02-12-2022, 06:12 PM | #726 | |
Re: GRIZZ’s English 2001 S10 Extra Cab 4.3 V6 Truck
Often earlier, mostly around 5.00am when the lodger gets up. After the brackets, I had another coffee. Thanks to Nick, I drink more coffee now. It allows me time to reflect for 10-15 minutes when progressing ideas. Then back to the build. Engine bay next. It is pretty untidy. Found some used, scrap aluminium to make a blanking plate. Ductape, gotta love it. Removed the heater pipes’ access, and copied the holes onto the plate. Then got the template Nick had made last weekend and transferred it. Drilled, jigsaw and a regular hand file to shape. Holed. And test fitted. Then removed the grommet again and turned it inside out after cutting back the loom tape. Filled with horrible gloopy black foam stuff. Unpicked most of it. Then drew the grommet over the lumpy bit to the next loom junction. And it seems a perfect length to get to the firewall. Tomorrow morning I will fit the grommet again and screw the plate into the firewall with a bit of sealant around the edges to seal it well. At this point I made a quick escape and closed the shop so I could come in and spend a bit of time with Sally and make dinner. She had done a 9 mile fast walk this morning with Sl in preparation for the Moon walk they are doing in May, for which she has managed to collect £700.00 so far, so she was tired and would not cook for herself. When I came in George, the cat I do not have, had spent most of the day on my chair…….. King George? Tonight I am waiting for KevFromWales to get here to collect the carcass of the MX5 donor. More progress tomorrow I hope. Tired tonight.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE. |
02-13-2022, 04:08 PM | #727 |
So the weekend has been……
Today I had planned on doing a load of smaller tasks that would get me moving along the list that @nickwheeler had previously created as a guide. I like lists. Thanks Nick for creating this. Rezin Rockit Jobs List I’ve broken these down into Mechanical, Electrical and Body. There will of course, be some cross-over as to what should be where. Now that most of the major fabrication - engine and gearbox mounts, scuttle support- is done, the remaining jobs are each much smaller, but they ought to be done in a considered order so that they don’t have to be re-done. Like the old joke about how you eat an elephant: one bite at a time. Getting the car running and driving is the objective. To that end, jobs will be tagged with a priority and difficulty rating as follows: High Priority - large job, that will enable others to be completed, or parts sourced Medium Priority - smaller job, with consequences Low Priority - small job, can be done at any time Difficult - time consuming, orneeds extra parts planned and acquired, or tools, or skills, or more hands OK - achievable with available parts, or minimal time Easy - quick job, needing little equipment or expenditure Your assessment will probably differ slightly! Mechanical Steering Column: Fit column, make connecting shaft, make weather tight High priority - can only fit in one place, and will affect other placements OK difficulty - shafts need turning and welding inside sleeve Clutch Pedal: Adapt Ford pedal to hydraulic, fit master cylinder, connect to slave High priority- requires mods to brake brackets and bulkhead Medium - placing is a two person job Throttle Pedal: Fit Mx5 pedal assembly, and use casting as pad. High priority - needs to attach to bulkhead/pedal bracing Throttle Cable: Longer cable with Mx5 fittings required Low priority - can’t be done until pedal is fitted OK - needs parts sourced, but easy to do .Propshaft: Hybrid Ford/Mazda shaft required to custom length High priority - last big mechanical part, car won’t drive without it, might take a while Easy - cheque book job! Brake Master Cylinder Inspect and improve as necessary Medium Priority - easy job, but needs doing before car is drivable Easy job - standard part, readily available Hydraulic Lines: make new brake & clutch lines as appropriate Medium priority - needs pedal fitted, but best done before other parts fitted Easy job Radiator: Make brackets as required High priority - mods to fan and hoses will be required Easy job Cooling Fan: Mx5 fan needs modifying or replacing Medium priority OK or easy Cooling hoses: modify radiator, expansion and heater hoses as required Medium - needs radiator and other parts fitted first Easy Engine Service: New plugs, oil, filters, cam belt etc Low priority - not to be touched until after it’s running!!!!!!!! Easy Fuel system: Fit tank, fuel pump, filler, pump filter and pipes High priority - probably the biggest single job, affects other parts Difficult - parts choices, fitting, fabrication etc Gear Lever: Needs extending/cranking back to suit driver Low priority OK Exhaust: Make new system from downpipe back Low/medium - needs fuel tank in place OK Airbox/Intake: Fit airbox and modify trunking as