Ridetech tubular lower control arms will give enough clearance for 15s with a 2.5" drop spindle?
![]() Join Date: Feb 2016
Re: Ridetech Arms, Dropped Spindles, and 15" Wheels
Unfortunately it's not that simple of a question. Wheel offset also plays a part in whether your combination will work. You can have interference between the wheel and the tie rod.
I replaced my factory lower control arms with reproduction ones and I had to grind them so the brake rotors didn't rub. So mixing aftermarket parts causes more problems. What brand spindles? Some of the cheaper ones are not always the drop they are advertised to be. Found that out on a Firebird some years ago. One side was 2 inches and the other side was 1 5/8" needless to say it took us a bunch of messing around to figure out why the car didn't sit level. Manufacturing inconsistencies will mean that what worked on my truck may not work on your truck. What does RideTech say? Can you post the wheel sizes and who's spindles you have?
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
Beep! Beep!
![]() Join Date: Nov 2003
Also, I wouldn't say it's a dire situation either. A little time with a grinder will fix the issue. I'm running 2.5" spindles from McGaughy's with 15" rallies and that's all I had to do for my factory arms. Unless you're putting together a concourse truck, likely no one will notice.
1972 Chevrolet C/10 shortbed, stepside, 350, HEI, Fire Engine Red, Black Interior, Former Army cargo transport 2003 Chevrolet 2500HD CC 6.0 4wd 2004 Jeep Rubicon some aftermarket stuff... 2019 Jeep Unlimited Rubicon (the wife's baby hauler) |
275/60R15 with 0 offset on 15x8.5 is what I always thought, but measurements look more like 15x10 (still on truck at the moment)
Looking to buy Ridetech coilover kits with upper and lower tubular arms and CPP spindles. |
Senior Moment
![]() Join Date: Mar 2002
I had ECE 2 1/2 spindles with 15x8 rallies up front. The only problem I had was caliper clearance. Then I found some 15x8 with 4 1/2 backspace, they also mentioned they were for disc brakes. They worked perfect. Trying to remember where I bought them, it was on line
Any way I went with QA1 coil overs. Long story short I went with 20s for better clearance
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN 2013 GMC PU, Oldest Son 71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son 2019 GMC Diesil Dually. Youngest Son 2017 Toyota SUV Daughters car 2018 Traverse , Wife’s Ride Pittsburg Ca 94565 |
#6 | |
![]() Join Date: Dec 2003
i'm running drop spindles factory arms and have had zero interference.
Wheel vintiques 62 series. 8" front 10" rear.
https://www.ebay.com/itm/295742064443 |
#8 | |
Beyond that, backspacing of the front wheels is probably the No.1 issue for contact related problems. Your stated 15x8.5" w/) offset is roughly 4.75"BS which is crowding the a-arm @ only 15" OD & I would bet comes close or contacts the outer tie-rod end. Larger OD wheels can pull that width/offset off because things will fit within the barrel better. Tubular arms can yield more clearance near the BJ pocket depending on how it's made (shaped). Better quality arms are usually clearanced by the manufacturer.
If you need to do things in stages, try starting w/8" or 7" front wheels that will require less back-space to fit under the wheel arch.