required Medium priority Easy Rear Wheels: Sort out correct studs/nuts and fit larger tyres Low Easy Electrical Main Loom: Fit to dash support, connecting to fixed parts and mounting components as required. Route front legs through bulkhead, and along inner wings then modify to match components as necessary. Route rear section along driver’s sill. Medium OK Power Loom: Connect to starter etc, route along chassis to rear, connect to fuse box & distribution block Medium Easy Engine Loom:Route through bulkhead and seal. Mount ECU to dash rail. Medium Easy Rear Loom: Connect to front loom, route to components, secure Low OK Battery: Build and install battery box Low OK Wipers: Design and install - Either OE Land Rover, generic screen mount or re-engineered through scuttle Low - not needed for car driving Depends on decision Body Roll Bar: Source and fit. Make new chassis mounts Low priority OK, once part is on site! Dashboard: Design, build and install dashboard Medium - not required for car to run OK Bulkhead: repair all redundant holes Low ???? - glassfibre work Floor: Strengthen as necessary, adapt for new Roll Bar Low ???? - glassfibre Gear Lever: Lever hole needs moving forward and finishing Medium - needs doing before dashboard Easy Windscreen:Modify and fit High - best done before the underdash electrical work OK - some fabrication and fitting required Seatbelts: Need Roll Bar in place Low OK Job Order Steering Column and Linkage Pedals Wiring looms, concentrating on getting the engine working Hydraulic lines Fuel system Propshaft Exhaust Roll Bar
02-13-2022, 05:13 PM | #728 |
After a rubbish night I was out in the garage early.
Weather forecast was for a lot of rain, so I needed to beat that, and the chill. So I carried on with the firewall plate I had made up yesterday, and the next planned job was to cut the holes in the firewall for the two side wiring looms to come through over the fenders. Then Nick arrived. Coffee, chat, planning and some gift exchanges. He also forgot the sleeve and two parts of the Ford and Mazda steering shafts last week. Plan is to turn them both down on the lathe to fit the tube, drill some holes to weld up after getting the total length right, followed by ensuring it all will work to,wrap,the steering up. After KevFromWales failed to materialise by 01.00 this morning, he eventually made it to my place by 1.00pm Kev and Nick hit it off and gassed for an hour before we loaded the MX5 onto Kev’s trailer. A few mugs of tea, cookies and Kev was off on his return trip to Wales. Once loaded the coal roller headed out. Then Nick and I went back to work. Loads left to do.
02-14-2022, 04:49 AM | #729 |
So next job you,say.
I had hoped to sneak an hour in during the week, but work just was relentless, and by the time I got home in the evenings, I could not be bothered once I had dinner and sat down for an hour with Sally. So Sunday was earmarked for that as well. Looms laid out roughly by @nickwheeler. Hole saw at the ready and off we went. With the position of the gas pedal or is it petrol pedal, or throttle…… and its backing plate, there was just enough room to drill out for the large grommet and loom plus various plugs to get through on each side. Done. Nasty fiberglass filed back a lot to tidy up. Both exits ready. Inside view. And all three looms in place. Loads left to do still, but progress for sure. Nick had been at me since day one when we stripped the MX5 to add a heater to the Rockit, which I kept declining. So this week I was looking for the throttle cable and pedal When I decided to pull the original heater/blower out of a box of bits. Nicks face was like a kid at Christmas, and of course between it, and the original, the Mini blower that this would have been originally, fitted like this. I may be thankful in the long run when I drive it in November…… or March if the heater keeps my feet warmer than a penguins tail. We had agreed to an early stop, by 5.00pm as I wanted to cook Sally a Valentines dinner (nothing that special) as she had been at work all day. But typical Nick, and me for that matter……. The rear lights and fuel tank loom came out to also be laid out and arranged….. Last of the nightmare pile of wires. We should have weighed the loom, just as a matter of interest. After this and now well after 5.00pm we also stood discussing one of Nicks best ideas that came to him while walking around in Rochester Cathedral. Relocating the battery from the rear into the engine bay, which then also included setting out the airbox, MAF and connecting pipe. So a bridge needs to be built, behind the engine, over the gearbox, with a battery tray. (Mocked up roughly in the photo) as well as a bit of a riser for the airbox. And that was how my weekend ended. More jobs added to the list of fabrication jobs. But both of us grinning madly as a bunch of jobs of the list are now partway done. Monday……..
02-14-2022, 04:34 PM | #730 |
Report tonight from Nick Wheeler.
He took the steering parts with him yesterday……… Reporting thus tonight. Pictures aren't in any particular order: Knocking the Mazda shafts apart because I can't get the assembly in the lathe Knocking the Mazda shafts back together Mazda shaft in the lathe New shaft turned down, with the joining sleeve Sleeve slid onto the new shaft All 3 parts slotted together; we need to shorten the new and old ones slightly to get the right length, and weld the sleeve to both And an explanation: We need the joint that matches the steering column and one that matches the rack to be joined together via a longer shaft. the new shaft and black u-joint are the standard Ford/European 9/16 23(I think)spline fittings. Sleeve is thickwall CDS that is almost 9/16 bore and about 150mm long for a strong connection. Certainly stronger than the original modified Cortina shaft that seems to be a piece of rod butt-welded in between the original ends. The Mazda shaft doesn't use those UJ fittings, and is different at each end for some reason. I turned about 100mm of the new shaft down until it was a slip fit into the sleeve. The Mazda shaft was too short to fit in the lathe with the UJ fitted. I wasn't sure how the parts were joined; the UJ is attached with a staked pin, and it turns out the two shafts are just splined inside each other which is probably for crash protection. I knocked them apart and turned some of the loose shaft down to match the new one. Then I knocked them back together with a new O-ring. I still need to drill some cross holes into the sleeve for some belt-and-braces plug welds. We will shorten each shaft by about 20mm, fit the relevant UJs to the column and rack and weld both shafts to the sleeve. That will complete the steering, and allow us to fit the other components that need to go in the same area.[/quote]
02-16-2022, 03:09 PM | #731 |
So with a few ideas bouncing around in my head, and @nickwheeler doing a CAD design, I had a few routes to go, all based on available materials in my pile.
So I made a rough cardboard replica of the battery. Nick did this design and a few others. So I started with a 50mm x 5mm steel strap, bent and cut to bridge the gearbox. And made up a small frame that the battery tray fitted into. Welding next. Looks like a nice fit. Mocked up with the battery in place, clamp in position. The feet will only be welded once the rivnuts or captive nuts are drilled and fixed in. And finally, bracket in place. Pretty pleased with this outcome. There may be some gusseting to be done. Next job will be to create a stand for the airbox to create a raised platform. Onwards…….. in the words of @pauly
02-16-2022, 06:30 PM | #732 |
Nice job on that Rian!
02-17-2022, 03:22 PM | #733 |
Thanks Bill.
Even I was pleased with the outcome.
02-17-2022, 04:03 PM | #734 |
Two small reports……
Nick said: Could I suggest 8.5mm holes in each end of the brackets, and matching 12mm in the rails? I'll provide some weld in threaded bungs, as I'm not convinced about rivnuts for this job, and we need at least two good earth points. 4 M8 threaded bungs to weld into 12mm holes in the chassis rail. We will need to drill clearance holes in the body for it to float over the bosses. These will also make for good battery and starter grounds. I'll make some more, but tapped M6 for the light grounds at each corner. But I'm due at a ringing practice so that's a job for tomorrow. So battery strap V2.0 Bypassed the sleeve, though I still like it. So as @kevins said……. Webbing. Add some brass eyelets And a hot punch. Holey Moley. Brass eyelets added. And then a lightweight mock up. Now we just need to wait for the vegans to object to the tightened nuts. Just teeeeaaazzzinnng. May still go back to the sparkly option ⚡️⚡️⚡️⚡️⚡️⚡️⚡️⚡️⚡️ Thursday….. Weekend soon. Garage time.
02-19-2022, 12:40 PM | #735 |
Part of yesterday’s zero emissions progress was another one of @nickwheeler ‘s crafty longterm ideas.
The Mini heater box, fan and matrix from the original kit car was one speed and no more than lukewarm. Where as it was mentioned that the MX5 heater was a furnace and also 4 speed So dismantling to the sum of its parts, discarding 50% of the useless bulk and redesigning the blower box, exit vents and matrix positioning could lead to a win. So while I searched for a ready made solution (think random discarded containers) Nick grabbed some pizza cardboard box, scissors and masking tape. He won……….. Further fine tuning and fitting needed. Also the transmission tunnel needs a hefty chunk of surgery and sculpting to allow the blower to fit under the scuttle and behind the firewall. More added to the list of tasks. Today the power is still out and no prospect of a repair today either. A freezer load of food to be discarded. Not impressed with that at all. But apparently we are not a priority. So this morning I cleaned up the carport area after the storm yesterday. Of course the wind and rain waited just for that point where I was done, to start all over again. So now it is cold, wet, windy and raining outside. But earlier on I did make it down there to remove the front wheels as I want new valves fitted that were not done when the tyres got fitted as the plan was blasting and painting. While I was there I decided to clean up and reset the tie rod ends as the front end was way out of line. New short term lodger John came down when he got up to see what I was up to. He is a Trike rider and builder having a full strength V-MAX based trike. He lost a leg at at age 24 in a motorcycle accident when he was T-Boned and had a high thigh amputation. He works as a driving instructor and has a keen mechanical eye. Nice guy to have about too. So an extra pair of hands to hold a twin pair of vice grips on the steering rod. I also cleaned up the threads on both sides so the steering toe in could be fine tuned once the car is completed. Once the threads were done and reassembled I fitted the space savers so the wheels can get taken to the tyre shop. Military spec? Rake. Now sitting indoors with a drink and a fire warning my heatless, cold, dark house. Anyone know a main grid electrical man or woman. Get me some electricity And internet.
02-19-2022, 03:39 PM | #736 |
Spoke to engineers a few minutes ago.
They are trying to get permits for replacement of the pilons that went down. Loads to do. Hopefully by Monday afternoon.
02-20-2022, 03:39 AM | #737 |
Morning world.
Went to bed 10.00 when fire died off. Woken 11.30 by John the one legged lodger banging my door. Bloody house alarm outside had gone off and main control panel is in his room. No battery mains backup with power out for 18 hours. Ended up opening masterpanel as no power on keyboard etc to try figuring it out, then going down to garage, got MX5 battery, jumper leads, some heavy cable and masking tape. Removed dead battery and joined up MX5 battery with a spectacular bodge including jumpers and bits of electrical wire, that shut up the whole lot. So today’s job will be to find a small 12v 15ah battery and install plus reset system.
02-20-2022, 09:08 AM | #738 |
Despite it looking romantic this was more born out of desperation.
Fire, light, warmth. Easy dinner. By 12.00 still no power. But activity in the farmers fields. Headed out in the S10 to get a new battery for the alarm system backup at Tool Station. Cost £23.00 Sally on camera duties. Poles being planted. Maybe we can look forward to power by tonight. New storm forecast is called Franklin. Ooooops. Spending time at Sallys house to get stuff charged up. So no building time really but have stuff going on in my head.
02-21-2022, 04:48 AM | #739 |
Thanks fpr all the advice on generators etc.
Certainly not something I would EVER try or do. I do not understand or trust electricity. Simple. Power came back last night after 6.0pm…… BUT…… Now my whole downstairs of my house is dead, NO HEATING since Friday (have a power shower upstairs that works) No fridges etc. So tried removing and refitting every plug downstairs one by one in a process of elimination Then removed all the plugs, washing machine, drier, radios, side lamps, chargers etc and still it tripped out the mains even before I could start refitting them one by one. So stopped there. Had a glass of sherry, put more wood on the fire. Have to try find an electrician once I have gone through a further process of elimination today. Next step is to remove the downstairs plug circuit breaker, in case that is gone and needs replacing, in which case it could be a simple, affordable job. But both my lodgers are here, one is an electrician at the power station, one was an appliances type electrician 25 years ago, and we will try figure this out in the mean time. Surely it can be fixed…….. As long as John does not trip down the stairs getting his crutches or prosthetic leg tangled in extension cables coming down.
02-22-2022, 06:03 PM | #740 |
Plumber came at 13.00 despite his day job being a night shift.
Straight up on the job after I updated him, up the ladder and not even a cuppa tea. Having unpacked a few cabinets to get to hidden power sources, it was a bit of a mess. Like most of the wiring. Ultimately he had to drop a load of the sockets to find the faults. Loose earths, and ultimately a section that was dead, which he fixed. Two hours later, £90.00 or $120.00 , the heating and circuits downstairs have been reinstated. So tonight the bed will be warm, and the kettle is not balanced on a chair…….. After the electrician left, I tidied up the house. Then shot down to the industrial estate to go look for a set of front side lights and indicators to replace the ones fitted the Rezin Rockit units. No luck, but found out they were Lotus items, followed by @rich suggesting tractor units. Ebay brought up a nice looking set for £22.00 delivered. Same thing with a Lotus badge is £30.00 each. While I was on the industrial estate I got 15 meters of nylon hose to use as fuel line, and some chassis clips for mounting the fuel line and return. Lastly, Kev sent these pics from Wales……. The king may be dead, but it lives on in the Rezin Rockit And off it goes to the scrapyard in the sky. I also ordered some fuel line clips to be collected tomorrow. @nickwheeler will hopefully be pleased too. Progress.
02-22-2022, 10:57 PM | #741 | |
The only bit of sunshine in a dark pile of junk.
02-24-2022, 05:00 AM | #742 |
I noticed that too.
Found some nice looking front repeater and marker lights. Prettier than what is fitted. Will need slight fettling of the body to fit. Tractor parts, cheap at £22.00 the pair, delivered. Perfect. Rain and chilly with a cold front coming in here in Kent today and toward the weekend. Onwards as a certain @pauly says.
02-24-2022, 03:49 PM | #743 |
Got home from work tonight, some sleet on the road.
Chilly outside for sure. Quick coffee, then down to the garage to mess around a bit. @nickwheeler made a template for the heater box and blower to fit under the slimline dash, in order to extend my useable season for the car. So,I pulled out the template box, copied ot, and transferred the measurements onto a Dexian shelf. Grinder (stop s******ing at the back) Result. Tidied and smoorhed. High tech folding tools. Progress. Liking it so far. Chocolates? And folded, not yet welded. Front slot will get cut out once welded and stable. Great fit on the blower too. Really pleased with this. Once welded, I will cut some holes for the directional vents too. Toasty ……
02-25-2022, 04:54 AM | #744 |
Have gone down this morning to check the vents on the box.
Looks like I will have to do a slight redesign and find some slimline vents to fit, or make some narrower grilles. Also, mate Martin, like me, is using an MX5 blower and switches in his 66 C10 truck. It is a direct retrofit to the original airbox with no cutting etc. The switching is either by original switch, or a multi speed switch. VIDEO BELOW. https://youtu.be/18tMWTUCvbY Coming together bit by bit.
02-25-2022, 03:06 PM | #745 |
02-25-2022, 05:32 PM | #746 |
Meet Molly.
No, not Mollie. Sally’s Uncle John, older brother to UncleBob The Hoarder had her for 5 years, born on Christmas day eve. Uncle John was walking Molly today, like he did twice every day, when he collapsed on the path and emergency services could not recover him. So Sally brought her over to me this afternoon as she was a bit of a mess. I love animals, as may be known, and she instantly took to me, possibly feeling secure, who knows. I wanted to offer her a home but it looks like one of Johns daughters may take her on. Sweet pup. And she loved the garage, perfect match? After Sally left, I felt a bit deflated. So I went to the garage, found some Chinese ply to create a template with. Measured, marked and cut……….. More measuring, arty stuff……… some cutting. Then a big hole. Some more fine tuning, cutting and fitting. And close up. And looking over my shoulder. I think it will work, with a bit of fine tuning. So tomorrow morning I need to play some more. Then figure out how to tilt it up a bit, and more importantly, creating a shroud. I really need a spare cover to cut up. Looking forward to getting on with this in the morning .
02-26-2022, 07:15 PM | #747 |
Pretty pleased with the first job I did this morning.
Shaped and clamped the folded box, took a bit of time to make it all square up. But it worked out in the end. More work done through the rest of the day. Back in a bit for those who are interested.
02-27-2022, 03:06 AM | #748 |
I felt like a kid, caught out being naughty yesterday.
Had @pauly over by 09.00 to collect the cab lifter for Woody his C10 bought in 2015 https://forum.retro-rides.org/thread...0-eagle-landed As well as his blasting pot, and a quick bacon sandwich with a mug of tea. After he left I had gone and carried on down at the garage, followed by a visit from Stuart my one neighbour to collect his large die that I had used to clean up the track rod ends when I reset the front wheel tracking last week. When he left it was time for a coffee, which I had just finished when @nickwhheler arrived, me sitting indoors reading the internet. More coffee, note comparing, planning and then off to the garage. Nick brought gifts……… He can explain them. First job was to remove the front grille, make space and do one more trial fit, then tack weld it all in place the steering rod. Not as tight as it looks, and later I would remove what was left of the original Ford engine mount. Then final weld up. More about this later. In the mean time it had become time to address the relocated position of the MX5 gear lever vs original Ford position. The MX5 gearbox is small, and lower than the original Ford part. Marked, cut, and then fine tuned the piece of MX5 tunnel I had removed. This will allow a Mazda part to be bolted in place once I have a gear lever extender screwed in place. 5th gear position was what mainly drove the relocation, as the original box would have been a 4 speed I suspect. Happy with this position too. Loads of small fabrication jobs done. Nick also carried on with modifications to the battery bridge and its mounts. Coffee was consumed constantly, the machine needs fueling.
02-27-2022, 04:01 AM | #749 |
The afternoon flew by with Nick and I continuing with a load of small jobs that are all part of the bigger job at hand.
At one point John, my current short term lodger came home, he needed a place to store his Yamaha V-Max powered trike, so I said to just bring it here. Sounds magnificent. In the mean time it was once again time for the body to come off. Allowing me to cut out the remaining Ford engine mount and for Nick to drill some holes in the chassis, followed by welding in captive threaded nuts he had made to act as a foundation for the battery bridge and as foolproof earth points for the power and loom. Body up again. Resulting in……. With the body on the trolley I carried on with another fiddly, time consuming job. Removing and refitting the steering column repeatedly till all the grinding resulted in a free spinning knuckle. John the lodger was adding a hand and camera skills. 6mm aluminium plate plus a few layers of firewall…… Eventually slick, clearance created, time not wasted but consumed. More cleaning up, grinding back, tidying. Through the day things like the steering shaft, gearbox mount, fender brackets, radiator brackets etc all got painted and cleaned up, in preparation for final (We hope) mounting when the body goes back one more time. It is amazing the amount of work that goes into this build that is not recorded or reported. I liked this posting on a South African Adventure Biking Forum by a member “EssBee” True for both Nick and I, but more so for me, learning so much as the build progresses. [quote author=EssBee link=topic=127490.msg4790247#msg4790247 date=1645884322] Nice work, Grizz, and a LOT of it at that....one doesn't realise how much there is to do in a project like that. Also...it's not stuff you've done before, every step of the way is new to you and requires a brand new line of thought figuring how you're going to go about it. Lot's of kopkrap/head scratching for you guys. [/quote] Nick continued to remove excess materials, parts and obstructions all the time. By 18.30 we put down the power tools as I needed to spend a bit of time with Sally and make dinner. Nick and I usually have a post mortem after the day ends for 30-60 minutes to discuss next jobs, plans, materials needed. One of the jobs that ended up happening while discussing was to remove the complex, space wasting clutch pipe assembly……. More about that later. He also managed to bleed over the wiring loom up front while removing excess cabling. As the battery bridge was completed the next trick was to simplify and reroute some power cables to and from the starter. More about that later too. Suffice it to say that it was a great day again, and huge thanks to Nick for coming to play. We closed shop just after 19.00 in the end, two more ad-hoc jobs done. Final pic, tidy wiring and bridge in place. Sunday will be a new firewall plate, many holes, brake and fuel lines……. And a multitude of other things to do. Progress is happening.
02-27-2022, 03:28 PM | #750 |
Short night.
Woke knackered. Bloody war in Ukraine has people behaving like idiots. Sally could not get fuel on the way to work at 05.00 so texted me to go get her some petrol in case things turned silly again. So I took the diesel company car, with less than 100 miles range left. And my days are a minimum of 65 miles.and a couple of Jerry cns. Got to the gas station…… No Diesel. So I went home, got the S10 and the Jerry cans and headed back, £108 later I had 25 litres for Sally, and the truck filled as it was also on empty. Got back home around 09.30 and had breakfast and read a bit, before going to the garage, before I stepped out the house Nick arrived. So another coffee, checking manuals and creating a shopping list of bits to purchase. While indoors I ordered a set of 7 inch LED headlights. For the car too. Looking forward to seeing them. Then down to the garage. First job was to drill the chassis and lay the two nylon fuel lines, and the rear brake line that @nickwheeler had made up and laid. Chassis clips ordered last week, to be collected. Drilling with 5mm and then an 8mm drill meant I could get the fuel lines sorted pretty quickly. Fuel lines laid, bit invisible against the black chassis. Nick also connected them to the front end at the engine. Another of many small jobs was to drill through to the rear for the rear wiring looms, they will be fed through on ground level, Nick sorted that while I was drilling the chassis. And then of course the transmission tunnel needed to be cut to allow the blower unit to fit. Resulting in a huge hole. So the next job on this will be making it fit, then closing the transmission tunnel again when I do the fiberglass work on the floor, tunnel and a few other spots. .
